Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
Customers reviews - There are 19516 reviews.
Hugo Darien O.
very good
is litle on the warm neutral sound is best for piano music
Hugo Darien O.
very good
is litle on the netral bright side good for movies and general calm music
Sergey O.
Normal sound
I bought 4 pairs of different operational amplifiers and changed them to Aiyima T1 Pro, A80 and absolutely no difference in sound with the pre-installed NE5532P. I don’t know why everyone is so excited about replacing opamps even on cheap amplifiers like the Fosi V3, I didn’t notice any difference in the sound.
vincent j.
Très bonne fiches à un prix dérisoire.
vincent j.
CANARE 4S11G STAR QUAD Speaker cable OFC Copper 4x2.08mm² Ø10.7mm This is the CANARE 4S11G cable, a perfect speaker cable for quality bi-wiring at a low price. This cable has 4 conductors made of high quality OFC copper, with a very long life...
Hi-fi pas chère.
Rapport qualité prix imbattable avec fiches bananes cuivre OFC . Câble neutre respect de la qualité de l’enregistrement. À recommander.
finesse et resolution
Bonsoir , 3 eme iec 004 sur mon systeme ,la voila sur l alimentation de mon phono ( allo shanti) celle ci remplace une iec iego or , la 004 a une grosse resolution dans le bas medium ,medium ,haut medium, aigu fin qui file, des basses rapide,precises, un poil legere peut etre , pour moi la meilleure iec que j ai testé ! la sonorité de la 004 est basé surtout dans la finesse ,transparence ,rapidité. Franck
Massimo M.
Vgood spade
Good quality, great value for money
Paulius S.
I tried them under CD transport DENAFRIPS Avatar, very satisfied.
Pascal j.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Le Graal...
Stupéfaction, restitution sonore exceptionnelle et immense plaisir.
Dès les premières minutes, sans rodage ( c'est une vue de l'esprit..) le son est exceptionnel
Merci Mr Aubert et bravo à toute l'équipe d'AUDIOPHONICSS
Pack Fosi Audio P4 Preamplifier + Fosi Audio V3 Stereo Amplifier + Audiophonics Wire RCA Cables 75cm We offer you a pack of Fosi Audio products consisting of the Fosi Audio P4 preamplifier, the Fosi Audio V3 stereo amplifier and a pair of Audiophonics Wire RCA cables (75cm)....
Al.ber
Tres bien emballé et reçu rapidement. Service impecable.
idéal en multiplication
Rare sont les très bons amplis avec un contrôle de volume. Alimente avec succès une paire de AMT Radian.je ne suis pas sûr que la puissance assez contenue convienne à toutes les enceintes mais dans la configuration c est idéal et sans concurrence.
Alain M.
Excellent à tout point de vue
Commandé le mercredi soir, livré le samedi matin...parfait!
Excellent lecteur, que ce soit en CD, en Bluetooth ou comme dac externe USB de pointe pour mon lecteur réseau (merci la puce AKM 4499EX ), fonctionnement rapide et silencieux, affichage lisible, pieds antidérapants qui "collent" littéralement au support. Très bonne prise casque testée avec un HD 650 (mais située en face arrière, bizarre...). Interface intuitive on se familiarise avec les menus en 3 minutes. Bon rapport prix/musicalité/ fonctionnalités. Si on veut chipoter : j'aurais aimé une entrée numérique supplémentaire, une lecture sur stockage usb et une télécommande moins "cheap", mais comme il est c'est déjà un top lecteur.
Massimo M.
Vgood connector
Very good quality. Excellent value for money.
Kenneth m.
Great streamer/DDC
It's a great streamer/ddc for the money.
It is a must with Cyan 2 dac, and a good i2s cable, e.g. audioquest vodka hdmi.
It is easiest to use with Roon.
You have to switch off power, and then manually disconnect the Lan or USB plug, when switching between HD streaming musik and the PC.
This is such a small minus when the music or sound for the screen is of such quality.
Deniz P.
Small yet strong!
Connected this to a pair of Dayton Audio BST-1 bass shakers. More than powerful enough, and the unit is super small. Amazing results.
Emmanuel L.
PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 0.5m With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas...
Un réel gain
Comme tous les avis sur les câbles USB, je commence par du scepticisme transformé en conviction.
J'ai changé l'USB fourni avec le DAC iFi Zen One signature pour le connecter à un net-top. L'effet est clairement là, c'est surprenant.
