Cedric J.
Surprenant
Sur un ampli purement symetrique, cet adaptateur confère une sonorite qui semble souffrir d' aucune perte si ce n'...
Régis C.
C'est la classe (D) cet ampli
Première expérience en classe D et je dois dire que je ne m'attendais pas à ça.
Après un excellent Rotel RB 1582 MKII qui...
bernard g.
cablage xlr
des connecteur de bonne facture pour faire des trés bon cable
monté en gamme pour les connecteurs eizz pour faire un cable...
AUDIOPHONICS LPA-S450ET Class D Stereo Amplifier PURIFI 1ET6525SA 2x450W 4 Ohm - reviews - There are 19 reviews.
David H.
Very impressed!
More out of curiosity about how far Class D quality had progressed, I decided to buy this amplifier, complementing an old-school tube and Nakamichi 420 power amps. Fortunately, since I specifically desired a European solution, the combination of Purifi hardware integrated into an Audiophonics chassis was the perfect opportunity for me. Examining the internal components and wiring shows excellent workmanship, putting the narrow chassis to effective use. I was very impressed with the dynamics and definition of the few CD‘s that I listened to for preliminary testing. I had combined this purchase with replacement Mundorf capacitors for my 30 year old B&W speaker crossovers, which I had also immediately installed, so I need to become accustomed to the sound to make a long term evaluation. Since I love to tweek my components from time to time(AFTER the warranty elapses), this amplifier allows the possibility to test alternative op-amps, and for the more adventurous, maybe replace the 15 volt voltage regulators on the interface board with Sparkos regulators.
The order and delivery process to Germany, basically next door, was quick and simple and I will continue to visit their website should I need any parts or accessories in the future.
Philippe S.
En avoir beaucoup pour son argent !
Je possède une belle installation hifi/Home cinéma avec un super ampli en classe A qui coûte aussi cher qu'il est lourd, si je lui donne un 9 sur 10 et bien je dois donner un 7,5 sur 10 au purifi 450, c'est aéré, doux dans les aigus, ferme dans les graves et bien présent dans le médium.
Le son est un peu moins dynamique, un peu moins de présence, un peu moins de modulation...... mais le purifi coûte 15 fois moins cher !!!!!
P.S : il aussi beaucoup moins lourd et bien moins encombrant.
Je suis très satisfait de mon achat.
ERIC C.
Magique !!!
Acheté à la mi-décembre en remplacement de 2 Nuprime STA-9 que j'utilisais en mode ponté mono, la magie a opérée dès les premières notes, connaissant déjà la classe D je ne m'attendais pas à une telle différence entre ces 2 générations d'ampli en classe D, déjà niveau poids 2 kg de moins sur la balance, la qualité des borniers carbone donne le ton, très imposants et surtout acceptant du câble de très grosse section, la finition est irréprochable le pied central avant déroute au début mais c'est très stable, les multiples réglages pour la sensibilité de sortie par le biais de petits switchs permet de caler correctement l'ampli au pré-ampli niveau volume
ERIC C.
Agréable découverte
Je connais déjà les amplis classe D avec le Nuprime STA-9 pour leurs qualités et puissances, j'en avais 4 que j'ai revendu pour pour changer et passer chez Audiophonics et le Purifi et je dois reconnaitre que je suis ravis
Eric E.
Remarquable !
La neutralité et la transparence sautent tout de suite aux oreilles. Le son est limpide et détaillé, les plans sonores sont parfaitement lisibles, tout le spectre est net, précis, exact. L’écoute prolongée n’entraîne aucune fatigue, au contraire le naturel et l’aisance sont vraiment reposants.
Mon LPA-S450ET pilote des Infinity Quantum 3, des mamies d’efficacité modérée réputées difficiles avec leurs boomers à double bobine travaillant à 2,5 ohms… mes mamies sont toutes ragaillardies et n’ont jamais si bien sonné. En fin de journée l’ampli est tiède, mesuré à 34° dans une pièce à 25°. J’ai poussé le volume au delà du raisonnable pour tester la tenue des basses, aucune défaillance audible.
Je retrouve avec cette classe D convaincante ce que j’ai connu avec une voiture électrique, quelques heures ont suffi pour enterrer définitivement le passé. L’expérience est si positive qu’à la fin de l’année je monterai en gamme.
 (3)
Laurent G.
Petit mais super efficace !!
