AUDIOPHONICS AP300-S250NC Power Amplifier Ncore NC252MP
The Audiophonics AP300-S250NC is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality.
4.9 / 5
By buying this product you get 54 loyalty points
Reference : 18419
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 25-06-2025.
Audiophonics Workshop amplifiers range
Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
AUDIOPHONICS AP300-S250NC Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
The Audiophonics AP300-S250NC is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex Ncore NC252MP Amplification Board
The amplification circuit uses a module Hypex Ncore NC252MP. It is a versatile, high-performance Class D amplifier. It offers a very comfortable power of 2x150W at 8Ω while taking advantage of the high efficiency of Class D amplifiers.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift and taking into account feedback only at the speaker output.
This amplifier does not have a decoupling capacitor, so it lets the DC component of the signal through. Make sure your source has no DC component present at the output. The DC protection of the module switches on at 12VDC which is very permissive.
NCore Technology
NCore amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers, but also to surpass them in terms of sound quality. As a result, they are able to deliver clear, rich, musical sound while remaining compact. This NCore technology combines the stability of the Hypex UcD series amplifiers with lower distortion and output impedance.
SMPS Power Supply
The NC252MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NC252MP module also has an overload protection system.
Connectivity
The AP300-S250NC amplifier features a 2-pole stereo RCA input on gold-plated sockets, plus a 3-pole stereo XLR input for balanced signal processing. The XLR or RCA input source is selected via two switch buttons (right and left channel). The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or spades for quick and easy connection. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button is used to switch the unit on and off.
100% Aluminum Case and clean lines
The Hypex NCore NC252MP amplifier is housed in a 100% black brushed aluminum case. The thick walls of this elegantly-finished case are highly resistant, providing the components with the protection they need. The natural conduction of aluminum, together with a carefully designed air flow, helps dissipate the heat generated by the module. In addition, the acrylic front panel is screen-printed with the Audiophonics logo, and the rear with the nomenclature of each input/output. Its compact size makes it easy to integrate into any audiophile installation, offering high performance in a small space.
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Total dimensions (WxDxH)300 x 248 x 62mm
Weight2080g
Package1x Audiophonics AP300-S250NC
1x Power cable
InputXLR
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
9 reviews
Compact and powerful
Bought this a as a back-up supplement to the Audiophonics corresponding pre-amp that I bought earlier. Works perfectly with my ATC SCM-40 closed-box-design speakers. No need for more power. Complete control, no need for more power. Turns a little warm in temperature, but perfectly capable to put my hand on the casing. Replaces a temporary Accuphase amplifier.
This review has been posted for AUDIOPHONICS AP300-S250NC Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
Très agréablement surpris
Premier achat sur ce site.
Connecté à des enceintes DIY de 30 ans dont je n'arrive pas à me lasser (base Seas speakers). D'abord surpris puis bluffé par la limpidité du son : aucune agressivité, détail et rendement important.
Connectique de très bonne facture. Esthétique sobre comme j'aime. J'hésitais avec le 2x500 w mais la puissance est très suffisante.
Bref : je recommande. Vivement !
Son parfait. Reste frais.
Très satisfait de la qualité sonore. La source est un Fosi ZD3, connecté en XLR équilibré.
Alimente deux enceintes colonne Jamo. La réponse en fréquence est linéaire. Son bien détaillé.
Un grand avantage de la classe D est que l’appareil génère très peu de chaleur. Je l’ai placé dans un meuble fermé, avec un ventilateur à l’arrière. Il reste très frais.
Un petit inconvénient : le boîtier n’était pas stable, deux pieds ne touchaient pas le sol. Cela était dû aux deux vis avant qui fixaient le panneau supérieur. Les trous dans le panneau n’étaient pas exactement alignés avec le filetage du châssis. Après avoir légèrement desserré les vis, le boîtier était stable. Je pense toutefois qu’il devrait l’être même avec les vis bien serrées.
comparé au Fosi V3
Voici mon ressenti après pas mal d'écoutes sur du Carl Cox, Iron Maiden remasterisé, Epica,Arch enemy, Stella Rose…
Comparé au Fosi V3 stéréo j'ai l'impression avec le Hypex d'entendre 3x plus de petits détails, d'éléments présents dans les enregistrements qui participent à l'ambiance et à l'immersion.
Sensation de calme dans la musique, tout est là, on peut pousser le volume, tout reste imperturbable et "paisible".
Comparée à l'écoute au casque les enceintes repassent devant.
L'écoute au Fosi ressemble peut-être davantage à mon expérience en class A/B (Harman, Marantz), sans arriver à mettre de mots dessus, c'est un peu plus chatoyant mais semble perdre un peu en justesse au passage. Le Hypex donne l'impression de prendre plus son temps et d'être plus lent, clairement 3 minutes 40 ne sont pas remplis de la même façon.
Est-ce que ça vaut le coup de mettre 5x le budget du Fosi dans un bloc Hypex
audiophonics? Sur mon instal et sous réserve qu'il tienne dans le temps je dirais que oui sans hésiter. En gardant en tête qu'on a déjà de quoi se faire plus que plaisir avec un V3 stéréo
S'il fallait grossièrement caricaturer avec le Fosi on est devant une chaîne Hifi, avec le Hypex Ncore on est au studio
Audiophonics AP300 S250NC
Reçu hier après midi et aussitôt mis en service. Branché sur un ampli Musical Fidélity M3i très sympa mais un peu trop juste pour mes enceintes KEF Q900 . A la mise en route bonne surprise . Mes enceintes aiment ça, Les basses moins lourdes et plus punchy et plus de dynamique pour la rythmique et de détails mais les aigus un peu trop présent à mon goût ... Mais au bout de 24h de fonctionnement c'est beaucoup mieux donc nickel. Mes doutes étaient bien fondés . Ils leur fallait du jus aux Q900.
The Audiophonics AP300-S250NC is a stereo amplifier based on an amplification module Hypex Ncore NC252MP. This...