Pour en avoir le coeur net j'ai testé avec un autre câble acheté en boutique hifi pour +/- 50€, idem, gain en précision et détails.
Je ne suis pas certain que cela vaille les 100€ cela dit mais le gain est garantit
Brice C.
Copper Spade Ø4mm (Unit) This robust spade is made of copper, giving it high conductivity. It features a screw locking system and accepts cable diameters up to Ø4mm.
Parfait pour le prix!
Utilisée pour faire des jumper elles assurent un très bon maintient sur des borniers en 8mm.
Christophe V.
Indispensable !
Placé sous ma platine vinyle assez lourde 28kg , ces absorbeurs font vraiment des miracles, en revanche indication du poids plutôt aléatoire il a fallu que j’en mette 8 au lieu de 4 préconisé ,amélioration immédiate de la scène sonore, avec un aiguë beaucoup plus détaillée et un grave plus précis. Indispensable !
Thomas G.
AIYIMA A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2...
Ça marche !
C'est mon première ampli classe D et j'en suis très content pour le moment.
La qualité est plutôt pas mal du boîtier et l'animation de l'ampli est sympa.
J'ai acheté cet ampli pour réutiliser mes Elipson Planet L avec son caisson pour mon ordinateur et ça marche assez fort.
Je l'utilise en optique sur mon pc et les sorties TRS pour ma carte son pour instrument et aucune latence.
Le son est vraiment très bon pour un si petit ampli.
nicolas g.
XDUOO TA-26S Tube balanced Headphone Amplifier / Preamplifier 6N8P 6N5P The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification...
Bonne amplis casque
Fonctionne très bien, bon sons avec un caque SIVGA SV023.
tubes de remplacement Svetlana 6H13C et Electro-Harmonix 6SN7. Jutilise le DAP MECHEN M30 et un cable FURUTECH ADLID-35R. Le tout donne un très bon rendue audio.
Attention la couleur de l'amplis et un bleu/gris.
Le tube 6N8P et le petit tube ET le grand tube et le 6N5P.
Faite attention a la compatibilité des tubes de remplacement, il y a beaucoup de bêtises sur internet.
Nom européen (6N8P- 6SN7) (6N5P-6AS7). Bonne musique.
François C.
IBASSO AMP8 MK2S Discrete Amplifier Module for DX240 Black The iBasso AMP8 MK2S is an improved version of its direct predecessor, the AMP8 MK2. This one embeds better quality capacitors in order to provide perfectly optimized...
upgrade nécessaire
Je ne comptais pas sur un gap important sur un DX240 déjà remarquable...
J'utilise ce DAP avec des intras en symétrique et casque semi ouvert SR2 de la marque. Avec les deux mon DAP chauffait pas mal après deux heures d'utilisation, avec cet ampli ce n'est plus le cas. Au niveau de la qualité d'écoute du mieux un peu partout, graves profonds mediums magnifiques et aigus bien présents, la scène est très large, bref un indispensable !
Robert D.
Happy
Cable installation without any problems. I am testing the sound.
Robert D.
Happy
Beautiful cable. Cable installation without any problems. I am testing the sound.
Robert D.
Robert D.
Happy
Excellent.
Robert D.
Robert D.
Happy
Excellent contact.Silver soldered wire.
Robert D.
Happy
Very good connectors. Non-magnetic.Made from one piece.Excellent contact.
Robert D.
Happy
Very good connectors. No plastic. Non-magnetic.
Robert D.
Happy
Richard P.
J'aime
Équilibre et douceur. Bon câble pour une écoute relax sans agressivité.
Je le préfère au 4 mm Orbit 240.
florent n.
SHANLING CA80 Amplifier Class D ICEPower 100AS2 CD Player DAC ES9219MQ Bluetooth 5.0 100W 4 Ohm Black The Shanling CA80 is a particularly versatile integrated amplifier, CD player and DAC. It performs these tasks brilliantly, thanks to its meticulous architecture and...
So much unfulfilled potential
It's an attractive device and is very well built. kudos to the design team
Sound wise, it's really good. I bought it to supplement my class A Accuphase that draws a lot of juice and which I don't always feel like using for casual listening. Honestly, the Icepower module plays on par with the big japanese amp. The RCA output on an amp is a rare but very useful feature as it allows me to listen to the Accuphase while using the CA80 as a preamp. I can think of Audiolab amps having it and a few others but it's pretty rare. The headphone amp works well.
