SINGXER SA-90 Mono Power Amplifier
The Singxer SA-90 class A/B mono power amplifier delivers ultra-low-noise, ultra-low-distortion performance while offering no less than 200W output power at 4 ohms. Like most power amplifiers on the market, it adopts a monoblock design with a simple, minimalist look.
Reference : 19750
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 27-05-2025.
Singxer SA-90 Mono Power Amplifier Class A/B 200W 4 ohm
SINGXER SA-90 picture
On the interface side, there's a balanced input on an XLR connector, as well as an RCA input with a GND terminal and, of course, a speaker terminal for the output. This amplifier also features audiophile components such as a toroidal transformer rated at 300W, 20,000uF electrolytic capacitors and no less than 4 low-noise discrete power supplies, as well as full speaker protection functions: power on/off, overtemperature, short circuit, overload and much more. A further feature is the ability to adjust its gain to two levels, 16dB or 23dB, enabling it to adapt to different input signals if required.
SINGXER SA-90 overview
1GND
2RCA input
3XLR output
4Input selection switch
5Speaker terminal block
5IEC power supply / Power switch
Product typePower amplifier
AmplificationA/B class
ChannelMono
Inputs1x Single-ended RCA
1x Balanced XLR
GND terminal
OutputSpeaker terminal
Max. output power200W @ 4 ohm (THD+N=1%)
120W @ 8 ohm (THD+N=1%)
Rated output power180W @ 4 ohm
90W @ 8 ohm
Noise level< 2.3uv (A-weighted, RCA input, Low gain)
SNR> 140dB (A-weighted, RCA input, Low gain)
THD+N-110dB (A-weighted, 20W, 8 ohm)
Gain adjustmentLow : 16dB
High : 23dB
Power supply115-230V AC
Dimensions216 x 320 x 80mm
Weight7.5kg
Package1x Mono power amplifier Singxer SA-90
1x Power supply cable
Mesure du SA-90
InputXLR
Channel1 (Mono)
ClassClass A / AB
Amplifier chipN/A
Power (W)200.0
SINGXER SA-90 Mono Power Amplifier Class A/B 200W 4 Ohm
The Singxer SA-90 class A/B mono power amplifier delivers ultra-low-noise, ultra-low-distortion performance while offering no less than 200W output...
