LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 1m
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher than 99.997%).
3.5 / 5
Reference : 15077
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 04-07-2025.
Ludic Aesir
Ludic Aesir Câble d'Alimentation Schuko IEC C15 Cuivre UP-OCC plaqué Or 1m
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher than 99.997%). In addition, the copper undergoes a cryogenic treatment at a temperature of -196°C, which enhances the conductivity of the material. The cable benefits from a high density triple shielding based on cotton and chlorine-free PTFE to reject potential interferences as much as possible. The dielectric surrounding the conductors is injected with nitrogen gas for perfect signal integrity.
The contacts of the connectors are made of a Copper-Nickel alloy and covered with 24k Gold plating for excellent conductivity and durability. The body of the connectors is made of Carbon.
Product typePower cable
Connectors1x Schuko
1x IEC C15
Length1m
Conductors materialUP-OCC Drawn® Copper
ShieldingTriple, high density
DielectricNitrogen Gas Injection Dielectric (Nz)
Contacts plating (connectors)Gold 24k
Cable diameterØ16mm
External sheathPVC
Cover sheathNylon
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorIEC C15
ConnectorSchuko
2 reviews
Excellent rapport qualité prix
On en a réellement pour son argent d’abord pour la qualité de fabrication puis pour l’amélioration sonore. Tout reste équilibré en gagnant en silence. Grande douceur sans perdre en définition. Mention spéciale pour le grave complètement libéré mais sans lourdeur. Seul point négatif, câble très rigide. Ne pas hésiter à prendre une petite longueur supplémentaire. Ça aide. Comment d’habitude servie audiophonics au top
This review has been posted for LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 1m
a bit disappointed
it looks amazing, but when i connected to my electronics i was a bit disappointed. with my preamp pass labs xp12 or with my integrated amp vitus audio ri-101 the result was not so good ... it was clearly worste than other cables that i own (like Oyaide SSC, furutech, bcd). the sound was confused and muffled compared to the others power cables.
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity...