Je viens d'un Sugden pure classe A, je peux affirmer que cet ampli n'est absolument pas froid, bien au contraire, les basses sont bien présentes, très définies et tout le spectre est bien mis en valeur. Le plus remarquable est sa transparence, Il alimente mes focal 948 avec aisance, fluidité et subtilité et s'efface pour transmettre le meilleur de mon pré ampli eversolo A8 (branchement XLR). Une véritable réussite à son prix.
Thierry S.
Vraiment bien
Merci David, pour votre patience , et , disponibilité, je craignais que ce petit ampli ne fasse pas le poids, en kilo c est certain, face à mon Classé Audio, et bien, il est costaud le petit, le son est vraiment très bon, le conseil était fort avisé.
Jean-François L.
Superbe choix
Le challenge n'était pas gagné d'avance : Alimenter mes Martin Logan Sequel II.
Après de nombreuses recherches sur les amplis adaptés, l'intelligence artificielle a attiré mon attention sur les amplis de classe D et notamment sur Hypex et Purifi.
Audiophonics m'a été d'excellent conseil dans le choix de celui-ci.
Je l'ai associé au préamplificateur MUSES72320 pour gérer facilement mes sources.
En plus, la livraison a été rapide et efficace.
Le résultat est exceptionnel quel que soit le volume d'écoute.
Merci à vous
PATRICE R.
Superbe Amplificateur
C'est mon 4ème ampli en Class D .. Je ne reviendrai plus vers les tubes , la class A ou même AB.
Absolu transparence , maintien du grave et dynamique, ce sont les qualités déjà connues et au top avec la dernière version de PURIFI.
Je l'ai utilisé avec différentes enceintes a rendement différents. avec le réglage de gain de la carte Audiophonics il est toujours possible d'avoir une bonne progression du réglage de volume.
Actuellement je l'utilise avec le Dac Preamp JADE de Metrum Acoustic. La qualité de fabrication est excellente ainsi que la possibilité de changer l'AOP si besoin .. !
Si vous optez pour des montages séparés avec ampli de puissance. C'est le meilleur choix à ce prix et peut être dans l'absolu. Il faudra penser à lui associer un bon câble secteur il y en a de bons ici dans la gamme ELECAUDIO, c'est ce que j'utilise aussi.
avec liaison MOGAMI XLR
Enfin je ne partage pas l'avis précédent qui parle d'un haut médium en avant .. , en fait ces amplis sont tellement transparents qu'ils mettent en évidence les qualités et les défauts des équipements associés.
Notamment les colorations caractéristiques de certaines marques !
Fabrice C.
Bien mais pas avec toutes les enceintes...
J'ai acheté cet ampli dans l'espoir de mieux alimenter mes enceintes Magnepan MG1.6 QR actuellement sur un Denon PMA 2000.
Si vous avez la même idée, oubliez! Le grave est étriqué, il est dépourvu du beau "moelleux" procuré avec le Denon. Le haut médium est outrageusement mis en avant au point de rendre l'écoute très fatigante sur certains titres. Les timbres sont dénaturés dans cette gamme de fréquence. D'une manière générale, la musique est désincarnée. Après deux mois d'essais, il m'apparait que cet appareil se marie très mal avec les Magnepan.
J'ai donc décidé de le tester sur mes vielles enceintes Rogers LS7T qui fonctionnent très bien avec mon ampli Onkio A 8500 (2 X 100 watts), et là, ça a été la très bonne surprise! Je l'ai associé à un DAC pré-ampli Silkline Zuki I acquis récemment. Eh bien, mes Rogers n'ont jamais aussi bien sonné! Le grave est charpenté, moelleux et soyeux à souhaits. Les timbres sont justes et équilibrés, l'aigu à sa place sans excès. L'écoute, légèrement flatteuse est vivante et extrêmement agréable.
En conclusion, selon mon expérience, cet ampli est capable du meilleur comme du pire en fonction des enceintes qui lui sont raccordées... Le mariage avec des Magnepan est désastreux mais, au contraire, il fait merveille avec des Rogers...
 (4)
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo piano performances, where you can see the sound hanging in space, fading away without any blur.
The treble is never harsh, and the overall sound is truly flat and stress-free. Despite this, even the lowest frequencies are clearly separated and dynamic without being overbearing. For acoustic music, this is exactly the sound I was looking for.
However, one point requires attention.
This amplifier also supports RCA input via a switch. But since the Purifi module is designed for a fully balanced configuration, using RCA results in a severe degradation in sound quality. Specifically, issues such as smearing, distortion, and poor imaging become noticeable—to the point where (to exaggerate slightly) it starts to resemble a sub-€100 Chinese digital amp.
