Thierry W.
ANTONIO M.
meanwell is meanwell
the smps brand choosen for nelson pass's pass aca class a diy amp.
Not casualty, the only one smps can make analog audio device sounds almost as good as with linear psu
ANTONIO M.
good detail, really good but compressed dynamics even with linear psu
good detail, really good resolution but compressed dynamics even with linear psu 5 volts
ANTONIO M.
Not better than UCD with linear PSU
Yes is more efficient than linear PSU amps but the treble is dull and not detailed at all. CI hope Purifi is much better than this. I ended selling it as i did with the NC500MP dual mono i purchased here too. Built construction is great, as all audiophonics house products but ncore is with smps is not good enough for hifi or high resolution monitoring. But Brunos's designs are advancing and the good thing is contruction is great, is durable, it really can handel 3 ohms loads, is dynamic .... but is low resolution highs... Looking for next generation of Purifi to see if they fix its high reslution weakness. Just ordered some pro class d amp for a popular brand of pro single driver passive studio monitor, Aurartone, still waiting for it. I use Focal, B&w and dynaudio only. Hope someday some class d amp can surpass my quad 606 or even my modest NAD 216thx regarding crisp highs and liquid mediums
Thibaut L.
J'ai commandé une 36 v pas une 24 v
Jean-Pierre V.
Documentation pas à jour
Attention la documentation téléchargeable sur le site audiophonics ne correspond pas au modèle livré (juin 2022) : en particulier contrairement à ce qui y est spécifié, Win7 n'est pas compatible... Savoir que l'achat d'un nouveau PC est indispensable, n'est pas complètement neutre.
En attendant, il ne m'est pas possible de tester l'appareil.
Le fabricant ne nous a malheureusement pas prévenu de ce changement, nous mettons la fiche produit à jour au plus vite.
A noter que vous n'avez pas à changer d'ordinateur pour mettre à jour Windows.
MATHIEU B.
DAYTON AUDIO BPP-SN Speaker Terminals (Pair) These terminal blocks offer great design quality at an affordable price. They provide a secure and efficient connection without the tendency to loosen. They also accept banana...
Beau de loin…
Massif et qualitatif, mais vu de près, les détails tels que la régularité approximative rainures évitant le glissement des doigts trahissent une fabrication inégale. Il y a sur le site des borniers mieux finis vendus moins cher. Mais bon, pour le look gris mat, il n’y a pas d’autre choix….
MATHIEU B.
Bonne qualité générale
Belle qualité générale, nombreuses mâchoires permettant le sertissage de presque tous les connecteurs. Je retire une étoile car la pochette ne contient pas d’illustration reprenant la correspondance mâchoire-connecteur, donc j’ai dû imprimer la photo du site pour obtenir et conserver cette info.
Joerg K.
Excellent Cable for reasonable price
Sound is excellent, very broad and deep soundstage.
Clear without irritating highs. Bass is also ver accurate.
To remove the insulation is very diificult and time consuming, also the termination with connectors is not that easy.
Still the sound quality was worth all the hassle.
Charles S.
VIBORG VF512R
Qualité des composants de haut niveau, excellente tenue de la fiche connectée supportant le poids de câbles lourds .
Sans oublier les soins apportés au traitements de surface argent/rhodium.
De la haute couture avec à la clef l'apport d'une musicalité au rendez vous .
je recommande ce produit sans réserve à ce prix sans concurrence !!!
mathieu l.
ELNA SILMIC II RFS Aluminium Audio Capacitor 100V 2.2µF The Silmic II RFS (ROHS) series is a high-end series of capacitors from ELNA with superior acoustic qualities. The electrolytic separating paper used for this series contains...
mathieu l.
FX-AUDIO BA3121N Isolator Noise Attenuation Module This very small module eliminates common ground noise from an audio system. Operating at 12V, it is particularly well suited for Car Audio use. If its installation between the...
super
Charles S.
Le connecteur VE12SS
J'ai testé depuis une quinzaine d'années au moins une quinzaine de connecteurs Schuko , je classe ce connecteur VIborg champion du monde toutes catégories , le rapport qualité prix et la musicalité sont extraordinaires. Sans autre commentaire !
