Zacharias L.
Very good but...
Pavol B.
Pavol B.
Moderate plugs
These RCA plugs looks good, quality made, aluminum body, good plast /no melting/, easy work with them. Pins and etc look...
Customers reviews - There are 19524 reviews.
MARCO A.
DAC
Good quality and easy to use. My Teac VRDS 10 take a new life.
Yann D.
VIABLUE HS SPIKES BLACK Spikes Black (Set x4) The Viablue HS Spikes help to limit vibrations from your speakers or devices to underlying surfaces. This results in a clear, precise and detailed sound reproduction. The spikes...
Pointes Viablue
Totalement satisfait du produit. Leur installation à totalement nettoyé mon système qui souffrait d'un excès de basses fréquences omniprésent. Excellente qualité de fabrication, parfaitement emballé. Livraison rapide. À recommander.
Csongor K.
Perfect DAC & Headphone amplifier
Very professional built, small device with all the necessary functionalities - small, but really powerful.
Just perfect to use as headphone amplifier and DAC connected to your computer. With some additional configuration on your computer you can experience the real value of the device (Hi-Res and MQA).
The audio quality with proper source and good headphone is fantastic. Working very well with Sennheiser HD650, HD660S and AKG K812. With TIDAL you can experience a new level of audio quality. For curiosity I checked with DSD512 - working....
All in all I think that M500 is a compact-, cost saving solution for listening high quality music trough your headphone.
Thierry D.
Connecteur de très bonne qualité permettant de monter facilement des gros câbles (ex YARBO SP-8000PW)
Thierry D.
Très bonne gaine rétractable
Se rétracte très bien avec un sèche cheveux
Thierry D.
Excellent cable secteur
Câble assez rigide. Assez difficile de monter des fiches coudées ELECAUDIO. Prévoir des embouts 6mm² afin de pouvoir relié la tresse de blindage en cuivre avec le fil de terre du coté Schuko pour obtenir une masse flottante.
Pour moins de 100 euros, vous aurez un excellent câble secteur blindé d'un mètre qui fera son travail, éliminer les interférences et parasites pour vous apporter un son plus pur permettant d'entendre plus de détails.
Branchés sur un ampli et lecteur CD/SACD HDG. Écoute, principalement du classique.
Petite période de rodage à prévoir
Bon câble
Pour le prix, rien à dire.J'ai comparé avec le mogami 2549 et le canare L-4E6S, câblés en symétrique, qui sont plus analytiques.Ils possèdent des qualités indéniables mais sont moins polyvalent et qui peuvent engendrer une fatigue auditive en raison d'un haut medium projeté
(surtout le 2549).
Le 238+ est plus charpenté dans le bas sans être brouillon, le médium ne fatigue pas à la longue et l'aigu est suffisamment défini.Je le trouve plutôt efficace et de bonne qualité pour le prix.Je l'avais tester en asymétrique il y a un moment, et il me semblait brouillon, ce qui n'est pas le cas en symétrique.Fait de la musique et c'est l'essentiel.
patrice f.
câble ethernet
Voir l'avis sur le connecteur telegartner !
patrice f.
connecteur rj45
Ce connecteur associé au câble viablue EP7 et au dac sanskrit 10th
MKll donne un excellent résultat.
Le concert Melody Gardot au studio 104(accessible par arte) est un régal ! A mon humble avis, le rendu est un peu meilleur que le cd !
Damien d.
FOnctionne bien
Il y a ambiguité sur le site : on ne sait pas s'il est avec ou sans inter. Finalement le modèle reçu est avec interrupteur.
Damien d.
DAYTON AUDIO DC130B-4 Classic Speaker Driver Woofer / Midbass 40W 4 Ohm 92dB 50Hz - 5000Hz Ø13.3cm The DC130B-4 speaker from Dayton Audio is a 4Ω model for bass broadcasting. Thus, with its diameter of 13cm, its flat and wide spider and its 2.5mm travel, this loudspeaker is...
Conforme à la description
Remplace un HP d'un caisson de basses Creative : le résultat est bien meilleur qu'avec le HP d'origine.
Athanasios S.
DELOCK USB 2.0 Cable USB-B male to USB-C male 1m
I don't have a reference cable to compare but this is effective for the price!
Jean Pierre P.
Belle construction de qualité apparente mais ou sont les radiateus qu'impose une class A
L'usage de FET aurait préférable aux transitors cela se ressent dans les écoutes la chaleur des lampes semble estompée
Class A tout de mème
Attention ce n'est qu'un ressenti personnel
jean francois F.
