XDUOO LINK2 BAL Portable Balanced USB DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256
15%
Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
Reduced price!
Reference : 15954
Limited time offer:
149,00 €tax incl.
-15%
126,65 €tax incl.
105,54 € tax excl.
Shipping date: 06-05-2025.
xDuoo Link2 BAL
xDuoo Link2 BAL DAC USB Amplificateur Casque Symétrique Portable 2x CS43131 32bit 384kHz DSD256
Dual DAC & Balanced design
The Link2 BAL features two CS43131 DAC chips, one for each channel, offering excellent audio stream decoding performance and supporting high resolution streams, up to 32bit 384kHz PCM and DSD256. This design allows the Link2 BAL to achieve an SNR of 127dB for clear and accurate sound reproduction. In addition, the converter and amplifier chips are separately powered to minimize distortion and noise at the output.
Independent amplifier circuit for high power
The amplifier stage uses a TI LM27762 chip, offering a high efficiency of 85% while maintaining low power consumption. It is thus able to develop a comfortable power with a beautiful dynamic.
Dual headphone output
The xDuoo Link2 BAL, versatile, has a double headphone output to adapt to all listening equipment. There is a balanced output on 4.4mm jack and a single-ended output on 3.5mm jack.
1Play/Pause button
2Volume -
3Volume +
4UAC Mode
5Power mode
Product typePortable balanced USB DAC and headphone amplifier
DAC chip2x CS43131
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Output powerSingle-ended : 125mW @ 32Ω
Balanced : 270W @ 32Ω
DSD up to DSD256
Frequency response20Hz - 20kHz (±0.5dB)
THD+NSingle-ended : 0.001% @ 1kHz
Balanced : 0.0007% @ 1kHz
SNRSingle-ended : 123dB
Balanced : 123dB
CrosstalkSingle-ended : ≥ 77dB
Balanced  : ≥ 120dB
Dimensions63 x 23.5 x 13mm
Weight28g
Package1x xDuoo Link2 BAL
1x USB-C Cable
1x USB-C to Lightning cable
1x Female USB-C to male USB-A adapter
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
2 reviews
Petit mais costaud!
Chanceux comme je suis, on m'a offert ce DAC portable et il a été une vraie révélation.
Pour commencer il a de la puissance à revendre, largement suffisante pour la majorité des casques (surtout en symétrique), et énormément pour la plupart des intras, je dirais même presque trop (avec des écouteurs sensibles et un câble Pentaconn vous ne dépasserez les premiers niveaux de volume sur l'appareil).
Quant au son lui-même, pour moi l'équilibre est très bon, parfait pour les écoutes dites reposantes, de la douceur dans les hautes fréquences, les graves et les médiums restent bien contrôlées.
J'ai eu un excellent combo avec des Shure Aonic 4 et l'appli mobile USB Audio Player Pro, et aussi bien avec Roon sur PC.
Eu égard au prix et aux qualités précédemment décrites, je dirais que c'est un must have si vous cherchez une solution portable intéressante.
This review has been posted for XDUOO LINK2 BAL Portable Balanced USB DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256
Outstanding! Neutrality and musicality, excellent physical controls
The controls work under Windows 7, the pause button can pause Youtube in Google Chrome. The analog-like audio quality, excellent price that rivals 2x more expensive products...Works under Android 8 with HTC 10. Very unique timbre, tested with Sennheiser HD599 and Focal Listen Pro. The detail does not hit you in your face, unlike ESS DAC. It gave slightly better performance than Arcam rPac (which had an expensive OFC USB cable). Yet, plenty of neutral detail even under Youtube (shocking, I know). Bass is soft and dense (in a good way, controlled, with impact). Best of all, the listen is not tiring. Normally, this level of detail is fatiguing, especially with TI or ESS DAC products. I know of this little gem because of this expert review, see the LINK below (pun intended). There are 2x more expensive dongles that are not better. Audiophonics has unbelievable customer support via e-mail, even late at night, and great price, better than the official Aliexpress shop of Xduoo`s:
https://andyaudiovault.com/xduoo-link2-bal/
Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a...
