Pack Tonewinner AV Processor 16 Channels AT-300 + Power Amplifier 11 Channels AD-8300PA
This Tonewinner package includes the AT-300 audio/video processor and home theater preamplifier, plus the AD-8300PA power amplifier. The result is an extremely powerful, high-performance home-cinema system. What's more, both devices feature a unique design for aesthetic integration into your audio system.
By buying this product you get 249 loyalty points
Reference : 18260
2 490,00 €tax incl.
2 075,00 € tax excl.
Instead of 3 039,00 €
Pack content
Tonewinner AT-300 + AD-8300PA Pack
AV Processor 16 Channels AT-300 + Power Amplifier 11 Channels AD-8300PAPack Tonewinner AV Processor 16 Channels AT-300 + Power Amplifier 11 Channels AD-8300PA
Tonewinner AT-300 AV processor / home theater preamplifier
The Tonewinner AT-300 is a 16-channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz, and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AT-300
Tonewinner AD-8300PA 7-channel power amplifier
Tonewinner AD-8300PA 11-channel power amplifier
Tonewinner presents its AD-8300PA, an 11-channel power amplifier for home-cinema integration, including Dolby Atmos. What's more, it delivers substantial power with low distortion for immersive, dynamic sound reproduction. Coupled with an audio/video preamplifier (sold separately), the AD-8300PA represents an excellent solution for entering the world of high-end home-cinema.
FIND OUT MORE ABOUT THE TONEWINNER AD-8300PA
Product typeA/V processor + power amplifier
Tonewinner AT-300 specifications
Home theater preamplifier
Channels16 channels
InputsBluetooth
6* HDMI 2.0
4* Stereo RCA
2* Coaxial
2* Optical Tolsink
1* Slot Micro SD
1* Mini USB (USB Audio)
1* USB-A (USB Host)
OutputsBluetooth
2* HDMI 2.0 (with 1 eARC)
RCA 9.3.4 channels
XLR 9.1.4
Other connectors1* RS232
1* 5V trigger output
Supported audio formatsDolby Atmos
Dolby True HD
Dolby Digital Plus
DTS/X
DTS Master
DTS Hi-Res
DTS Upmix
DTX Neural:X
Supported video formats / resolutions4K UHD
3D
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.2
eARC supportOn one output
CEC supportOn 5 inputs
Automatic EQ calibration
Lip syncUp to 1000ms
DRC feature
Input impedance20kOhm
Output impedance1kOhm
Gain>= 14dB
THD<= 0.02% (1kHz)
SNR>= 98dB (A-wt)
Frequency response10Hz-50kHz (+1/-3dB)
Channel separation>= 80dB
Crosstalk>= 80dB
Supply voltage100-240VAC 50/60Hz
Dimensions431*326*100mm
Weight4.4kg
Tonewinner AD-8300PA speCifications
Product typePower amplifier
Amplification typeClass AB
Channels11
Inputs11* XLR
11* RCA
OutputsSpeaker terminals
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, one channel drivenL, C, R channels: 350W RMS
Other channels: 155W RMS
Output power @ 20Hz-20kHz, 4Ω, THD < 0.1%, one channel drivenL, C, R channels: 605W RMS
Other channels276W RMS
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, two channels drivenL, C, R channels: 320W RMS
Other channels150W RMS
Output power @ 20Hz-20kHz, 4Ω, THD < 0.1%, two channels drivenL, C, R channels: 516W RMS
Other channels207W RMS
Output power @ 20Hz-20kHz, 8Ω, THD < 0.1%, all channels drivenL, C, R channels: 240W RMS
Other channels105W RMS
SNR>= 111dB
THD+N< 0.009%
Frequency response1Hz-80kHz (+0/-2dB)
Gain29.3dB
Damping factor141 @ 8 Ohm
Supply voltage110-230VAC 50/60Hz
Dimensions450*460*210mm
Weight20.5kg
InputMicro SD
InputHDMI
InputXLR
OutputBluetooth
OutputHDMI
OutputHDMI eARC
Channel11
ClassClass A / AB
Amplifier chipTransistors
Power (W)275.0
Power (W)105.0
Power (W)515.0
Power (W)150.0
Power (W)240.0
Power (W)600.0
Power (W)350.0
Power (W)320.0
Power (W)200.0
Remote ControlYes
This Tonewinner package includes the AT-300 audio/video processor and home theater preamplifier, plus the AD-8300PA power amplifier. The result is...