Therefore, if your upstream equipment only has unbalanced RCA output, or a pseudo-XLR connection that only uses pin 2, simply using an adapter plug for conversion is not sufficient. The unbalanced-to-balanced conversion must be performed via active circuitry within the preamplifier!
Marco R.
7 stelle di Qualità
Arrivato da pochi giorni questo amplificatore e nonostante è ancora in rodaggio, non smette di piacermi. Palcoscenico largo e tridimensionale, ottima separazione degli strumenti, e non stancante, ottima musicalità. Collegato a delle PMC TWENTY5 22 che già suonavano bene ora ancora di più. Non posso far altro che consigliarlo, anche per l'ottimo rapporto qualità prezzo, e all'ottimo servizio di consulenza di Audiophonics.
Nicolas P.
Ampli purifi
Cela fait seulement 2 jours que j ai reçu mon ampli purifi et donc tjrs en rodage.
La claque, il exploser en tout point mon ancien ampli pourtant 3 fois plus cher...
Je n' ose Imaginer dans quelques heures ce que cela va me donner...
Tout y est, à la bonne place, avec une précision extraordinaire.
Tout est sublimé.
Je suis super content de mon achat et certainement le dernier ampli que j achète.
Merci audiophonics pour donner la possibilité d avoir une amplification aussi bonne, à si peu cher en comparaison.
Olivier L.
L'ampli idéal
J'ai eu pas mal d'ampli et souvent pas 100% satisfait mais là j'ai été convaincu dès les premières écoutes. Le son est fantastique tout simplement.
Autant j'ai été déçu par un ampli comme le topping LA90, qui a de bonnes mesures mais est pouratnt très mauvais à l'écoute.
Je n'ai pas encore le comparer à mon ampli de référence mais je suis super content. J'ai l'impression qu'il est diffcilie de trouver mieux à ce prix.
André A.
Exceptionnel
Je viens enfin de brancher mon ampli de puissance. Après avoir attendu le temps de chauffe nécessaire, c'est une révélation. J'ai l'impression d'avoir de nouvelles enceintes. Je découvre le potentiel de mes Triangle Esprit Antal EZ, grosse montée au niveau des basses, impressionnant, un caisson de basse s'avère inutile. Mon ampli Yamaha RN1000A se concentre sur les médium haut et sur les aigus.
Pour info, suite au conseil donné ( merci encore aux équipes d’Audiophonics, technique et réactif) j'ai réglé mes curseurs sur un gain de + 29dB pour avoir le même niveau de volume.
Emilio L.
Excellent ampli !!!
Reçu 3 jours après la commande, et testé tout suite après avec un streamer/dac/preampli Yamaha wxc-50 et mes chères enceintes Triangle Lyrr 222 (93dB de rendement et 8 Ohms). Le réglage de gain à 20dB est correct pour mes besoins. Très transparent, il fait ressortir beaucoup de détails dans tout la gamme spectrale. L'écoute n'est pas de tout fatigante il convient bien au classique, jazz, pop, rock. Bref, le LPA-S450ET tient tous les promesses qui apparaissent dans le descriptif d'Audiophonics. Rien à ajouter de plus. Je recommande cet ampli.
Grand merci à David Aubert d'Audiophonics pour m'avoir aiguillé sur cet ampli.
George R.
Exceptional sound quality
I also have an "LPA-S600NCX" stereo power amplifier and wanted to compare the two concepts. I really struggle to determine if there is a repeatable difference between the two amplifiers. On certain tracks I feel that the Purifi is slightly more relaxed & natural and on others feel that the Hypex is a bit punchier in the bass. However, I am not confident that these subjective observations are repeatable. Both amplifiers are neutral (in a positive way), musical & silent. The one noticeable / repeatable difference is that the Purifi is cooler to the touch. Save a bit of money and buy the Hypex ncx? You cannot go wrong with either - both are exceptional amplifiers!
 (6)
Jean Pierre g.
PARFAIT
Merci a audiophonics et son equipe de faire des appareils aussi performants a un prix (abordable).
Un vrai plaisir d'écouter la musique.
A une prochaine sans probleme
Juha T.
Excellent quality
Build quality really good, excellent sound. Although the case is small and lots of power, amplifier case heats only little during modest levels of listening.
We're proud to present the Audiophonics LPA-S450ET, a Class D stereo power amplifier based on two Purifi 1ET6525SA modules. Electronically...