Charlie
Bharat C.
This is the one.
Excellent build quality. Excellent sound. Simply no faults to be found. I'm not sure how one would find something better, except by trying many others with similar quality-characteristics and then preferring a greater coloration/distortion to the sound. Along those lines, I ordered the Sparkos op-amps as an extra purchase and installed them myself to test. Honestly, there is starkly little difference. However, I did very slightly prefer the Sparkos and left them installed. For the information of others who may research this choice, I'm 100% happy. The USD/Euro ratio is favorable right now if you're ordering from the US, and the shipping cost is not expensive at all (price it in your cart). My goal was to get streamed high-definition recordings to my ears with as little deviation from the source recording as possible. To that end, I run the streamed music through an RME-ADI 2, then (via XLR) to this amplifier, at the "low" jumper setting for the Audiophonics. Bi-wired handmade (but not expensive) cables run to the Eminent Technology LFT-8b speakers. The RME has plenty of output and can effectively serve as a preamp for digital sources. I listen to all kinds of music for pleasure, though I am a full-time professional orchestral/chamber/solo musician by trade. Thus, my preference for the straightest path to the musicians where possible. I happily acknowledge that there are likely systems of music reproduction that I would like better than what I have here now -perhaps more colored, perhaps somehow less. Having said that, I've never heard anything I've liked better. Buy this amplifier with complete confidence.
Stefano P.
Question for Patrick
Thanks for the review! Which IEC plug would you suggest to match the DOUBLERAMM and the FI-48R?
Stefano
Constantin N.
Incredible price performance
Anyone interested in this amp has probably dealt with measurement data and ASR. Thus, you know that probably one of the best power amps in the world is offered here.
They are impeccably finished and thoughtfully assembled. The sound is mercilessly transparent and clean. I can not imagine that there will be anything better again. Especially not for this price. This is final stage endgame.
A few criticisms: the front LED can be deactivated, but I would have preferred the color red or orange here, so that it is not so annoying at night. A small instruction or parts list, at least on a small piece of paper, would have been nice. But these are both really only small things.
Alexis R.
Impressionnant
Je cherchais à remplacer mon bc ex-222 pour un prix modique et je n’ai pas été déçu. Évidement l’ampli est solide dans les basse, son prédécesseur l’était aussi. Mais la finesse et la scène sonore sont sans comparaison !
Un rapport qualité son/prix a mon avis imbattable.
En cherchant la petite bête je relevé que certaines sifflantes ressortent mais sans que l’écoute soit fatigante. A voir après rodage. En tous cas je ne regrette pas cet achat.
Amont: lecteur réseau/preampli yamaha wcx-50
Aval : dynaudio emit 20
2avis.exelent option oayde iec berilium platine palladium remplace iec viborg rho
Monté en viborg 502 rhodium. J ai essayer une oayde iec cu berilium pl platine palladium. Certe 137euro pour une prise sais pas donné. Mais la ch centime en valent la peine elle depasse mes esperance et de loins. Chuko cu rho et iec pl palladium. Le match parfait pour un prix plus que justifié. Plus ouvert precis fluide et des aigus superbe. Grave percutant ferme et precis. Wouaa j ai envie de le dire. A essayer absolument. Je vais changer regulierement mes viborg rho iec part ses oayde 004 berilium plat palladium. Ha la musicalité le naturel le son analogique. Genialisime sur mon systeme moyen de gamme. Bien optimisé.
Matthieu G.
Etonnant de qualité
Curieux de nature, j'ai voulu tester un ampli FDA. Sans a priori d'ailleurs.
Et là, j'avoue que j'ai été très heureusement surpris. Par la robustesse de l'objet, d'une part, mais aussi par le rendu. c'est musical, clair. Et puis, ça ne manque pas de puissance. Je suis tout simplement impressionné !
C'est un voyage musical diffèrent d'avec mon Atoll ou mon Jadis Orchestra. Il vient en complément, mais en aucun en mode "low cot". Pour le prix, c'est une véritable révélation. Et même en Bluetooth c'est très correct.
Bref, de la qualité. Bravo !
Matthieu G.