FX-AUDIO XL-2.1BL
rapport qualité prix exceptionnel (une caractéristique de la marque). Son très propre (trop?)varie suivant le support (ex pieds en sorbothane)...appareil très pratique et qui fait bien le job.
Anne b.
etain a souder a l argent
fil étain argent de tres bonne qualité pour un cablage interne enceintes célestion super son vraiment bien
jean-françois J.
Franchement, je n’y croyais pas.
Ce câble est venu complété mon installation constituée d’un Nad C658, de modules Hypex N400 et des Electra 1028be2.
Et bien, l’apport est indéniable tant sur la clarté que la dynamique ainsi que sur l’immersion sonore.
Pour ceux qui pensaient comme moi que du cuivre reste du cuivre, je n’ai qu’un conseil : essayez par vous même !
MICHEL B.
Ce câble est parfait
Je connais depuis longtemps le câble MOGAMI W3103 qu j'utilise pour relier ampli et enceintes. Ce c^bla 4 mm2 est parfait, tout le signal est transmis sans perte à l'enceinte que ce soit en 1 m ou en 4 m. Il faut bien-sûr égaliser la courbe de réponse pour compenser les défauts de la pièce.
Knob Aluminum Notched Shaft 34x17mm Ø6mm Copper This copper-coloured Aluminium knob has a 6mm diameter notched shaft and can therefore be installed on any potentiometer shaft corresponding to these characteristics. The total...
Boutons classieux encore plus beaux que la finition dorée classique
Trés beaux boutons ayant beaucoup d'allure, surtout sur une façade noire. Trés bel aspect. Aspect bien plus original que le doré classique. Mais attention, adaptés aux axes crantés seulement, pas de vis de serrage ici...
Dominique P.
Pour atteindre l'excellence sans compromis!
Mis en oeuvre dans les 245 kits d'amplificateur K209+ Grand_Floyd dans le cadre des Commandes Groupées du forum de Mélaudia.
Dominique P.
nicolas H.
une vrai différence!
ayant testé du mogami 2497, du viablue nfs1et le fameux canare star quad avec du neutrik a chaque fois
j'ai sauté le pas pour me monter un cable plus 'haut de gamme' avec ce Nemoi 3220 et des fiches de qualité Ramm 30891GT: le top!, une scène large et précise (j'ai écarté un peu plus mes enceintes) c est naturel ,équilibré...mon système 'respire' mieux : vraiment très satisfait
nicolas H.
l'alternative au fer à souder... excellent connecteurs
Connecteur de grande qualité
Montés avec du NEMOI 3220 en utilisant des clés 6 pans (2mm et 1.3mm) j'ai trouvé le montage d'une simplicité par rapport à une solution soudée... on n'a pas la 'pression' du fer : montage fait sur 2 soirées tranquillement et résultat au top
Les fiches sont 'verrouillables' , il faut dévisser légèrement le corps avant mise en place puis revisser
Perso j'adore.. et je pense que j'en reprendrai...
Lionel N.
Très bien emballé, qualité au rdv boomer pour remplacer celui hs de mon flipper je recommanderai.
Noel R.
Cable de modulation
Matériel correct pour sa fonction, mais sa couleur rouge est un peut top voyante.
Andrew G.
Andrew
Great item, works exactly as described, switches entire system under control of my preamp.
Patrick D.
AMPLI BIPOLAIRE
Son exceptionnel si on lui met une très bonne alimentation ENTRE 35V ET 45V,mérite d'utiliser un préampli très musical ou un bon Equalizer
Patrick D.
Module ALIMENATION
Excellent, je recommande, bon filtrage pour ampli 100w à 1000w Sono ou Hifi
Vasil G.
Tres bon bon produit.
Samuel R.
Fonctionne aussi sous LibreElec 9
Fonctionne sous LibreElec 9. Pour cela, j'ai dû faire deux choses, après avoir glané différentes infos ici et là:
1) ajouter la ligne: dtoverlay=gpio-ir dans le fichier /flash/config.txt (il faut remonter la partition /flash avec les droits d'écriture avant)
2) créer le fichier /storage/.config/lircd.conf trouvé sur le site sunfounder: http://wiki.sunfounder.cc/images/3/35/Lircd.zip
Au final ça fait le job, mais télécommande vraiment très petite et pas du tout ergonomique.
Nicolas D.
Un NAD pour quelques euros
Tout d'abord, merci à Audiophonics pour l'emballage sécurisé qui a permis au produit de survivre à l'écrasement manifeste du carton.
Mon ampli mos-fet étant mort après 25 ans, je souhaitais remplacer très vite l'électronique par un module simple à installer et particulièrement abordable. Mes enceintes DIY ont des Monacor SP6/108 pro avec des "compressions" à ogive sphynx (copies de Beyma).
