PANGEA AC-14SE MKII Power cable triple shielding Cardas Copper / OFC 3x2mm² 2m
4.5 / 5
Reference : 10004
119,00 €tax incl.
99,17 € tax excl.
Extremely clean and noise-free power supply for source components.
Based on a mix of solid strands and litz wires, this cable is specifically designed for your audio sources.
The Pangea AC-14SE MKII cable is specially designed for source components that do not require the same power as the receivers and amps.
The AC-14SE MKII provides more current, while providing multiple shielding and other features that facilitate the extremely clean and noise-free power supply of your devices.
Pangea designed the AC-14SE MKII specifically for powering the "Audiophiles" source components.
It will improve the performance of preamps, CD players, DVD players, CEDs, and other line level components.
The new AC-14SE MKII SE is now equipped with a copper couple OFC Copper and Cardas Grade One Copper, developed specially by George Cardas for its own cables.
Thiscable has an OFC plated braided copper shield.
Theindependent insulation of each conductor ensures an unrivaled level of power quality in this price range.
The contacts of the AC-14SE MKII are plated 24k Gold for superior conductivity.
Characteristics :
  • Main Driver in CardasGrade One Copper
  • 6 strands of Copper OFC 99.999% surrounded by 6 threads of Litz
  • Copper foil plating Silver plated
  • Shielding against parasitic noise (EMI, RFI)
  • High flexibility
  • Gold plated contacts 24k
  • Total diameter: 12mm
  • Length: 2m
  • Weight: 565g
Length (m)2.0
ShieldingYes
Section (mm²)2.00
ConnectorSchuko
ConnectorIEC C13
Conductors material (Cable)Cardas Copper
2 reviews
Bon câble mais il semblerait que la phase soit inversée
J'ai branché ce câble sur mon alimentation séparée qui est reliée à mon DAC USB, le résultat était globalement bon en prise murale.
Cependant, je trouvais que la scène sonore était trop en hauteur et trop brillante, ce qui devenait fatigant. J’ai donc branché le câble sur mon onduleur
le son est devenu beaucoup plus équilibré et moins fatiguant brillant. Sur des forums français, on parle d’inversion de phase du câble ; je pense que le problème vient de là.
J’ai donc branché ce câble sur mon PC et gardé l’ancien câble non audiophile sur l’alim de mon DAC USB : le résultat est meilleur.
Peut‑être que le jour où je changerai la phase de ma prise murale, le résultat sera encore meilleur et ça supprimera cette brillance et scène sonore trop en hauteur.
This review has been posted for PANGEA AC-14SE MKII Power cable triple shielding Cardas Copper / OFC 3x2mm² 2m
Comment magnifier le son sans changer d'ampli.
J'ai acheté un combo DAC / AMPLI audio GD 11 38 Performance. Déjà la qualité d'écoute était exceptionnelles bien que les aigus un peu trop agressifs. En plus je l'ai équipé d'un câble USB Audiophonics Digital Audio qui q déjà considérablement améliorée rendu sonore. Là, je viens de recevoir le câble secteur PANGEA AC-14SE MKII. En fait j'étais toujours sceptique quant à son efficacité sur la qualité du son. Le résultat dés le remplacement du câble d'origine m'a laissé sur le c...Le DAC / AMPLI Audio GD a immédiatement adopté un son organique, les basses sont devenues plus profondes sans perdre de leur précision et les aigus ont pris une chaleur qu'ils avaient pas. Je vous garantis que ce câble secteur transforme votre écoute en bonheur béat pur. Livré dans les temps par Audiophonics dans sa boite rigide bien protégée.
 (3)
