By buying this product you get 56 loyalty points
The FangSound Silenos is a small, versatile device that acts as a DAC, headphone amplifier, and preamplifier. Its digital-to-analog conversion stage consists of an R2R network of 192 complementary resistors to achieve clean rendering with sampling rates up to PCM 32bit 768kHz. Its amplification circuit is based on a balanced architecture that delivers high headphone amplification power while maintaining a pure signal. It is capable of delivering up to 14W into 32Ω of output power, allowing it to drive a wide range of headphones and IEMs available on the market, including some with high impedance or planar magnetic technology. The unit is powered by a dual GaN switching power supply with up to 100W of power. In terms of connectivity, the FangSound Silenos is not to be outdone and will suit many Hi-Fi configurations, while its extremely compact form factor makes it an ideal desktop device.
The FangSound Silenos incorporates a discrete complementary network of 192 resistors to improve signal processing performance and produce an analog-like sound that is appreciated by many users. It supports up to 32-bit 768kHz PCM and includes internal oversampling for more detailed and accurate sound reproduction.
The Silenos' balanced headphone outputs are capable of delivering up to 14W + 14W of output power. This makes it a perfect match for high-impedance and/or low-sensitivity dynamic headphones or IEMs, as well as difficult-to-drive planar magnetic headphones.
The GaN (gallium nitride) switching power supply delivers up to 100W of power and offers high efficiency, low EMI noise, and fast response. In other words, it provides reliable and stable power without noise interference, even under high loads.
| 1 | Power indicator |
| 2 | Volume control potentiometer |
| 3 | DAC indicator |
| 4 | 4-pin XLR headphone output |
| 5 | Balanced 4.4mm headphone jack output |
| 6 | Single-ended 3.5mm headphone jack output |
| 7 | Single-ended 6.35mm headphone jack output |
| 8 | Balanced XLR input |
| 9 | Gain adjustment (L/H) |
| 10 | Power switch |
| 11 | USB-C input |
| 12 | 100-240V AC power port |
| 13 | Preamplified 4.4mm stereo jack output |
Please note that when using the analog XLR input, ensure that the USB-C digital input is disconnected so that the Silenos can produce sound.
In addition, the 4.4mm preamplified output jack supports connection to XLR and RCA with active speakers or a power amplifier using a suitable adapter or cable.
| Specifications | |
| Product type | DAC Preamplifier Headphone amplifier |
| DAC | R2R |
| Inputs | 1x USB-C 1x Balanced XLR |
| Outputs | 1x 3.5mm single-ended headphone jack output 1x 6.35mm single-ended headphone jack output 1x 4.4mm balanced headphone jack output 1x 4-pin balanced XLR headphone output 1x 4.4mm stereo preamplified jack output |
| Headphone amplification/preamplification specifications | |
| Output power | 14W @ 32 ohms, 1W @ 600 ohms (10% THD+N, 1kHz) 11W @ 32 ohms, 0.6W @ 600 ohms (1% THD+N, 1kHz) |
| Output voltage | 25Vrms / 70Vpp (10% THD+N, 1kHz) 19Vrms / 54Vpp (1% THD+N, 1kHz) |
| Amplification type | Class AB |
| Dynamic range | 106dB |
| SNR | 106dB |
| THD+N | 0.002% (@ 16Vrms, 1kHz) |
| Gain settings | 2 Level : High and Low |
| R2R DAC section specifications | |
| Supported sample rates | PCM up to 32bit 768kHz |
| Architecture | Complementary R2R with oversampling support |
| Output voltage | 4Vrms |
| Dynamic range | 84dB |
| SNR | 84dB |
| THD+N | < 0.1% |
| General | |
| Power supply type | Dual GaN switching, up to 100W |
| Power supply voltage | 100-240V AC |
| Dimensions | 16 x 18 x 4.5cm |
| Weight | 1.1kg |
| Package | 1x FengSound Silenos 1x USB-C cable 1x USB-A to USB-C cable 1x AC power cable |
| Input | USB |
| Input | XLR |
| Output | Jack 3.5mm |
| Output | Jack 6.35mm |
| Output | XLR |
| Output | Jack 4.4mm |
| DAC / ADC Chip | R2R LADDER DAC |
| Color | Gray |
| Color | Brown |
| Class | Class A / AB |
| Networking | No |
| Remote Control | No |
