By buying this product you get 22 loyalty points
We propose a product pack consisting of a Fosi Audio SK02 headphone preamplifier and a Meze 99 Neo headphones. This combo lets you enjoy quality headphone listening at an affordable price.
Fosi Audio's SK02 is a versatile headphone amplifier that can also be used as a portable preamplifier. It is also equipped with an ES9038Q2M DAC chip, enabling it to support high-resolution streams up to PCM 32bit 384kHz and DSD256. An SGM8262 amplifier chip provides output power of up to 1000mW. Thanks to its gain control, it can drive headphones with impedances ranging from 16 ohms to 300 ohms. As for inputs, the SK02 features USB-C and Toslink optical connectivity. Outputs include two balanced jack 3.5mm and jack 4.4mm headphone outputs, plus an auxiliary jack 3.5mm/mini-Toslink output for connection to an amplifier.
View complete product page of FOSI AUDIO SK02The Audio Meze 99 NEO are closed-circumaural headphones with a 26-ohm impedance and a sensitivity of 103dB, making them easy to use. They feature dynamic transducers no less than Ø40mm in diameter, with a balanced response curve from 15Hz to 25kHz, for a sound reproduction that's both warm and extremely precise. These headphones feature a robust design with silicone suspension and noble mechanical parts in steel, zinc and manganese alloys. The headphones' double-arm system, ABS shells and weight of just 260g ensure long, fatigue-free listening.
View complete product page of Meze 99 NeoTechnical characteristics
Products type | Headphone Amplifier + Headphones |
Package contents | 1x Fosi Audio SK02 1x Meze 99 Neo |
FOSI AUDIO SK02 SPECIFICATIONS | |
Product type | Headphone amplifier / Potable Preamplifier / Portable DAC |
DAC chip | ES9038Q2M |
Amplification chip | SGM8262 |
Inputs | 1x USB-C input 1x Optical Toslink input |
Outputs | 1x 3.5mm jack headphone output 1x 4.4mm balanced jack headphone output 1x AUX jack 3.5mm/mini-Toslink output |
Supported sampling rates | USB: PCM 32bit 384kHz, native DSD up to DSD256 Toslink optical: PCM 24bit 192kHz |
Gain adjustment | |
Headphone output power | 3.5mm headphone output: 90mW @ 32Ω (Low gain) / 280mW @32Ω (High gain) Balanced 4.4mm headphone output: 350mW @ 32Ω (Low gain) / 1100mW @32Ω (High gain) |
Recommended headphone impedance | 16Ω-300Ω |
Frequency response | 20Hz-20kHz (+/-0.02dB) |
SNR | 3.5mm jack headphone output: 110dB (Low gain) / 116dB (High gain) Balanced 4.4mm jack headphone output: 102dB (Low gain) / 113dB (High gain) |
THD | > 0.001% |
Noise level | 3.5mm jack headphone output: 6.2uV Balanced 4.4mm headphone output: 13uV |
Crosstalk | 3.5mm jack headphone output: 110dB (Low gain) / 118dB (High gain) Balanced 4.4mm headphone output: 103dB (Low gain) / 104dB (High gain) |
Power supply | 5V DC via USB-C |
Dimensions | 121 x 51x 43mm |
Weight | Approx. 300g |
Color | Black |
Package | 1x Fosi Audio SK02 portable DAC headphone amplifier 1x USB-A/C to USB-C cable |
MEZE 99 NEO SPECIFICATIONS | |
Product type | Headphones |
Headphone type | Closed |
Coupling | Circumaural |
Drivers type | Dynamic |
Drivers diameter | Ø40mm |
Earpads | Medium density shape memory foam, leatherette covered |
Self-adjusting headband | |
Arceau | Steel, zinc and manganese alloy |
Hulls | Plastic |
Assembly | Without glue, only with screws |
Frequency response | 15Hz - 25kHz |
Sensitivity | 103dB @ 1kHz, 1mW |
Impedance | 26 Ohm |
Power handling | RMS : 30mW Max : 50mW |
Cable conductors | OFC Copper |
Cable sheath | Kevlar reinforced |
Cable connectors | Gold plated Jack 3.5mm |
Dimensions | 170 x 205 x 85mm |
Weight | 260g |
Color | Black |
Package | 1x Meze 99 Neo headphone 1x Carrying case 1x Accessory pouch 1x Cable 1x Telephone cable with microphone 1.2m 1x Jack 3.5 to Jack 6.35mm adapter |
