FOSI AUDIO ZP3 Balanced Preamplifier
New
The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The ZP3 is ideally suited to audiophile and professional use, given its performance and connectivity, including TRS/XLR combo jack inputs and a balanced XLR output.
By buying this product you get 23 loyalty points
Reference : 20776
239,00 €tax incl.
199,17 € tax excl.
Fosi Audio ZP3 Balanced Preamplifier NE5532
Fosi Audio ZP3 picture
The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The ZP3 is ideally suited to audiophile and professional use, given its performance and connectivity, including TRS/XLR combo jack inputs and a balanced XLR output. In addition, there are controls for low and high tones and channel balance, for tailor-made rendering. Three additional features are also available. These include a subwoofer output (20Hz-200Hz) for installation of a 2.1-channel system, as well as an XLR/RCA frequency crossover switch (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz) and a bypass mode switch. All in all, the ZP3's performance and functionality make it the preamplifier of choice.
More information on the Fosi Audio ZP3
ZP3 overview
Fosi Audio ZP3 overview
1Power / Input selection
2Input indicator
3Channel balance adjustment
4Bass control
5Treble adjustment
6Volume control
72x RCA input
8Balanced TRS/XLR combo jack input
9RCA output
10SUB output
11XLR output
12Trigger IN/OUT
13Switching on / IEC power supply
14Bypass switch
15RCA/XLR frequency cut-off switch
Product typePreamplifier
AOPNE5532
Inputs2x Single-ended stereo RCA
1x Balanced Jack TRS/XLR combo
Outputs1x Single-ended stereo RCA (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz)
1x Balanced stereo XLR (20Hz-20kHz / 80Hz-20kHz / 120Hz-20kHz)
1x Subwoofer output (RCA) (20Hz-200Hz)
XLR balanced output specifications
SNR≥ 112dB
Dynamic range≥ 112dB
THD+N≤ 0.0007%
Noise floor≤ 6uV
RCA output specifications
SNR≥ 115dB
Dynamic range≥ 115dB
THD+N≤ 0.0008%
Noise floor≤ 4uV
Power supplyAC 100-240V
Package1x Fosi Audio ZP3 preamplifier
1x IR remote control
1x 12V trigger cable
1x Mains power cable
InputJack 6.35mm
InputXLR
OutputSubwoofer
ClassN/A
Remote ControlYes
une vraie montée en gamme par rapport au P4
Après avoir utilisé le Fosi Audio P4 pendant plusieurs mois, j’étais curieux de découvrir ce que le nouveau ZP3 avait à offrir. Clairement pensé comme une évolution directe du P4, ce nouveau modèle apporte des améliorations sensibles à tous les niveaux.
Qualité sonore : plus de définition, plus de dynamique
Le ZP3 reprend l’approche du P4 avec ses AOP interchangeables, mais va plus loin en termes de transparence et de scène sonore. Le grave est mieux tenu, les médiums plus ouverts et les aigus plus ciselés sans devenir fatigants. On gagne en précision et en séparation des instruments, ce qui donne une écoute plus "hifi" que le P4, qui restait un peu rond ou doux selon les configurations.
Construction et design : plus sérieux
Là où le P4 semblait presque "jouet" dans sa finition, le ZP3 respire davantage la qualité. Châssis plus solide, meilleurs connecteurs, et une alimentation plus sérieuse permettent de tirer le meilleur de ses composants internes. C’est un vrai plus si vous l’intégrez dans un système audiophile.
Fonctionnalités : toujours aussi modulable
Comme le P4, le ZP3 permet le remplacement des AOP (op-amps), ce qui est un vrai bonheur pour les tweakeurs. Il est livré avec de très bons AOP d’origine (souvent des NE5532 ou dérivés), mais il prend une toute autre dimension avec des modèles comme les OPA627 ou Sparkos SS3602. De plus, il accepte sans problème des sources variées grâce à sa large plage de gain et ses entrées bien pensées.
Le Fosi Audio ZP3 est clairement une montée en gamme logique et réussie. Il conserve l’esprit DIY et audiophile du P4, mais avec un raffinement et une maturité sonore que le P4 n’atteignait pas. Si vous avez aimé le P4, vous allez adorer le ZP3. Et si vous hésitez entre les deux, le ZP3 justifie largement son tarif légèrement supérieur par une restitution bien plus maîtrisée et audiophile.
This review has been posted for FOSI AUDIO ZP3 Balanced Preamplifier NE5532
The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range,...