Particulièrement déçu
C'est la première fois que je suis déçu par un produit de la boutique Audiophonics. D'habitude, je suis toujours enchanté et vraiment hyper satisfait depuis plus de 10 ans.
Mais là, j'avoue que je suis interloqué par la bête. Comme j'avais des soucis d'accès à Internet je n'ai pas vraiment pu teste de Zen stream, sinon je l'aurais rendu tout de suite. Depuis, mon Internet fonctionne parfaitement. Mais l'appareil, qui est le seul connecté sur mon réseau, n'est pas toujours fonctionnel : il est souvent nécessaire de le redémarrer plusieurs fois, de vider le cache de mon téléphone ou de mon ordinateur avant que du son sorte enfin ! Et lorsque je change de source, il faut souvent recommencer l'opération. C'est très agaçant.
C'est dommage, car au niveau sonore, il en vaut la peine. Ce qui doit certainement justifier son prix...
Du coup, il risque de terminer au fond d'un carton, parce que je ne vais pas revendre un appareil dont je ne pourrais pas dire qu'il est convenable.
Nous sommes navrés des soucis que vous rencontrez avec ce produit, ils semblent anormaux.
Contactez nos collaborateurs du SAV qui vous aideront à comprendre ce qui ne va pas et vous permettront de disposer d'une solution fonctionnelle.
MICHEL B.
J’avais des problèmes de parasitage sur mon lecteur réseau NAD M50.2.
J'ai acheté il y a trois jours deux câbles Ethernet de 5 m AUDIOPHONICS pour relier les enceintes Cabasse au CPL, et un câble Ethernet de 1 m AUDIOPHONICS pour relier mon serveur lecteur réseau M50.2 au CPL.
La finition des AUDIOPHONICS est parfaite : les prises RJ45 sont bien blindées et le câble est d’excellente qualité.
A ma grande surprise, les parasites ont disparu et le son reproduit exactement l’orchestre réel sans aucun des défauts attribués classiquement au numérique.
Donc un très grand merci à AUDIOPHONICS pour ce câble parfaitement blindé qui respecte la quintessence de la musique.
reginald B.
se méfier....
J'en ai trois pour alimenter des T3 mono de chez hifimediy, j'ai cessé de les utiliser, ils me grillaient des modules amplis au démarrage un peu aléatoirement, depuis j'alimente direct avec trois batteries 12v en série et je n'ai plus de soucis (recul de plusieurs années). Dans quelle mesure un soft start réglerait le problème... dommage c'était bien pratique comme circuit.
Sublime le son
Etant alimenté par cable oayde tunami monté cu pl rhodium. Je voulais changer les iec car les prises de mes appareils sont en cuivre pl or. Or et rhodium ne font pas d exelents partenaires. Et bien je suis heureux du resultat. Non seulement le son na pas changé musicalement. Mais a amelioré la dynamique la transparence et aussi la richesse des harmoniques. Le filé la fluidite rythmique sont parfaite. Apres deux semaine d utilisation, la prise sais ameliorée jours après jours. Le grave et puissant ferme et d une rapidité impressionnante. Les attaques du violon du cello et du piano sont fenomenale. Certains album de jazz de classique et meme d electro housse trance rock sont encore plus percutant. Et de l autre côte de la douceur et un naturel magnifique. Les voix sont encore plus incarnées et d une intelligibilité incroyable. Et en sachant que la chuko reste cuivre pl rhodium. J ai une barrette type furutech nfc rhodium le mariage de ses dezx prises et exelentisime. Monté sur mon dac audio gd r2r. Charnel emouvant et aussi percutant et puissant. L ouverturr aussi et exelente. Mes delta signature sont ainsi magnifiée et il en ressort un plaisir a l ecoute jouissive.
Un peu plus loin.
Mon matériel : Pier audio 580 se, focal aria 948, roksan k3. Ces câbles vous procurent une restitution en 3D. Les basses sont bien assises avec une vraie restitution des instruments, exit les boom boom. De trés beaux médiums font que Mélody Gardot ou Patricia Barber voire Diana Krall sont en train de prendre l’apero avec vous. Les aigus apportent une énergie ciselée sans jamais vous vriller les tympans, les belles harmoniques sont là. Derrière ce découpage, en fait, c’est la musique et son émotion qui vous emmènent vers un grand plaisir.
