The Shanling UA Mini DAC / headphone amplifier adapter lets you enjoy high-resolution files from a smartphone. It incorporates a Cirrus Logic CS43131 DAC chip, a Savitech SA9312 USB interface and an SGM8262 OPA, enabling it to support sampling rates up to PCM 32Bit 384kHz and DSD256, while delivering power up to 205mW into 32Ω (THD+N < 1%). This chipset offers good performance for noise-free sound reproduction and ultra-low distortion of just 0.0004% into 32Ω. Furthermore, the UA Mini is compatible with many operating systems for “plug and play” use. The 3.5mm jack output connector also features an LED indication of the current sampling rate:
| Specifications | |
| Product type | DAC adapter / Headphone amplifier |
| DAC chip | CS43131 |
| Headphone amplifier OPA | SGM8262 |
| USB interface | Savitech 9312 |
| Input | USB-C male |
| Output | 3.5mm jack female |
| Supported sample rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| Output power | 2x 205mW @ 32Ω (THD+N < 1%) 2x 260mW @ 16Ω (THD+N < 1%) |
| SNR | 126dB @ 32Ω |
| DNR | 126dB @ 32Ω |
| THD+N | 0.0004% (-3dB @ 32Ω) |
| Noise floor | 1.4uV (A-WT) |
| Frequency response | 20Hz-20kHz ±2dB |
| Output impedance | 0.5Ω |
| Compatible OS | Andoid, iOS, Windows, MAC OS |
| Cable conductor material | Cuivre plaqué argent |
| General | |
| Dimensions | 42 x 10mm (main body) / 128mm (total length with cable) |
| Weight | 8.4g |
| Package | 1x Shanling UA Mini |
| Input | USB |
| Output | Jack 3.5mm |
| DAC / ADC Chip | CS43131 |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Black |
| Color | Gray |
| Connectic | Male & Female |
| Connector | Jack 3.5mm |
| Connector | USB-C |
| Networking | No |
| Remote Control | No |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
