MATRIX MA-1 Power Amplifier
The Matrix MA-1 power amplifier is part of the brand's M series, completed by the MS-1 streamer and MP-1 preamplifier. This new series features a new design, both in terms of appearance and internal structure. This power amplifier is capable of delivering up to 2x 450W at 4 ohms and 1x900W at 4 ohms in bridged mode.
By buying this product you get 889 loyalty points
Reference : 19303
8 899,00 €tax incl.
7 415,83 € tax excl.
MATRIX MA-1 Class AB Power Amplifier Stereo 2x450W / Mono 1x900W 4 Ohm
Matrix MA-1 picture
The Matrix MA-1 power amplifier is part of the brand's M series, completed by the MS-1 streamer and MP-1 preamplifier. This new series features a new design, both in terms of appearance and internal structure. This power amplifier is capable of delivering up to 2x 450W at 4 ohms and 1x900W at 4 ohms in bridged mode. Connections include the essentials, as well as two 12V triggers. A switch allows gain to be adjusted to 2 levels for greater compatibility with different types of preamplifier and speakers. As for its power supply, Matrix has chosen to integrate an independent transformer per channel and numerous capacitors for an extremely reliable, clean power supply.
MATRIX MA-1: a high-performance power amplifier
The Matrix MA-1 power amplifier uses a Class AB amplification system with a parallel multi-triode push-pull output stage. 10 ONSEMI transistors per channel compose the push-pull amplification circuit, reducing the impedance at the amplifier's output terminals. Powerful, the MA-1 delivers up to 2x 450W at 4 Ohm and 1x900W at 4 Ohm in bridged mode.
MA-1 amplification stage picture
Stereo mode
Stereo mode
Each channel is processed independently for a high level of detail and precision.
Bridged mode
Bridged mode
In bridged mode, the combination of two MA-1s gives you up to 2x900W of power at 4 ohms. This makes it possible to drive all types of speaker, even the most difficult.
Mono mode
Mono mode
In mono mode, you can power two loudspeakers in a configuration with two MA-1 amplifiers and create a bi-wiring connection.
MA-1 gain settings
MATRIX MA-1: Gain control
The MA-1 amplifier has two gain settings. A normal setting is equivalent to +30dB, and an attenuation setting to +24dB. This allows the MA-1 to be paired with a wide range of preamplifiers and speakers available on the market.
MATRIX MA-1 : une alimentation symétrique
The MA-1 power supply incorporates one transformer per channel for a totally balanced design and a total power of 1250VA. Added to this are 14 parallel-connected capacitors per channel, each rated at 6,800uF. This means a total of 190,000uF per channel. The advantage compared to using a single capacitor of this power lies in the fact that it limits the internal resistance for greater flexibility in managing significant currents.
MA-1 power supply stage
MA-1 cooling system
MATRIX MA-1: advanced cooling system
Two sensors located on the main heat sink are connected to the MA-1 microprocessor for continuous evaluation of the unit's temperature. When the temperature exceeds a certain threshold, a large, silent fan (approx. 18cm in diameter) starts up, adjusting its speed dynamically.
Matrix MA-1 connector overview
1Mode selector: Stereo / Bridge / Mono
2Gain adjustment
3RCA/XLR input selector
4XLR stereo input
5RCA stereo input
6Service port
7Trigger IN/OUT
8Mono/Bridge input
9Right channel speaker terminal output
10Power switch
11Fuse
12IEC power supply
13Left channel speaker terminal output
Product typePower amplifier
Amplification typeClass AB
Inputs1x RCA stereo
1x XLR stereo
OutputSpeaker terminals
Input sensitivity1.48Vrms @ Stereo/Mono mode
1Vrms @ Bridge mode
Output powerStereo / Mono mode: 2x 250Wrms @ 8Ω, 2x 450Wrms @ 4Ω
Bridge mode: 1x 500Wrms @ 8Ω 900Wrms @ 4Ω
Frequency response20-20kHz (+0, -0.15dB - 142kHz@-3dB)
SNR-122dB @ +24dB A-weighted
-118dB @ +30dB A-weighted
THD+N<0.02% @ 250W 8Ω Stereo/Mono mode
<0.06% @ 500W 8Ω Bridge mode
Crosstalk-120dB
Gain+24dB
+30dB
Load impedance2-16 ohm Stereo/Mono mode
4-16 ohm bridge mode
TriggerIn: DC 6-12V <10ma
Out: DC 12V/50mA Max.
Power supplyAC 220V-240V 50/60Hz
Standby power consumption< 1W
Energy consumption250-300W
Max. power consumption< 1250W
Dimensions430 x x 518 x 201mm
Weight42.4kg
ColorSilver
Package1x Matrix MA-1 power amplifier
1x Trigger cable
1x Power supply cable
InputXLR
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)900.0
Power (W)450.0
The Matrix MA-1 power amplifier is part of the brand's M series, completed by the MS-1 streamer and MP-1 preamplifier. This new series...