Merci à l’équipe pour ses conseils avisés sans jamais vous proposer des produits aux tarifs hallucinants. Donc c’est un choix fortement .recommandable.
Merci bonne écoute.
stephen r.
BLUESOUND NODE 3 (2021) Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA White The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi system, it will allow you to...
Attention lecteur USB 'has been'
Bon streamer mais interface limitée. La gestion de vos fichiers audio sur support USB (clé ou disque) est tout simplement nul. Donc, si vous avez un grosse collection de fichiers audio passez votre chemin.
Michel L.
2 eme command de cet ampli ... que du bonheur ...
Un excellent ampli numérique au son propre, ciselé, riche, défini, ... dans un tout petit volume.
Fonctionne avec des Boston CR75 pour un excellent rendu sonore.
C'est le 2ème ampli de ce modèle que j'acquiers pour faire un cadeau à un ami, c'est dire le niveau de qualité du produit.
jean - claude A.
AUDIO-GD R-8HE Balanced Discrete 4x R2R DAC Regenerative Power Supply 32bit 384kHz DSD512 This R-8HE, with its extremely careful design, takes up the key elements of its predecessor, the R-7HE, whose audio quality it inherits, while seeing its performance revised...
très bon DAC
Ce modèle ne se fait plus mais je donne mon avis :
Cela fait un an que je possède ce Dac .
Suite à montée en gamme , il remplace un bon Dac de gamme inférieure et de prix trois fois plus faible . J 'ai , aussitôt branché , entendu une grande différence . Son clair et bien défini .
J'en suis très content .
De plus , le service Audiophonics est très performant .
jean - claude A.
Je suis très content de ce câble : j'ai remplacé une paire de cordons RCA entre l'ampli et le Dac ( valeur des deux pour situer les choses : 9000 € ) pour profiter des 5 volts en sortie du Dac au lieu des 2.5 V sur les RCA .
J'ai aussitôt récupéré beaucoup plus de puissance comme prévu .
Ceci pour régler mon problème technique .
Pour ce qui est de la paire de câbles en elle même :
très bel aspect et un son qui me conviens parfaitement . Je ne les ai pas comparés à des câbles beaucoup plus chers , que je n'ai pas , donc MA CONCLUSION est qu'il ne faut surtout pas hésiter à utiliser ceux - çi .
Comme d'habitude le service Audiophonics est excellent .
Fernand B.
couteau suisse
Voilà un appareil qui réunit plusieurs fonctions, filtre actif et surtout Dirac Live, une écoute très détaillée.
Christophe H.
Kenneth H.
good value, good customer support
This is a good value. For those of you who are accustomed to more old-school amplifiers, you will be surprised how such a light and small package can pack such a big punch. The internals of this unit will definitely make your speakers sing. The external case is good enough. Solid connectors. Simple design.
I ordered this to the USA based on what I've read about this implementation in online forums, particularly AudioScienceReview. The delivery arrived within days, in very protective packaging.
I needed to talk to customer support a few times, and they have been willing to address all my concerns in an ethical manner.
In conclusion, if you're in the market for a Purifi amplifier, I would recommend trying out the Audiophonics implementation.
845 B !
Justement, les vraies 845 B sortie vers 2004 n'avaient pas de top mica, sa structure était basée sur le modèle Amperex, avec une armature de maintien bien plus rigide qui ne nécessite pas de calage par un top-Mica.
Des 845 B avec Mica ont été produites ensuite visiblement suite à des problèmes de casse durant le transport...
La 845 A (standard) avec Mica est basées sur le modèle RCA.
Les deux versions n'ont pas la même sonorité, la vraie 845B a un son plus plein, plus d'assise, l'une ou l'autre conviendra mieux les goûts de chacun et l'ampli utilisé.
Juan T.
FOUNTEK NEO CD 3.5H Speaker Driver Ribbon Tweeter 12W 7 Ohm 95dB 1100Hz - 30kHz 9x60mm Fountek innovates in the field of ribbon loudspeakers by adding a roof. The combination of these two technologies allows high frequencies to be obtained with extreme precision...
