FURUTECH CF-C15 NCF (R) IEC C15 Connector Rhodium-Plated Copper Alpha Treatment Ø16mm
The Furutech CF-C15 NCF (R) connector is an IEC C15 connector featuring pure copper contacts with rhodium plating and Alpha treatment. Its body is reinforced with NCF technology using damping materials based on nano-ceramic and carbon. It supports cables with diameters from 6.6mm to 16mm (maximum cross-section of 3.5 mm² (~12 AWG)).
By buying this product you get 45 loyalty points
Reference : 21635
459,00 €tax incl.
382,50 € tax excl.
Furutech CF-C15 NCF (R) IEC C15 NCF Connector Rhodium-Plated Copper Alpha Treatment Ø16mm
The Furutech CF-C15 NCF (R) connector is an IEC C15 connector featuring pure copper contacts with rhodium plating and Alpha treatment. Its body is reinforced with NCF technology using damping materials based on nano-ceramic and carbon. It supports cables with diameters from 6.6mm to 16mm (maximum cross-section of 3.5 mm² (~12 AWG)). Assembly is carried out using screws, a pressure plate, and a non-magnetic cable clamp, improving grip while reducing mechanical and electrical distortion. In addition, a specially formulated silicone sheath provides optimal tensile strength. The CF-C15 NCF (R) is specifically designed for direct connection to slim-profile video equipment, including 4K and 8K televisions.
Technical Specifications
Product TypeIEC Connector
IEC TypeC15
Contact MaterialCopper, Alpha (α) treatment
Contact PlatingRhodium
Body MaterialNylon, fiberglass and NCF
Damping MaterialNano-ceramic particles and carbon powder for piezo-electric damping
Cable Diameter Min / MaxMin: 6mm
Max: 16mm
(Maximum cross-section of 3.5 mm² (~12 AWG))
AssemblyScrew-on
Cable Clamping SystemMetal clamps
Dimensions22 x 30 x 82mm
Weight7g
Packaging1x Furutech CF-C15 NCF (R)
Max cable diameter (mm)16.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)N/A
FURUTECH CF-C15 NCF (R) IEC C15 Connector Rhodium Plated Copper Alpha Treatment Ø16mm
The Furutech CF-C15 NCF (R) connector is an IEC C15 connector featuring pure copper contacts with rhodium plating and Alpha treatment. Its body is...
