bonjour ; fonctionnement correcte , mais tassement de dynamique et quelque peu bruyant ...!
This volume control module includes an encoder, a display and an IR remote control. This GLA-RCA module features a low-distortion chip (0.0015%) and a 4.2Vrms output level. Sound level is controlled over a wide range from -97dB to 0dB by potentiometer, with a volume memory function. The display shows values from 0 to 95, with one step representing 1dB. The module's supply voltage is +/-12V. DC. This module is ideal for any DIY project requiring volume control.
The encoder features a potentiometer, resistors and an NJW1194 chip. The NJW1194 is a low-noise, low-distortion 2-channel volume control chip. A 78M05 voltage regulator and STCW204S microcontroller are also integrated.
On the display side, there's of course an LED screen, but also an indication LED with IR receiver. All this is supported by a 16-channel JXI5020 LED microcontroller.
A small infrared remote control allows you to control sound level and the mute function from a distance. Very practical, it eliminates the need to move around and systematically use the potentiometer to access the volume control.
1 | Signal output 3-pin PH 2.0 connector |
2 | Signal input 3-pin PH 2.0 connector |
3 | Power supply +/-12V 3-pin PH 2.0 connector |
4 | Soldering pad for additional 3-pin PH2.0 connector |
5 | Encoder/display module connector |
6 | Display/encoder module connector |
7 | Display LED |
8 | LED indicator/IR receiver |
Product type | Volume control module |
Input | 1x Signal input on 3-pin PH 2.0 connector |
Output | 1x Signal output on 3-pin PH 2.0 connector |
Volume control range | -97dB to 0dB |
Input impedance | 20KOhm |
Distortion level | 0.0015% |
Channel separation | 120dB |
Output noise level | 1.4µV |
Output level | 4.2Vrms |
Remote control |
Power supply | +/-12V DC |
Dimensions | Encoder: 39 x 42mm Display: 48 x 25mm (Spacing holes: 40x20mm / Holes diameter : 3mm) |
Package | 1x Volume control module (encoder and display) 1x IR remote control 3x 3-pin PH 2.0 connector cable to bare wires |
Average votes 2.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
