TONEWINNER AD-8300PA Power Amplifier Class AB 11 Channels 3x515W + 8x205W 4 Ohm
17%
Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a consistent power with low distortion for an immersive and dynamic sound reproduction. Coupled with an audio/video preamplifier (sold separately), the AD-8300PA is an excellent solution for entering the world of high-end home theater.
Reduced price!
Reference : 17407
Limited time offer:
1 790,00 €tax incl.
-17%
1 485,70 €tax incl.
1 238,08 € tax excl.
Shipping date: 03-07-2025.
Tonewinner AD-8300PA
Power Amplifier 11 Channels Class AB 3x515W + 8x205W 4 Ohm
Tonewinner AD-8300PA Amplificateur de puissance 11 canaux Class AB 3x515W + 8x205W 4Ω
Powerful 11-channel amplification
With the Tonewinner AD-8300PA you can enjoy an impressive amplification that is perfectly adjusted to the channels. Indeed, the left, right and center channels generally requiring more power, these operate at a higher current. They can thus deliver a power of 515W under 4Ω. As for the other 8 channels, they are not left out with a power of 205W under 4Ω.
Each channel benefits from an independent amplifier module - inspired by high-fidelity amplifier designs - and operates with high-power transistors providing 45A output current.
3000W Power supply
To provide such power, the AD-8300PA is equipped with a large 3000W switch mode power supply, which is capable of delivering high power requirements at any time. An essential basis to provide a dynamic and lively reproduction, adapting efficiently to the audio signal.
Balanced and single-ended connections
Simple and efficient, the connectivity of the Tonewinner AD-8300PA allows to connect a balanced or single-ended source. Indeed, each channel has an XLR (balanced) and RCA (single-ended) input connector. The output is made on speaker terminals accepting banana plugs. Moreover, for a practical integration, the amplifier is equipped with a 5V trigger input and output in Jack 3.5mm format. It is thus possible to automatically turn on and off the amplifier and its source thanks to a 5V signal.
1Right channel balanced input
2Right channel single-ended input
3Right back surround channel balanced input
4Right back surround channel single-ended input
5Right surround channel balanced input
6Right surround channel single-ended input
7Right top front channel balanced input
8Right top front channel single-ended input
9Right top rear channel balanced input
10Right top rear channel single-ended input
11Center channel balanced input
12Center channel single-ended input
13Left top rear channel balanced input
14Left top rear channel single-ended input
15Left top front channel balanced input
16Left top front channel single-ended input
17Left surround channel balanced input
18Left surround channel single-ended input
19Left back surround channel balanced input
20Left back surround channel single-ended input
21Left channel balanced input
22Left channel single-ended input
235V Trigger input
245V Trigger output
25Right channel output
26Right back surround channel output
27Right surround channel output
28Right top front channel output
29Right top rear channel output
30Center channel output
31Left top rear channel output
32Left top front channel output
33Left surround channel output
34Left back surround channel output
35Left channel output
36Power connector
Active cooling system
In order to promote good heat dissipation and therefore increased durability, the Tonewinner AD-8300PA integrates an active cooling system. Four fans are triggered when needed and adapt their speed according to the temperatures detected by the sensors of the device.
Protection circuit
In addition to this efficient cooling system and always with a view to durability and reliability, the amplifier embeds a complete protection circuit. It protects the AD-8300PA against short circuit, overload, overcurrent, overvoltage and overheating. If triggered, the short circuit, overvoltage and overcurrent protection can be reset with a button on the back of the unit.
Product typeAmplifier
Channels11
Inputs11* XLR
11* RCA
OutputsSpeaker terminals
Other connectors1* 5V Trigger input
1* 5V Trigger output
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, one powered channelL, C, R channels: 350W RMS
Other channels: 155W RMS
Output power @ 20Hz-20kHz, 4Ω, THD < 0.1%, one powered channelL, C, R channels: 605W RMS
Other channels: 276W RMS
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, two power channelsL, C, R channels: 320W RMS
Other channels: 150W RMS
Output power @ 20Hz-20kHz, 4Ω, THD < 0.1%, two powered channelsL, C, R channels: 516W RMS
Other channels: 207W RMS
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, all channels poweredL, C, R channels: 240W RMS
Other channels: 105W RMS
Gain29.3dB
Frequency response1Hz - 80kHz +0/-2dB
THD+N< 0.009% @ 100W RMS, 1kHz, 8Ω
SNR> 111dB @ 8Ω, single-ended, A-Weighted
Min. load impedance4Ω
Damping factor141 @ 8Ω
Supply voltage110-230V 50/60Hz
Dimensions450*460*210mm
Weight20.5kg
Package1* Tonewinner AD-8300PA
1* Power cable
InputXLR
OutputSpeaker terminal
Channel11
ClassClass A / AB
Amplifier chipTransistors
Power (W)515.0
Power (W)205.0
Order this item before 11:00 and the next day in my house before 12:00, that's very nice!
Big amp and a nice design. The first sound impressions were good sound! The package was also very good, box in a box in a box!!!
This review has been posted for TONEWINNER AD-8300PA Power Amplifier Class AB 11 Channels 3x515W + 8x205W 4 Ohm
Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a...
