Richard M.
Bernard g.
Excellente Interface
Jacques K.
Etonnant...
Expédition soignée et rapide: bravo!
Mais...commutateur dysfonctionnel : une cosse cassée, dessoudée du contacteur rotatif.....
Customers reviews - There are 19550 reviews.
Stephane Y.
Tout d'abord fil de Litz très facile à étamer à la température de 320 °. La longueur fournie permet de câbler deux bras. Les couleurs des isolants sont faciles à identifier. Bref impeccable.
Emanuele Davide Ludovico G.
I needed something to reproduce liquid music to my Revox system (a76, a77 & a78). I used an old asus vc60 with Daphile streaming music out of its 3.5mm jack. When this DAC arrived it changed my world! I am no audiophile and I lack in the correct vocabulary, so I'll say that its like watching a poster when you were used to look at a postcard. Everything sound bigger (not louder, but wider), sounds are more clear and distinguishable. To me it's a new listening experience. Very good product, I'm afraid I cannot listen to music without it from now on!
Thomas Z.
Worked without problems right from the start. The need for unsoldering and re-soldering the 0R SMD "resistor" for using wih a dual power-supply is unconvenient, much better here would be a jumper with two positions.
Sound wise (until now I only used the optical in) already great, really met my expectations. Output stage with elco's in signal path leaves room for individual improvements.
Frederic F.
Service Audiophonics impeccable.
Frederic F.
Frederic F.
Frederic F.
Frederic F.
Thomas Z.
R-CORE Transformer 30VA 2x115V to 2x15V 1A This R-Core transformer is ideal for powering a DAC or preamplifier. It has one primary 2x115V and two secondary 15V 1A
Great look&feel with the copper sheet wrapping at the outside.
Works flawless and buzz-free, which is important to me.
Frederic F.
Excellent rapport qualité/prix.
Branché par l'entrée usb au pc, il offre une restitution sonore de haute qualité.
Thomas Z.
Dual Linear Power Supply Module LT3045 LT3094 +/-15V This dual regulated linear power supply module provides a clean and stable DC electrical signal with a noise level close to 0 by using a positive LT3045 Ultrahigh PSRR linear...
Production quality and quality control not the best - loads of flux on the board, and solder short-cutting 3 pins of the LT3045. So check your board carefully before bringing it into operation.
After cleaning and solving issues, the module worked well.
Frederic F.
Excellent petit ampli/dac et rapport qualité/prix.
Parfait pour une utilisation dans mon bureau avec Foobar sur pc comme source numérique et enceintes Q-acoustics légèrement mat.
Sa puissance et ses qualités sont suffisantes pour une utilisation salon (enceintes 89/90 db de sensibilité) , sans atteindre le niveau d'un ensemble de bonne qualité à 700 e.
Frederic F.
Je pense que c'est un buffer (à intercaler entre source dac/platine laser et ampli intégré) avant d'être un véritable préampli.
Pas convaincu branché directement sur ampli puissance (gain inadapté, impossibilité d'affiner le volume).
En tant que buffer il apporte la chaleur et un certain relief propre aux tubes assez séduisant, mais entame un peu la transparence et l'ouverture.
Renforce légèrement le bas du spectre, il peut être utile pour adoucir un système un peu dur.
rapport qualité/prix excellent.
Frederic F.
J'ai remplacé le tube Chinois d'origine sur mon ampli casque Bravo audio v2 par ce modèle.
Amélioration à tous les niveaux, notamment diaphonie moins élevée que j'avais constaté avec le tube d'origine.
Davide S.
Je connaissais pas le site audiophonics, et je suis agréablement surpris par le choix et la qualité des produits. Ce cable est au top pour tout le raccordement électrique de haut niveau. David
Olivier M.
Bravo
Grande rapidité de livraison même en cette période difficile, super.
Produit de qualité pour un prix raisonnable . Très très souple, facile à passer dans un conduit avec une aiguille tout de même. J'ai lu qu'il fallait que le câble se rôde, j'attends, mais ne compte pas sur des miracles . Pour l'instant il me satisfait pleinement sur une chaine de qualité des années 90. Merci
Frederic F.
Dac de bonne qualité, bon rapport qualité/prix mais n'atteint pas le niveau musical d'un Musical Fidelity v-dac 2 qui coute 3 fois plus chère (aération, ouverture et richesse des timbres).
Davide S.
Nikel
Embase schuko parfait avec ça fiche sur internet je usiné la tôle à l'avance super livraison très rapide, je conseille vivement. David
Alain R.
Excellente solution
J'ai utilisé ce presse étoupe sur un gros filtre secteur. (1,2kVA)
Je ne voulais pas de prise IEC, je voulais un câblage direct.
Mon câble secteur était de forte section (augmentée par une jolie gaine tressée de couleur). Ce presse étoupe permet d'être sûr que le câble ne sera pas coudé trop fort.