Incredible tweeters
These are my main tweeters and are Incredible.
Super clean, light, musical, realistic. Impresive.
Will never use dome tweeters again. Its ultra low mass moving ribbon must make the difference.
Be sure the crossover is well designed and cuts at least at 3,5Khz, 3rd order.
Miklos B.
LPA-S400ET class d Purifi2x400w After one year of use
Dear Friends,
After one year of use and system developments I thought it worth to write a second chapter to my original review:
So, I changed to Electocompaniet ECI-2 DAC, and Focal Kanta No2 Speakers. Obviously I had to recalibrate the whole cabling from power to speakers. Finally I have made some acoustic treatments in my Hi-Fi room too which is absolutely needed if you want to reach real bass and prefect focuses. The end result is simple fantastic! I know that the amplifier is still the cheapest element in my system, but friends it makes the job so-so well, that I am still amazed in every single day how fantastic is the music ( I use Tidal master) what I can hear. The amplifier has zero distortion with plenty of fine details, endless power, fantastic deep bass levels, and space creation for the instruments-singers, no heat issue at all and finally, excellent price /performance ratio.
I am a huge fan of cabling, so I recommend to have each Hi-Fi element separate and connect them with matching cables ( I mainly use own selected, paired and soldered together cables and of course solid dc converters to the small Hi-fi pc and to the X-SPDIF2 USB to RCA converter too.)
So if you need affordable amplifier with a capability to drive even much more expensive elements, do not hesitate, just go ahead!
restitution honnête
Meilleur qu'un câble basique , utilisé sur un lecteur cd la restitution sonore est améliorée ( neutralité et propreté d' image ) . Cependant pour un peu plus cher on peut avoir beaucoup mieux . Idéal pour un utilisateur qui ne veut pas se ruiner .
Wayne G.
NEOTECH DG-2075 Coaxial RCA Connector 75 Ohm Ø9mm This Neotech DG-2075 RCA connector is ideal for designing a high-quality 75Ω coaxial cable. The current is distributed evenly over the entire contact area. The cable...
No assembly instructions or support from supplier of manufacturer
This crimp plug requires an appropriate tool to crimp the conductor and the shield. What tool though? there are no assembly instructions. I asked for at least a size for the crimp, Audiophonics were unable to provide, said they would get back to me but didn’t. Neotech seem impossible to contact.
So don’t waste your money buying a product with no assembly instructions, no technical data or support from the manufacturer or supplier.
Tres bon câble
Après un peu de rodage câble bien détaillé sans tomber dans l'analytique
De belles basses bien propres de beaux timbres musicale et jamais fatiguant les aigus sont très soignés bref on écoute la musique et pas le câble
Magnifique rapport qualité prix
J'ai acheté 2m de ce câble pour relier mon enceinte centrale (Kef R600C, pré-ampli Marantz Av 8805 + ampli Marantz MM8077)
Dès les premiers films les dialogues ont été métamorphosés, clareté, précision... pour 22€, c'est à peine croyable
Mon ancien câble avait couté 10 fois ce prix...
Encore merci à David pour ces précieux conseils
Alain Prost
Câble magique
A l'origine, j'envisageais de changer mes enceintes (infinity kappa 7.2 achetées en 2000) car je constatais un manque de basses et manque d'ouverture, malgré 1 pré-ampli Naim Atom et ampli hybride Pier audio. A la lecture des avis, j'avais un sérieux doute sur les qualités vantées sur ce câble (prix...) ayant des câbles valant 6 fois plus cher avec un résultat frustrant.
Après quelques heures d'écoute + magic cd, ma surprise est totale, bravo!!
Merci à David pour ces conseils avertis, ne poussant pas à la consommation
Alain Prost
François R.
SHANLING CD-S100 (21) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black The Shanling CD-S100 (21) is a high quality, high performance and versatile CD player. The core of the system is based on a dual-core Junzheng X2000 processor using XBurst2...
Excellent lecteur
Acheté il y a 5 mois, correspond parfaitement à mon besoin pour l'utilisation principalement en lecteur CD et connexion bluetooth.
Je n'utilise pas l'appli Eddict Player qui plante systématiquement sur mon android, mais elle n'est pas vraiment utile.