Conformément à ce qui est annoncé, j'ai clairement l'impression d'entendre un ampli à transistors bipolaires de bonne qualité. La puissance annoncée est vraiment présente (attention mes HP ont un rendement relativement important pour de la hifi).
Regrets (mais il faut aussi lire la suite):
- bande passante limitée dans l'aigu, mais correcte dans le grave
- image stéréo décevante
- présence des instruments acoustiques en retrait
- les HP ne peuvent plus restituer les transitoires ni les détails comme les cymbales "ride" ou les cordes pincées en classique et en jazz, je n'ai plus l'impression d'entendre les percussions et cuivres comme s'ils étaient dans la pièce. la contrebasse a perdu sa présence dans les attaques.
- un "cloc" à l'allumage et un autre à l'extinction, mais j'ai entendu bien pire.
Félicitations:
- construction de grande qualité
- EXTREME facilité de mise en oeuvre, Comporte des borniers à vis fiables pour câbles courants, sans soudure nécessaire côté CI. Penser à prendre un câble XH (en accessoires conseillés sur la page).
- puissance très confortable
- homogénéité de la bande passante
- la qualité ne s'écroule pas à forte puissance, l'écoute n'est pas fatigante et la distorsion reste très, très contenue
- devrait être très apprécié par les amateurs de rock et blues qui aiment les sons "ronds et chauds" façon vinyle (question de goût car je préfère une restitution "analytique", qualifiée de "froide"); devrait aussi très bien convenir aux amateurs de symphonique qui aiment le son "allemand": graves présentes, médiums doux et aigus modérés
- j'ai dit adieu à l'onéreux transfo torique de 225VA et ses gros condensateurs, remplacés par l'alimentation Mean Well RS-100 24 à 30€ et ses borniers à vis très pratiques. Il n'y a évidemment aucune harmonique parasite et le son est très propre. j'avais déjà apprécié ces alimentations blindées de qualité industrielle dans d'autres montages.
Conclusion: il m'avait fallu des semaines pour construire mon ancien ampli, bobinages compris, et seulement deux heures pour le reconstruire avec ce module. J'ai l'impression d'avoir retrouvé le NAD qui avait précédé le mos fet mais cette fois l'électricité est utilisée à 90% pour produire du son au lieu d'en gaspiller 60% en calories. Je conseille vivement ce module aux débutants ou aux auditeurs pressés et un peu radins qui aiment le son vinyle, cherchant une électronique très bien réalisée, de petite taille, ne nécessitant pas de radiateur (il est intégré) et ne présentant aucune difficulté à installer.
Gregory P.
IBASSO SR2 Dynamic Open Headphone 50mW 24Ω 108dB 3Hz-40kHz The iBasso SR2 is an open-structured headset with all the features of a high-quality audiophile headset. Its dynamic drivers combine the advantages of Silicone suspension with...
Excellent headphone for money
Wow. Great build quality. Beautiful balanced sound - excellent detail but all strung together - True legato, allowing hours of listening pleasure. Also very comfortable. Used with Astell & Kern SR25. No problem driving them direct. Great combination
Karl P.
CLOUDYX CL-250W A31 Amplifier WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm The CloudyX CL-250W A31 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It supports WiFi 2.4G and Bluetooth...
Oui, il existe !
Si comme moi vous avez cherché un peu partout sur internet des informations sur cet ampli, je vais essayer de faire office de documentation.
Je l'ai reçu en 2 jours bien emballé comme toutes mes commandes audiphonics. J'ai été tout d'abord surpris par le minimalisme du packaging, il n'y a pas de notice, pas d'informations, et même pas de piles pour la télécommande ! Il vous faudra 2 piles AAA pour cette dernière.
Je vais tout de suite parler du principal défaut que j'ai pu lui trouver ; les boutons 'volume -', 'wifi' et 'mute' de la télécommande affectent aussi ma télé Hisense, mais je pense que je suis un cas particulier et que si vous avec une autre télé vous ne devriez pas avoir de soucis.
Coté entrées/sorties tout fonctionne, notez que la sortie ligne est controlée par le bouton volume, ce qui peut être aussi un avantage si vous y connectez un appareil sans télécommande comme un ampli casque.
