IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 450F 5V
The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
Reference : 20410
159,00 €tax incl.
132,50 € tax excl.
Last items in stock !
Shipping date: 07-04-2026.
Ian Canada UcConditioner Pro Ultra Capacitor Conditioner Board 450F 5V
For audiophiles, upgrading a power supply with the UcConditioner Pro can be one of the best solutions for achieving much better sound quality.
Key features:
  • Fully ultra-low resistance MOSFET architecture.
  • Built-in automatic per-charge/charge circuits with current limitation.
  • Enable/disable conditioning is performed by monitoring ultra capacitors and DC input status.
  • All control logics are running automatically at background, no need any external control signal.
  • On-board active balancers for ultra capacitor protection.
  • LED indications for power on, power good, ultra capacitor full and conditioning.
  • Double thickness 2oz PCB copper layers especially designed for high current and ultra low ESR applications.
  • MOSFETs are controlled by optical isolators to eliminate any possible leakage current.
  • Output is 100% following the input without any delay.
  • With ON/OFF control signal output for possible requirement.
  • Works with any 5V power supply, plu and play, no software required.
Ian Canada UcConditioner PRO Conditionneur de Signaux à Supercondensateurs 5V
Technical characteristics
Product typeSignal conditionner
Input voltage5V
Output voltage5V
Dimensions (with capacitors)88 x 55.5 x 82mm
Mounting holes spacing58*49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower conditioner
The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve...
