This 24-position digital incremental encoder features a D Shaft for mounting a knob. It can be used as a volume control, or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push-button, so it can also be used as a source selector, for example.
Type of product | Mechanical Encoder |
Pulses per revolution | 24PPR |
Number of notches | 24 |
Orientation | Vertical |
Shaft length | 20mm |
Shaft diameter | Ø6mm |
Operating temperature | -10°C / +70°C |
Supply Voltage Max | 5V DC |
Termination | Solder Pin |
Push Switch | With push-button switch |
Encoder output | Quadrature |
Encoder technology | Mechanical |
Encoder type | Incremental |
Encoder mounting | Through Hole |
Number of channels | 2 |
Shaft Type | D Type Flatted End |