Attention, il faut un peu de place derrière votre boitier pour laisser passer ce presse étoupe et la courbure naturelle de votre gros câble.
J'ai ai profité pour faire un câble secteur juste à la bonne longueur.
Donc pas de câble qui traîne, qui se mélange, un presse étoupe qui oriente le câble, des couleurs de tresse par type de signal (secteur, numérique, analogique, optique). Ça fait un arrière meuble propre e t ordonné.
Alain R.
Isolated Screw Terminal 7 Ports Ø6,5mm (Unit) Very practical, the domino allow quick and easy connections thanks to a screw system. No soldering required to connect two elements. This model has copper alloy screws and 7...
Pratique ce bornier pour mis à la terre.
J'ai fait un gros filtre secteur à base de transfos RCORE.
J'ai mis le tout dans un boitier plastique pour des raison de sécurité.
Je me suis servi de ce bornier pour relier à la terre toutes les parties métalliques des transfos et les terres des prises de sortie, à la terre de l'entrée.
L'accessibilité par le haut est pratique.
Sándor S.
SMSL SAP-12 Headphone amplifier Class A/B 210mW 32 Ohm Silver Class A / B headphone amplifier with discrete component output stage. Delivers a well-defined sound with a very low distortion rate (0.0003%) and an excellent signal-to-noise...
I use it in combination with SMSL SANSKRIT 10Th MKII DAC, and it sounds terrific! I absolutely recommend it!
Sándor S.
Sounds wonderful! I absolutely recommend it!
Be advised that it'll only come with 1 micro USB cable, so better get another micro USB cable and an AC adapter (used for phones e.g.) for the power/aux. input! It is recommended to connect the aux. input USB to the AC adapter if it used for a PC.
Alain D.
Surpris … en bien
Surpris par ce câble car il ne ressemble pas du tout à la photo. C'est un bifilaire sans gainage extérieur. Mais c'est tant mieux car du coup il est plus souple. Sinon fait bien son travail mais sur un mètre une corde à linge ferait aussi bien mais … en plus raide.
Alain D.
Excellent choix
Encore mieux que sur le plan. Juste ce qu'il faut, là où il faut. Qualité sonore tout à fait convaincante sur des enceintes Focal SIB Evo 2.0.
Dominique B.
conseil a tous et pour beaucoup d'utilisation Rca comprise !
je n'ai pas acheté ces fiches , mais il suffit d'embrocher mâle et femelle ensemble avant de souder ce qui a le double effet de diminuer la température sur les parties plastique par effet d'évacuation de la chaleur par l'autre élément et d'ainsi conserver le centrage pendant la soudure . C'est tout simple !
Jean-Marc B.
Mauvaise qualité
Impossible de faire entrer un connecteur C20 du côté C19 de l'adaptateur: mécaniquement, ça n'entre pas. Encore un truc fabriqué en Chine pour 10 centimes, que Pangea revend bien cher après avoir juste apposé sa marque et collé un sticker TESTED, sans avoir rien contrôlé.
De beaux aigus , mais rien d'autre ...
Bonjour ,
tous mes câbles secteur sont en Cu (câbles et prises), par curiosité j'ai voulu tester un câble plaqué Ag , je l'ai associé à des Viborg VE502G Plaqué Argent / Or , et bien le résultat n'est pas bon , les aigus et l'Ag ce n'est apparemment pas une légende , les aigus montent très haut mais. l'équilibre spectral n'est pas respecté , avec un déficit dans le médium et les graves . Donc écoute désagréable si le câble alimente le dac ou le drive , franchement catastrophique si branché sur l'ampli. On ne peut donc le conseiller que sur un système ou les aigus ont besoin d'être réveillés !!
Christophe D.
détail sur le modèle de Raspberry supporté
vous indiquez que seul le Pi3 est supporté, mais j'ai noté une façade arrière en bambou dispo pour le PI4 /Raspdac mini. Cela m'a fait hésiter et j'ai finalement pris le PI3, craignant aussi pour la surchauffe, ne sachant pas si on pouvait mettre un radiateur supplémentaire entre la carte DAC et le SBC. Un petit complément d'info de votre part serait intéressant je pense (+ orienter sur le modèle d'alim 5V 3A qui va bien ) . Merci
Christophe D.
fonctionne bien
livré préchargé et configuré tel que décrit. Parfait. Reste juste a voir comment sauvegarder la carte (clonage) pour refaire une carte en cas de panne.
Christophe D.
RASPBERRY Pi 3 model B+ 1GB HDMI Ethernet 4xUSB 1.4Ghz The 3B + version of the famous SBC Raspberry Pi is back in force with a faster CPU, a multi-band wifi antenna, an Ethernet port three times faster and compatible with HAT POE...
bon choix sur RAspdac mini
J'ai hésité entre le Pi4 et le Pi 3 et c'est ce dernier que j'ai choisi pour limiter les risque de surchauffe avec le Pi4 . Il s'avère largement suffisant.
