The Shanling UA4 portable balanced DAC is an easily transportable and relatively affordable solution for enjoying high-resolution audio streams in all circumstances. It features high-end components such as an ES9069Q DAC chip, enabling it to support 32bit 768kHz PCM, native DSD up to DSD512 and MQA streams. Two RT6863 headphone amplifier chips give it an output power of up to 211mW @ 32 ohm. A small display and three control buttons let you easily access settings and control playback. Input is via USB-C port and two outputs are available: 3.5mm jack and 4.4mm balanced jack.
The Shanling UA4 portable DAC features three buttons for adjusting the volume and play/pause of your audio tracks. In addition, a small screen lets you navigate the settings menu and display information about the track currently playing.
The USB port supports UAC1.0 and UAC2.0 standards and is compatible with Windows, Mac, Android, IOS or even a games console such as a Nintendo Switch.
| Specifications | |
| Product type | Portable DAC |
| DAC chip | ES9069Q |
| Amplification chip | 2x RT6863 |
| Input | 1x USB-C |
| Output | 1x Single-ended 3.5mm jack 1x Balanced 4.4mm jack |
| Supported sample rates | PCM 32bit 768kHz, native DSD up to DSD512, MQA |
| Output power | 211mW @ 32 Ohm |
| Gain adjustement | High et Low |
| Digital filters | 8 |
| 3.5MM JACK OUTPUT MEASUREMENT | |
| Output power | 2.1V @ 32Ω |
| Frequency response | 20Hz - 40kHz (-0.7dB) |
| THD+N | 0.0008% @ 32Ω (A-Weight @1.5V) |
| Dynamic range | 120dB @ 32Ω (A-Weight) |
| Channel separation | 124dB @ 32Ω (A-Weight) |
| SNR | 124dB@32Ω (A-Weight) |
| Output impedance | < 0.4Ω |
| BALANCED 4.4MM JACK OUTPUT MEASUREMENT | |
| THD+N | 0.0006% @ 32Ω (A-Weight @1.5V) |
| Dynamic range | 116dB @ 32Ω (A-Weight) |
| Channel separation | 106dB @ 32Ω (A-Weight) |
| SNR | 120dB@32Ω (A-Weight) |
| Output impedance | < 0.8Ω |
| General | |
| Dimensions | 60 x 25 x 11mm |
| Color | Silver |
| Weight | 20.8g |
| Package | 1x Shanling UAC4 portable DAC 1x USB-C to USB-C cable |
| Input | USB |
| Output | Jack 4.4mm |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9069Q |
| Max sampling rate | MQA |
| Color | Silver |
| Networking | No |
| Remote Control | No |