Vraiment très satisfait d'avoir ce maillon dans ma chaine hifi.
Laurent D.
AC/DC Switching Adaptor 100-240V AC to 12V 10A DC This AC adapter provides an output voltage of 12V DC and a current of 10A. It may allow you to power certain devices such as an amplifier or DAC that require these power values....
Grésillement
J'ai utilisé ce produit pour alimenter un mini-PC, je ne le recommande pas pour cet usage : l'alimentation grésille de façon très audible. Le grésillement suit l'activité du PC (mouvement de la souris, etc). Au bout de 10 minutes je n'en pouvais plus, j'ai fini par éteindre le PC ! Et pourtant il est inscrit dessus "utiliser avec du matériel informatique seulement"... A voir si elle se comporte mieux dans d'autres usages.
Joaquin T.
Excelent petit DAC Bluetooth
Fonctionne parfaitement avec une parfaite stabilité de connexion et un son qui me plaît.
Philippe A.
amélioration effective, sensation de propreté plus marquée dans le message sonore reproduit. utilisé en tète de multiprise. m'a permis de constater que la prise avec bouton de marche arrêt était en opposition de phase et que le bouton lui même ne coupait que la terre donc c'était dangereux et maintenant corrigé.
DIMITRIOS P.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
A hi fi device by all means
I have it only a week now but from the first moment it gave me the confidence and pleasure that only real hi fi devices do.Always on it runs cool, every input/ output works perfectly, usb driver a breeze, sound really better than my Burson conductor 3 reff wich cost me more than 4 times more and now returned to its box as a veteran (a war casualty.)
Anders H.
Really good product
I work with professional Broadcast equipment with AES/EBU input and with this product I now have a small battery operated media player with AES/EBU output. Very practical to have for testing and repairing equipment or just listening to music when You are working :-)
julien m.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
rapport qualité /prix
Difficile de lui reprocher quelque chose à ce prix , un ampli simple et efficace drive honorablement des davis mia20
merci fx audio et surtout merci audiophonics
Alain S.
Fabuleux
Tout est déjà dit dans les commentaires précédent qui sont très juste par rapport au ressentit et plaisir procuré par ces petits bijoux ...
C'est un aller sans retour tous vos précédents intras (y compris très sensiblement plus onéreux ) vont vous paraitre fade et ... limite cassés ...
otto k.
TOPPING HS01 USB Isolator 32bit 768kHz DSD512 The Topping HS01 is a small, high speed, low latency (0.29µs) USB 2.0 isolator. It is compatible with high resolution streams up to 32bit 768kHz PCM and native DSD512 for...
USB Isolation
Ein schwieriges Unterfangen mit dem Topping HS01 Isolator .
War durch Inernet Recherche etwas vor gewarnt, zusätzlich muß man richtig nach Info suchen.
Er sollte die USB Verbindung Mac Mini zum DAC galvanisch auftrennen. Wie gesagt er sollte.
Mehrfach Versuche an anderen Apple Rechner liefen sehr sperrig und es blieb beim - er sollte.
Mein schon lange benutzter „großer“ Isolator von einer anderen Firma, stellte überall die Verbindungen/Erkennung des DAC her.
Mit freundlichen Grüßen
Guillaume B.
Vraiment un très bon câble
Je l'ai sélectionné pour son architecture et les matériaux utilisés.
Le résultat est une ouverture accru, une foultitude de détails qui se révèle pour le medium/aigue, une basse profonde et charnue et une dynamique bien ressentie le tout sans déséquilibre.
Très très bien!!
Guillaume B.
Remplace très avantageusement les HDMI HighSpeed de Mon....-C...e ainsi que Cinnamon de Au......st.
Je remplace tous mes HDMI par ces câbles 2.1 en cuivre OCC plaqué argent au résultat super!!
Achat sans aucun regret!!
Acheter ce câble pour remplacer en HP mes chord epic, j'en est monté un à la place de mes nordost red pour voir (fiche nordost ET câble RAMM) et là le choc !
Tout est mieux.
Du coup je remplace tout mes câbles par du RAMM 5
C'est un super mariage avec mon système (Moon 280 et Moon 340)
Merci audiophonics
