DAYTON AUDIO DAX88 Power Amplifier 8 Zones WiFi 12x80W 4 Ohm
Dayton Audio's DAX88 is an 8-source, 8-zone amplifier for a complete multi-zone audio system. With an easy-to-use control application, Matrio, the DAX88 allows you to listen to your music wherever you are in your home. The flexibility of six stereo amplification zones and two stereo line level preamp zones allows you to use DAX88 with the speakers of your choice.
By buying this product you get 149 loyalty points
Reference : 15093
1 499,00 €tax incl.
1 249,17 € tax excl.
Grantie 5 ans
Dayton Audio DAX88
Amplifier 8 Sources 8 Zones WiFi 80W 4 Ohm
Dayton Audio DAX88 Amplificateur 8 Sources 8 Zones WiFi 60W 4Ω
Warning, before connecting this amplifier you must position the power selector in accordance with your electrical network (220V or 110V).
Uncompromising performance
With 8 sources and 8 zones, the DAX88 offers the ultimate customizable multi-zone audio experience, designed for simplicity, flexibility and easy remote control. With 75W per channel, the amplifier is powerful enough to deliver an immersive listening experience throughout your home. It is also capable of bridging between channels to deliver 180W of power.
Freedom in Simplicity
The DAX88 offers a wide range of analog and digital inputs, including WiFi streaming options (AirPlay, Spotify Connect, DLNA). Equipped with a dedicated WiFi channel, the DAX88 allows you to stream your music directly from your favorite streaming service. Analog input options, including four RCA, seven 3.5mm jacks and two optical connections allow you to use virtually any type of source.
The output flexibility of the DAX88 allows you to choose your speaker system or integrate the DAX88 into a pre-existing system. With six stereo amplification zones and two stereo preamp zones, the unit gives you the ability to use any combination of speakers as well as additional amplifiers.
Multi-Zone Immersion
Dayton Audio's Matrio mobile application simplifies your audio system by giving you and others access to multi-zone control from your mobile devices. With the ability to choose between eight sources and eight zones, Matrio centralizes your different audio systems in a single interface. Matrio allows you to switch sources, adjust volume, tone, and zone balance, and group zones.
Your music your way
Thanks to the integration of a dedicated WiFi streaming channel, the DAX88 makes it easy to listen to the music you love directly from your favorite streaming service.
Command at your fingertips
The Matrio application gives you complete control of each of your eight exit zones. The Zone Control menu allows you to adjust all parameters of the selected zone, including power on/off, source selection, volume control, and mute. Additional features such as bass and treble or left/right balance control are also available, all within an intuitive interface.
All the control all at once
The Group Control menu of the Matrio application will allow you to act directly on previously defined groups of zones. Thus, each setting made for a group applies to all the zones in the group.
Customize your sources and zones
Matrio allows you to customize the names of your sources, zones and peripherals so that you can quickly identify the zones and entries you are acting on. This is also a useful option when you need to group several zones. The modified names appear in the application for all users on your network.
Application mobile Android Play Store Application mobile iOS App Store
1Zone Signal LED
2Zone Status LED
3Power LED
4Power ON/OFF
1Voltage selection
2AC Supply input
3Bridge / Stereo mode switch
4Speaker
5Zones 7 & 8 Preamp outputs
612VDC Trigger outputs
7Stereo RCA inputs
8Stereo 3.5mm inputs
912VDC Trigger inputs
10Channels 5 & 6 Optical Toslink inputs
11Serial port for RS232 control and device updates
12WiFi Antenna
13Keypads connection
14LAN connection
Product typeMultizone amplifier
Channels6x Stereo amplified
2x Stereo preamp
Power75WPC @ 8Ω
80WPC @ 4Ω
180WPC @ 8Ω Bridged
Amplification classClass D
Inputs4x RCA
7x Optical
1x WiFi (AirPlay, Spotify Connect, DLNA)
Outputs6x 4 Poles Phoenix connectors
2x RCA
SNR> 87dB
THD0.6%
Amplifier protectionOverload
Short circuit
Thermal
Trigger12VDC
Max input sensitivity620mV
Line out voltage1.5V
Bass control±12dB @ 100Hz
Treble control±12dB @ 10kHz
Power supply115VAC 60Hz, 230VAC 50Hz (switchable)
ConsumptionStandby : 23W
Max : 1031W
Dimensions42.5 x 10.1 x 36.2cm
Weight7.84kg
InputWiFi
OutputPhoenix connector
Channel8
Amplifier chipN/A
Power (W)80.0
Dayton Audio's DAX88 is an 8-source, 8-zone amplifier for a complete multi-zone audio system. With an easy-to-use control application, Matrio,...
