AIYIMA T20 Tube Balanced Preamplifier
New
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of tube amplification. For further convenience, the T20 incorporates two 12V trigger outputs, allowing for seamless integration into your audio system while protecting the tubes.
Reference : 21019
165,00 €tax incl.
137,50 € tax excl.
Aiyima T20 Tube Balanced Preamplifier 2xECC83
Aiyima T20 : Front view
One trigger is dedicated to turning on the DAC, while the other turns on the amplifier. This protects the tubes and allows them to warm up before processing the audio signal.
Aiyima T20: Twin ECC83 tube
The T20's amplification stage relies on two ECC83 tubes. These are combined with pre-amplification by LME49720 and OPA1612 chips, mounted to take full advantage of the character of the ECC83 tubes and provide them with a 180V signal. Furthermore, the T20 offers sound customisation through the use of interchangeable tubes such as 12AX7-S, 12AX7B, 7025 or 12AX7, depending on listening preferences.
Aiyima T20 : OPA
Aiyima T20 : Aluminum chassis
Aiyima T20: A sleek design
The T20's aesthetic is both sober and elegant: a large, minimalist volume display makes it easy to read the settings, while the CNC-machined aluminium casing ensures a neat finish, good heat dissipation and a visually striking appearance.
Aiyima T20 Overview
Aiyima T20 : Overview
1Infrared receiver
2Input mode indicator light
3Display
4ON / OFF / Volume control
52x Trigger output
612V DC power socket
7Stereo XLR output
8Stereo RCA output
9Stereo RCA input
10Stereo XLR input
Product typePréamplificateur
Supplied tubes2x ECC83
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
OPA3x LME49720
2x OPA1612
Noise20µV
Signal-to-noise ratio (SNR)≥ 112dB
Dynamic range109dB
Total harmonic distortion more noise (THD+N)0.003%
Frequency response20Hz-20kHz (±0.2dB)
Compatible tubesECC83
12AX7-S
12AX7B
7025
12AX7
Power supply12V DC
Dimensions90 x 142 x 46mm
Weight1015g
Package1x Aiyima T20
1x Remote control
2x ECC83 tubes
1x AC adapter to DC jack
Aiyima T20 : Measurements
InputXLR
ClassTube amp
Remote ControlYes
Interesting concept
Unique concept of balanced tube amp - fully balanced signal path. Only so so on revealing system with stock tubes and opamps but improved with v7 classic and ps vase art series - the impact is pretty serious. Also good power supply needed to support the product express his performances
This review has been posted for AIYIMA T20 Tube Balanced Preamplifier 2xECC83
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the...