L'entrée Wifi correspond entre autres à airplay, pour connecter votre appareil au réseau wifi vous aurez besoin d'une application chinoise obscure 'Muzo Player' qui en profitera pour récupérer vos données de localisation. La bonne nouvelle c'est que vous pouvez la supprimer après le paramétrage, et votre ampli se comportera exactement comme un appareil airplay classique. Pour plus d'informations sur le paramétrage j'ai trouvé une vidéo youtube perdue : /watch?v=h-6jO_g3h8k . Remarque : la led qui correspond à l'entrée Aux et Wifi est la même, mais on peut quand même sélectionner l'une ou l'autre en appuyant sur le bouton volume.
J'ai branché un dt1770 pro (250ohm) sur la sortie casque et le son est très bon. On sent que l'impédance est un peu élevée pour ce petit ampli quand on met des musiques très punchy mais rien de grave, sur les musiques plus 'douces' le son est très propre.
Je n'ai pas encore branché mes enceintes dessus car je ne les ai pas reçu, je ferai une update si jamais je remarque quelque chose de particulier, mais je ne me fais pas de soucis.
Il n'y a pas de 'patins' dessous comme peuvent le laisser penser les photos, mais ce n'est pas très grave on peut en rajouter facilement. J'ai essayé de retourner les faces latérales pour pouvoir le fixer sous une planche de meuble, mais c'est malheureusement impossible car les faces supérieures et inférieures ne sont pas symétriques, si vous voulez faire ça il vous faudra bricoler un peu.
Dernière remarque sur le bouton marche/arrêt qui est très agréable, avec un contour en métal, et un éclairage blanc quand il est en marche. C'est un bouton physique qui reste enfoncé quand l'appareil est allumé, et reviens en avant quand on l'éteint.
En conclusion je dirais que c'est vraiment un bon petit ampli, ses petits défauts se font oublier quand on voit son prix, sa taille, et son look.
BRUNO B.
très bon ampli
J'avais un AD18 dont j'étais satisfait, couplé avec des infinity kappa 6.2. Le son était cependant un peu limité pour ma pièce de 35 m2.
J'ai donc acheté le A8 au vu des critiques positives.
J'ai eu de la chance, j'ai acquis l'un des tout derniers avant arrêt de la vente.
Et celui-ci va plus loin dans tous les domaines.
Je viens d'acquérir des infinity renaissance 90, et là, c'est prodigieux !
Ils se marient parfaitement ensemble. Les enceintes sont bien tenues, la puissance est là, mais aussi une grande finesse, et un réalisme saisissant.
Je pense être parti pour de longues années de plaisir, tout en essayant d'améliorer les autres éléments de la chaine.
ALBERTINO GOMES A.
Merci Audiophonics
J´ai demandé un avis pour acheter un cable avec 2 metres car je voudrais conecter une barrete de secteur un peu plus loin de la place ou j´ai tout le sistéme. Je suis trés ,trés satisfait car la recommendation funcionne trés bien ,c´est un cable plus précis ,plus neutre et meloudieux que le Yarbo 7000 que ´avais avant. Maintenant la combination Yarbo 8000 sur l´ampli ,le 7000 sur le cd et l´Elecaudio sur la barrete funcionne trés, trés bien. Je veux dire ,de novo, excellent service ,livraison trés,trés rapide ,merci Audiophonics pour votre bon service
Hervé F.
Changement d'écran !
Ces câbles m'ont fait passer du 4/3 au 16/9, d'un LCD 46" à un écran 4K Oled 55". J'avais déjà un beau rendu, j'ai le cinéma scope maintenant.
Juan A.
TOP-CLASS CABLE
I am a happy owner of the 1.3m version. so I already knew the benefits of this cable. I needed to replace the original cable on my Audio-Technica ATH-MSR7 headphones with a higher quality cable so I went straight back for this 3m Furutech. This cable is beautifully finished and constructed with the highest quality materials that provide incredible excellence in sound. Well done Furutech! and Many thanks Audiophonics!
Mario C.
Révélation
Sur mon système amplification tubes ce câble est une vraie révélation. Belle ouverture et scène, rendu naturel avec détails sans froideur et bonne assise dans les basses. Les percussions sont très très bien rendues et les timbres d'une justesse et d'une profondeur remarquables.
Noel R.
manque repèrage
Pas de marquage de couleurs (noir -rouge) par exemple.
Clément E.
Un bon tube
Utilisé dans un ampli hybride, et comparé au fameux tube 6922 Electro-Harmonix, ce tube-ci présente une sonorité plus chaude, plus douce, plus relaxée, plus "naturelle" (même si ce dernier point sera bien évidemment plus subjectif).
Cela se paye en revanche au niveau de la scène sonore, qui devient plus confuse, moins précise, avec une perte de détails importants. Les aigus sont en retraits, ce qui permet cependant aussi de les rendre moins agressifs pour ceux qui y seraient très sensibles.
