j'ai un doute par rapport à la prétendue connaissance des personnes rajoutant un signe négatif sous chaque commentaire d'un produit furutech dont la qualité est indéniable, mais bon bref...
By buying this product you get 87 loyalty points
If you're a musician or recording studio professional, ask yourself this question: Does a Hifi power cord make sense?
The new Furutech Astoria power cords have been designed with the demanding professional in mind. Developed in Tokyo with many talented musicians and recording professionals, Astoria power cords have been specially optimized and balanced to deliver more punch and dynamics to your mixes and studio recordings.
In fact, choosing the Astoria Furutech power cord gives you even more control over the kind of sound you're trying to achieve. Choose Astoria if you're aiming for fast response and natural speed, coupled with deep, powerful bass.
Simply replace the existing power cords for your amplifiers, mixing consoles, mic preamps and even your entire recording system, and you'll immediately hear greater sound coherence across the entire bandwidth. Dynamic range will be greater than ever, music will sound effortless and expansive instead of flat, aggressive or undefined.
Furutech's legendary design team are experts at preserving the audio signal path, delivering a precise, honest and uncompromising end result.
The PC-Triple C (Alpha) power cable used on the Astoria is the result of an exclusive fusion process involving repeated cycles of metal bending, a Katana-inspired technique refined over centuries of Japanese swordsmanship.
This art-like technique uses high-purity, oxygen-free copper. This creates a forging process identical to that of folded steel from the art of the Katana, shaped tens of thousands of times.
This ensures that the joints between the crystal grains inside the copper are rearranged so that the electrical current moves through the signal path more smoothly than ever before.
Add Alpha-treated gold-plated connectors, flexible ROHS PVC sleeving and a patented floating grounding system, and you've got a high-precision tool for extracting the best from music in the studio and on stage.
Features :
Cable specifications :
Length (m) | 1.5 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | Schuko |
Connector | IEC C15 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Fabrice j.
Jerome B.
Jean-Luc B.
Jean-Luc B.
