AC/DC Switching Adapter 100-240V AC to 15V 3A DC
This switching adapter takes an input voltage of 100-240V AC 1.8A 50/60Hz to deliver an output voltage of 15V DC 3A. This power supply integrates several protections, such as overload, overvoltage, overheating, etc. The cable conductors are made of tinned copper to ensure good conductivity and durability. The input has an IEC C14 connector (male) and the output has a 5.5/2.5mm and 5.5/2.1mm compatible DC jack.
Only the power supply unit is supplied. Its use requires the addition of a cable to be purchased separately with mains plug (Schuko) to IEC C13.
| Specifications | |
| Input voltage | 100-240V 1.8A 50/60Hz |
| Output voltage | 15V 3A |
| Connectors | Male Jack DC - 5.5/2.5mm and 5.5/2.1mm compatible IEC C14 (male) |
| Cable conductor material | Tinned copper |
| Cable length | 1m |
| Power supply unit dimensions | 125 x 56 x 32mm |
| Weight | 220g |
| Color | Black |
