By buying this product you get 149 loyalty points
Design your own high-end preamplifier with this DIY Hypex DIYclassD DIY PreAmplifier kit. Thanks to the easy-to-follow instructions, you'll be able to build a high-end preamplifier cost-effectively, and in just 30 to 60 minutes. Combined with a Hypex Nilai Class D amplifier (sold separately) like the Nilai500DIY, you can create a complete package delivering incredible sound quality.
Key features:
Required tools:
Product type | DIY preamplifier kit |
Inputs | 1x Balanced stereo XLR 2x Single-ended stereo RCA |
Outputs | 2x Balanced stereo XLR 1x Balanced XLR 4 pins headphone output 1x Single-ended Jack 3.5mm headphone output |
Input level | 14.45dBu (4Vrms) |
Output level | 14.45dBu (4Vrms) |
Headphone output level | 19dBu (7Vrms) |
Input impedance | 100kΩ |
Output impedance | 44Ω |
Headphone output impedance | < 0.5Ω |
Noise | 3µV (No-wt, unitary gain) |
Headphone output noise | 7.5µV (No-wt, unitary gain) |
SNR | 122dB |
Gain range | -70dB / +13dB |
THD | -140dB à 1kHz, 4Vrms in, 0dB |
Supply voltage | 90-135VAC / 180-270VAC (auto switch) |
Consumption | 10W |
Standby consumption | < 0.5W |
Dimensions | 417 x 340 x 77mm |
Weight | 4kg |
Package | 1x DIY preamplifier case 1x Main board 1x Front board 1x Headphone board 1x Power supply board All necessary wiring, connectors and mounting hardware Mounting guide 1x TX-10 / TX-20 and 1.5mm hex key 1x Remote control |