Au final, un bon tube, qui pourra convenir à ceux qui recherchent une sonorité chaleureuse avant tout, même au prix d'un son moins précis, ce qui est généralement la contrepartie d'une sonorité chaleureuse de manière générale.
Comparé au tube 12AU7 de JJ, celui-ci conserve une sonorité moins chaude, les tubes 6922 n'étant pas réputé de ce côté-là.
Serge H.
mieux que des filtres plus chers
Très surpris de la qualité de ce filtre.
Douceur, précision.
Marche bien mieux que la Dynavox 4100 et la bada 5600.
Seukl regret : aucune notice pour indiquer plus de précisions sur les caractéristiques et l'ordre de branchement par rapport aux autres modèles.
Carlos N.
Excellente musicalité
Câble incroyablement excellent, le médium est très fouillé avec énormément de matière, le grave descend très très bas mais de manière linéaire, l'aigu est détaillé équilibré sans aucune dureté. S'est câble que je qualifie de transparent surtout avec les enceintes haut rendement et avec un ampli à tubes triode. Pour la musique classique et le jazz ce câble va vous surprendre. Je vais bientôt pouvoir l'essayer sur un gros triode 845 Line Magnetic Audio et voir ce qu'il a vraiment dans le ventre. Actuellement je l'utilise sur une paire de triode 6CA7 et une paire d'Elipson prestige 4i et je doit avouer que ce câble est le mariage idéal pour l'ensemble que je possède actuellement. Dès que je possèdrais le Line Magnetic je posterai mon avis sur ce nouveau mariage.
Carlos N.
Excellent connecteur
Excellent connecteur banane verrouillable que je recommande fortement
Laurent H.
Très bon produit pour une taille vraiment miniature
Radu Bogdan D.
DD DJ44C Adapter Female Balanced Jack 4.4mm to Male Single-Ended Jack 3.5mm Gold Plated This adapter consists of a female balanced Jack 4.4mm connector and a male single-ended Jack 3.5mm connector.  It benefits from a very nice quality design with a robust CNC...
Great product
The item is very nice manufactured, both esthetically and technically, great service and communication with audiophonics, highly recommended!
Sébastien K.
bon produit, supporte les codecs annoncés
Utilisé purement en numérique, je n'ai pas testé le DAC. Fonctionne très bien en LDAC en conjonction avec un DAC externe, affiche le morceau joué comme indiqué.
Christophe L.
A deux c mieux
Deuxième avis après achat d'un autre ncf. Le secteur chez moi est pas terrible passé de tri à mono donc ligne chargé. Avec le deuxième le côté 3d est encore plus réaliste plus de dynamique de détails de vie on a l'impression d'avoir les artistes en face de soi. Cette article est à mettre dans un système aboutit j'ai fait l'essai chez un ami qui n'a rien juste ampli et enceinte résultat pas terrible donc il faut travailler le reste avant autrement c'est un achat à faire surtout le deuxième qui donne plus de dynamisme et de détails. Même la tv ce trouve amélioré je suis passé d'un full HD de 13 ans à un 4k (lol non) mais ça a un réel impact. Cordialement
Yves V.
Excellent produit, je l'utilise pour alimenter mon ordinateur portable en 19V à partir d'une batterie 12V chargée par un panneau solaire.
Sébastien K.
Utilisé en sortie ligne et casque, du 44.1KHz / 16bit à 192KHz/32bit (mais pas en MQA). Son irréprochable. Seul petits défauts :
- un petit ploc audible lors du changement de fréquence d'échantillonnage
- semble chatouilleux concernant la qualité du cable USB. Avec un câble qui ne posait pas de problème avec un DAC plus ancien (Nuforce Icon), nombreux petits parasites très audibles, qui ne disparaissent pas en jouant sur le réglage de PLL. Pas de problème avec le câble fourni ou un autre câble en ma possession cependant.
des qualités...
et des défauts...le haut médium est fatigant à la longue.Il apporte de la précision de l'ouverture etc, c'est assez bluffant au début...mais manque de polyvalence à mon gout...très bon câble mais si vous appréciez la matière et de la couleur, passez votre chemin.
Marc V.
Great sound and great value for money
The SMSL AD18 works as advertised. All to connectivity options makes this a real work horse which you can use in many different configurations. I mainly use it with ChromeCast Audio (Toslink input) to play from ROON or TIDAL. It works like a charm and delivers good sound. You get the best sound with warmer sounding speakers. I have tested vintage PSB Alpha B1 / Wharfedale Denton 2XP / Wharfedale Diamond III and got very good results. There is plenty of power to drive a wide range of speakers and deliver relatively loud output.