What disappointed me before the purchase was the absence of at least another analog input or digital input. It would have been great, but that's a compromise I made willingly as it had BT as a fallback solution for my bluray player. Except, that eventhough the bluetooth works flawlessly with a phone if connected to a transmitting dongle, the CA80 BT implementation is buggy. It requires the user to resort to some idiotic procedure to get the sound...and if you switch to another input and back, you will have to do this all over again
For the other negatives, there is - the barebone CD implementation: No resume functionality. you will have to restart the cd from the start each time you switch inputs...
- the god awful remote which has less than 3 meters of range
- the slow response from the the remote and other universal remotes. It's unacceptable and makes using the device beyond a desk use, frustrating. The buttons on the other hand are perfectly responsive. Maybe it can be improved through a firmware update?
- the cd spinning is kind of noisy. Not a problem but I expected better
I will keep it as I can live with the drawbacks but what a shame of what could have been. It'd be a killer device with a couple extra inputs, cd resume functionality and a better remote control and BT implementations
Marc R.
Son parfait. Reste frais.
Très satisfait de la qualité sonore. La source est un Fosi ZD3, connecté en XLR équilibré.
Alimente deux enceintes colonne Jamo. La réponse en fréquence est linéaire. Son bien détaillé.
Un grand avantage de la classe D est que l’appareil génère très peu de chaleur. Je l’ai placé dans un meuble fermé, avec un ventilateur à l’arrière. Il reste très frais.
Un petit inconvénient : le boîtier n’était pas stable, deux pieds ne touchaient pas le sol. Cela était dû aux deux vis avant qui fixaient le panneau supérieur. Les trous dans le panneau n’étaient pas exactement alignés avec le filetage du châssis. Après avoir légèrement desserré les vis, le boîtier était stable. Je pense toutefois qu’il devrait l’être même avec les vis bien serrées.
Sebastian J.
Some serious problems
I bought this device because I found the connection as a CD transport via USB very appealing. Unfortunately, there are three serious problems, which is why I had to send the device back after a few days. Firstly, it takes too long to read the CDs. Much too long. Once the CD is playing, the player makes very loud humming noises, like a poor quality computer CD drive. The last point to mention is some inconsistencies in operation, such as the non-intuitive button assignment on the front of the device and the display, which is far too small. Overall, it's a shame that this device didn't live up to expectations. The quality appearance of the casing was otherwise very good.
Gregory O.
NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm² Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver...
Ethernet RJ45 Cable
Made Ethernet RJ45 Cable out of this to see what would happen. No shielding . Use it to stream Disney 4K and X Box games. had other pure silver cable from A-Phonics on it but this looks better to me. Once broken in this has a wow factor on the right material I have recently found out that NEOTECH SOST-28 Wiring Cable UP-OCC Solid Pure Silver PTFE 28AWG 0.081mm² will fit as well. Thanks A_F for your great company.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
Bien pensé
produit bien pensé, dans la tradition minidsp. Idéal pour alimenter un filtre nanodigi ou autre de la marque.Préamp MC et MM paramètrables à souhait, convertisseur AD performant . alimentation séparée, déjà upgradée avec une LHY 12v faible bruit. Avec une écoute musicale, vivante et naturelle qui met en valeur une petite ortofon quintet blue installée sur une Transrotor zet 1, à merveille !
Jan S.
GUSTARD C2 Digital Coaxial Cable 50Ω BNC 1m The Gustard C2 digital cable with BNC connectors can be used as both a clock cable or coaxial cable, whether with a clock generator, interface or DAC.
Good quality
I bought this one because I have two if them already. Good built quality. I've not compared it with something else. Works flawless.
Jan S.
Small effective amp.
With TPA3255 chip it's a really compact and perfect match to my needs. With tone control i can adjust the sound to fit my situation. Bought 12pcs to a exhibition.
Thierry H.
Découpe IEC
suite à des achats précédents et à des visuels sur le site j'étais persuadé que les boitiers 1U avaient tous une découpe IEC pour l'alimentation j'ai été étonné de voir que ce n'était pas le cas .
sinon les boitiers hifi 2000 galaxy ou slimline sont parfaits ( celui çi est le douzième que j'utilise.....)
Jerome A.
7HZ X CRINACLE ZERO II In-Ear Monitors Dynamic IEM Ø10mm USB-C with Mic Silver The 7HZ x Crinacle ZERO II in-ear monitors are dynamic IEMs that are affordable but no less powerful. An evolution of the 7Hz Salnotes Zero, they feature a number of...
