DENAFRIPS ATHENA 15TH Preamplifier Silver
Embark on an unprecedented audio journey with the Denafrips Athena 15TH discrete balanced preamplifier, the pinnacle of sonic sophistication and performance. Designed and built with uncompromising dedication, the Denafrips Athena embodies a true feat of audio innovation and craftsmanship. Built to exacting standards, this incredible model sets a new benchmark in performance, revealing incredible precision and musicality.
By buying this product you get 259 loyalty points
Reference : 21340
2 599,00 €tax incl.
2 165,83 € tax excl.
Denafrips Athena 15TH Discrete Balanced Preamplifier Pure Class A Silver
Denafrips Athena 15th : Front view
The Denafrips Athena 15TH benefits from a fully symmetrical, pure Class A architecture of the highest quality. The entire unit uses high-end electronics, including a 60-step relay attenuator to keep crosstalk to a minimum, with precisely matched resistors ensuring perfect channel balance and extremely low distortion. The result is a rich, pure sound.
All Athena components are housed in a sturdy, modern aluminum chassis. It also features a front-panel display to show the selected volume level. All functions can be accessed remotely via the associated remote control.
Points clés :
  • Pure class A. True balanced, discrete, high-quality line stage
  • Microprocessor-controlled 60-step relay volume attenuator
  • High-precision resistors and components throughout with perfect channel balance and low distortion
  • Remote control
Denafrips Athena 15TH overview
Denafrips Athena 15Th : Connectique
1 / 3Balanced XLR inputs
2Single-ended RCA input
4Unbalanced RCA output
5Balanced XLR output
6Trigger input
7Trigger output
8Power connector
Product typeDiscrete balanced preamplifier
ArchitecturePure class A
AttenuatorMicroprocessor-controlled 60-step relay attenuator
Inputs4x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Input impedanceSingle-ended: 12.2kΩ
Balanced: 60kΩ
Output levelRCA: 2Vrms
XLR: 4Vrms
Output impedanceSingle-ended: 200Ω
Balanced: 400Ω
GainUnity gain, 0dB
Frequency response10Hz - 85kHz (-0.3dB)
THD+N0.00012%
SNR127dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
Consumption25W
1W idle
ColorSilver
Dimensions433 x 385 x 110mm
Weight18kg
Package1x Denafrips Athena 15TH
1x Remote control
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
DENAFRIPS ATHENA 15TH Discrete Balanced Preamplifier Pure Class A Silver
Embark on an unprecedented audio journey with the Denafrips Athena 15TH discrete balanced preamplifier, the pinnacle of sonic sophistication and...
