IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 12V 4A
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device with a clean and stable power supply.
4.8 / 5
Reference : 15101
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 09-05-2025.
iFi Audio iPower Elite
iFi Audio iPower Elite Adaptateur Secteur à Annulation de Bruit Active 5V 5A
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis:
  • A high-performance 60W adaptive multimode controller optimized for high efficiency, low standby power and noiseless design.
  • Frequency shuffling technique to achieve excellent performance against EMI interference.
  • 400% increase in the power supply capacity of the adaptive multimode controller.
  • Oversized power MOSFET.
  • Low leakage transformer.
  • Background noise less than 1µV.
  • Noise cancellation technology.
  • Aluminum frame with integrated heat sink.
Active Noise Cancellation 2
Active Noise Cancellation 2 technology actively suppresses incoming noise, using similar operation to noise-cancelling headphones. A signal identical to the incoming electrical noise is generated with an inverted phase, in order to perform this noise cancellation.
This method is particularly effective in eliminating noise in the low and medium frequencies, while passive filtering deals with interference in the high frequencies. This intelligent combination is more effective than simple passive filtering.
Product typeAC adapter
Input voltage100-240VAC (50-60Hz / 1.5A)
Output voltage / current12V DC 4A
Output connectorJack DC 5.5/2.1mm
Noise floor< 1µV
Dimensions148 x 55 x 50mm
Weight550g
Package1x iFi Audio iPower Elite
1x Reverse polarity Jack DC adapter
1x Power cable
Output voltage (V)12.0
5 reviews
Changé le son mais pas une amélioration pour moi.
J'ai utilisé cet iFi iPower Elite avec mon DAC exaSound e38 et cela a changé le son par rapport à l'alimentation à découpage fournie. Malheureusement, le changement n'a pas été une amélioration sur mon système, il a rendu le son très légèrement plus dur et a donné un peu moins d'air autour des instruments.
Après quelques jours, j'ai décidé de retirer l'iFi de mon système et de rester avec l'alimentation fournie par exaSound.
D'autres personnes pourraient trouver le changement de son de l'iFi bénéfique dans leur système, mais cela a fait pencher l'équilibre sonore de mon système vers un son légèrement trop dur et brillant.
This review has been posted for IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 12V 4A
Audible
Je n'écoute qu'en streaming, radios et Qobuz sur une paire de KEF LSX50W2, relièes par des RJ45 Audiophonics entre elle et à la Box via un simple switch Netgear. J'ai pris cette alim qui est plus petite que je pensais, et elle n'est pas moche, dans le but de la mettre sur ma Box Orange sur laquelle j'avais déjà une alimentation IFI AUDIO IPOWER X.
J'ai fait un premier essai en mettant cette alim sur mon switch internet en laissant la IPOWER X sur la box. Le résultat n'était pas satisfaisant, manque de présence avec un voile. J'ai interverti les 2 alimentation et là... C'est bluffant, une transparence, une présence, une netteté...c'est incroyable...et je ne suis pas du tout un audiophile pointu, mes oreilles ont plus de 60 ans. J'avais déjà optimisé mon installation avec une multiprise Audiophonics et des cables RJ45 Audiophonics, et là je suis comblé, je suis persuadé que ma petite chaine est au maximum de ses capacités et le résultat est magnifique, sur des sources correctement enregistrées en Flac.
 (3)
Suite critique.
Choisis er un cable secteur privilégiant une large bande passante. Neoteque cu pl argent ou oayde up occ tsunami. Perso tu ami. Me restait un mettre. Monté en Viborg cu pl argent. Coût des deux prise schuko et iec moins de 60fr ch. Aération et dynamique encore mieux. Avec une spacialisation stéréo 3d encore plus marquée. N esiter pas à essayer diff config. À bonne entendeur
Steamer zen ifi
Exelente alimentation. Pour mon steamer zen. Aucun bruit. Silence superbe. Naturel dynamique incroyable. Certe PS donnée. Mais une fois essayée vous pourrez plus vous en passer. J ai fait un essais sur ma box tv upc et même le modem. Si j était bien argente
Very effective
I have owned IFI power products before, and this one is very impressive. Well-built and seems highly effective in reducing electromagnetic noise and thereby improving the performance of what its powering
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device...