IEM au rapport qualité prix incroyable
Avec un dac/ampli fosi DS2, ce casque est incroyablement bon, tout est là, sans exagération, précis, en mobilité, c'est excellent.
Il place la barre très haut pour un prix très bas !
Bon câble ...
Bon câble, mais un peu fin du niveau du diamètre ext, pour une bonne fixation dans la plupart des connecteurs
Rien à redire, c'est tout bon !
Emmanuel A.
Pas mal
J’ai utilisé ce câble en liaison modulation sur un dac rega et un amplificateur à lampe
Je ne suis pas très satisfait du rendu global
Il manque beaucoup de détails et la scène sonore ne s’ouvre pas comme avec l’autre modèle de la marque
Le l2-t2s qui lui est bien meilleur sur toute les fréquences
Bernard L.
Très utile
C’est tout à fait l’adaptateur dont j’avais besoin.
Pedro V.
DE CONTI TRIO N60 Speaker Stands Black (Pair) De Conti's Trio N60 speaker stands have been designed to position your bookshelf speakers optimally. With a height of 60cm, they bring the speakers to ear level, in a seated...
Very good stands
Despite the affordable price these stands are sturdy built and elegant. I took one star because the supplied plastic bags for mass loading have some holes in them, rendering them more or less useless.
André C.
ATAUDIO Q8RM Male RCA Connectors Ø7.5mm (Pair) This ATAUDIO Q8RM male RCA connector features 24k gold-plated pure copper contacts. Their metal and carbon-fiber body provides insulation against interference, while the...
Satisfaction
Depuis longtemps je rechercchais des connecteurs RCA de bonne facture qui de par leur diamètre (12mm) pouvaient faire le job sur un Revox B77 , sur lequel les prises RCA sont très resserées .
Ces connecteurs montés avec du Sommercable Olbédo sont parfaits.
BRUNO B.
NEOTECH NEUB-3020 Cable USB-A Male/USB-B Male 2.0 Gold plated 24k OCC 1m The Neotech NEUB-3020 USB AUDIO class 2.0 cable offers superb digital playback quality using innovative technologies that challenge the hierarchy of high-end USB cables.
J'avais déjà un câble USB de qualité.
Lisant les avis, j'ai tenté le coup.
Je suis impressionné par le résultat.
A la fois plus de douceur et de présence.
Des basses enfin à la hauteur, très nettes et propres.
Mon matériel : ampli SMSL A8 et enceintes Infinity Renaissance 90.
Petit boîtier parfait ?
Ça y ressemble !!
Connecté au Mac Mini en USB il a été immédiatement reconnu par Audirvana, décode tous les formats (Mqa compris) et il est relié à mon Dac en Spdif.
Il est très plat ce qui m’a permis de le glisser sous mon Dac.
Envoi rapide et sécurisé.
Jerome A.
AUNE S17 PRO EVO Discrete Class A Balanced Headphone Amplifier Preamplifier 7500mW 32Ω Black With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features...
Une main de fer dans un gant de velours !
Cet amplificateur est puissant, il devrait alimenter sans problème la majorité des casques, même ceux gourmands.
Pur classe A, comme mon Singxer Sa1, il est plus chaud, dans tous les sens du terme... la chaleur dégagée par cette ampli m'inquiète sur son espérance de vie, et son utilisation en été ?
Mon Singxer SA1 est un peu moins bon, mais pas ridicule, et surtout il ne chauffe pas autant.
La fonction permettant de modifier le courant "50mA ou 100mA" n'est pas toujours facile à entendre, selon le casque, et d'après mon expérience, il faut attendre quelques secondes pour l'entendre... ce qui ne facilite pas les tests. Je laisse à 100Ma pendant l'écoute, et bascule à 50Ma lorsque je pose le casque pour quelques minutes/heures, ainsi il redescend en température (Max 55 degrés après 3H avec 21 degrés dans la pièce).
Belle finition, mais bouton de volume peu précis, et toucher/feeling bas de gamme, c'est vraiment dommage.
J'utilise la télécommande pour régler le volume, plus précis, et plus agréable que ce bouton, point faible de cet ampli.
Si vous avez le budget, très bon ampli, sinon pour 50% du prix, le singxer SA1 est très sympa aussi, et il chauffe beaucoup moins.
A l'heure ou j'écris ce commentaire, un kit vendu sur ce site permet de bénéficier du casque Audio Aune AR5000 pour un prix très sympa, je ne l'avais pas vu avant...
