Préamplificateur à Tubes 2x 61N Bluetooth 5.0 aptX LL USB 24bit 192kHz
This Suca Audio Tube-T5C tube preamplifier is compact, affordable and efficient. It embeds two 61N tubes, allowing it to reveal a musical and round sound reproduction. The Tube-T5C is equipped with modern connectivity, including USB-B and Bluetooth 5.0 reception, in addition to RCA, making it possible to connect the Tube-T5C to a computer or to broadcast your music wirelessly from a smartphone or a tablet for example. The USB input uses a CM4462 interface, the Bluetooth reception a Qualcomm QCC3008 chip. On the output side, we find stereo RCA but also a 3.5mm headphone output on the front. Moreover, for greater versatility, the Tube-T5C has a tone control that allows you to adjust the level of bass and treble depending on your listening style and your audio system.
Product type | Tube preamplifier |
Tubes | 2*6N1 |
Inputs | Bluetooth 5.0 USB-B 1x Stereo RCA |
Outputs | 1x Stereo RCA 1x Jack 6.35mm headphone output |
Frequency response | 20Hz-20kHz (±3dB) |
Bluetooth chip | QCC3008 |
USB Interface | CM4462 |
OPA | NE5532P |
SNR | ≥ 110dB |
THD | 0.02% |
Supported samplinbg rates (USB) | PCM jusqu'à 24bit 192kHz |
Recommended headphone impedance | 16-300Ω |
Headphone output power | 150mW @ 32Ω |
Input sensitivity | 0.775V |
RCA output level | 1.4Vrms |
Bass/treble gain setting | ±6dB |
Geenral | |
Dimensions | 133*128*33mm |
Weight | 480g |
Color | Black |
Input | RCA |
Input | USB |
Input | Bluetooth |
Output | RCA |
Output | Jack 6.35mm |
Color | Black |
Class | Tube amp |
Remote Control | No |