Démarrage immédiat avec distribution volumio préchargée.
Christophe D.
nickel
Bonjour, vous pouvez spécifier la présence d'un adaptateur USB A et d'un USB C en plus du micro usb , ce qui est une excellente surprise.
Fonctionne bien avec Raspdac mini et permet de branche le câble USB -C avec interrupteur du kit. Parfait
Christophe D.
satisfait
Montage facile et mise en route simple (Volumio -raspberry Pi3B+ -Alim Ifi 5v 2.5 A faible bruit). Livraison rapide et complète mais le livreur n'attend pas pour constater si un problème sur l'emballage, surtout en ce moment. Trouve le NAs sans problème. Webradio , wouch! il y en a tellement.
Petit détail, le film plastique de protection de la facade avant manquait sur un des cotés , mais comme c'est le coté intérieur, pas vraiment génant (4étoile et demi ).
premières écoutes ok, ça descend bas. Switch entre CD en direct et lecture d'un même fichier numérisé je le trouve légèrement plus doux et les voix sont un peu moins en avant. Mais le lecteur cd n'est pas vraiment audiophile. Bref satisfait du produit après ces quelques minutes d'utilisation.
Angelo P.
moyen
alors voila, je pense que ç'est de ma faute mais le module a griller .sur le descriptif il est ecrit/tension d'alimentation de 12 a 20 volt alternatif, donc j'ai injecter du 14 volt alternatif, bon c'est vrai que j'avais un doute en voyant la tension maxi des condensateurs a 16 volt .et forcement, 14 volt redresser ça fait pas 12 volt continu.enfin bref attention a l alim :12 volt continu et c'est tout!
Angelo P.
tres bien
vraiment tres bien , montage façile, son exellent .pour resumer, simple ,façile et tres bon rendu sonore
manuel R.
ALPS RK16816MG 6 Way Logarithmic Motorized Potentiometer 100k This ALPS RK16816MG potentiometer is ideal for integration into a HiFi device. Its motorization can offer the possibility of remote control via remote control. It is also...
Parfait pour réparer mon ampli ambiophonique
Ce potentiomètre m'a permis de réparer celui défectueux de mon ampli home cinéma Sony STR-DB930QS haut de gamme pour une somme modique. Il était parfaitement compatible.
Frederic g.
Excellent rapport prestation prix
Je viens tout juste de monter (montage avec le tuto très simple à faire) et de mettre en service ce lecteur réseau.
Dès le début, c'est très bon ! une bande passante large et de très beaux timbres. Une bonne lecture des plans sonores et de la rapidité au service de la profondeur de la scène sonore (bien sur, en fonction de la qualité de l'enregistrement).
La gestion du volume est très pratique ainsi que la possibilité de pouvoir basculer sur l'entrée numérique.
J'ai monté dessus un disque dur externe SSD (480 go) ce qui permet d'avoir à porté de clic tous mes CD ripper au format FLAC.
Dans un format très petit, on a un concentré de musicalité et de technologie.
Système :
Préamplificateur DIY Kaneda
Amplificateur DIY 40W classe A
Enceintes Studio Lab SLB 102
Câbles Hifi câbles & compagnies
Wilson C.
Utile
Accessoire bien utile pour éviter l'entrée de la poussière dans les équipements.
Wilson C.
Génial
Un accessoire qu'il est obligatoire d'avoir pour déssouder ! Avant j'avais du mal maintenant c'est fini ! sacré gain de temps et de très bonne qualité.
TRES CONSEILLE !
En comparaison d'autres tubes 300B
(dont le fameux 300B Western NOS) , ce Gold est le plus proche du Western original par son côté "fruité" et chantant.... (Jean Hiraga "himself" est du même avis.)
Précisons que cette version Gold sonne encore un peu mieux que la version de base à peine moins chère qui, hormis qu'elle n'use pas de revêtement or, est moins précise au niveau du montage interne.
Jean V.
Impact et densité
Livré en avance par rapport à la date prévue.
Boitier bien fini et ne chauffant pas.
Utilisé, dans un système multi amplifié, pour le registre grave ( inférieur à 120 Hz).
Remarquable qualité d’impact, de densité, de définition et de tenu des HPs et ceci jusque dans l’infra.
A conseiller sans réserve pour la reproduction de ce secteur !
pierre C.
Excellent Budget amps
Pour débuter ce fda ultra compact est excellent malgré des composants premiers prix qui datent. Tout marche parfaitement, le son est excellent avec n'importe quelles enceintes moyennes et haut rendement. Pas de défaut ni de nuisances sonores en entrée usb.
Il y a surement pleins de choses à améliorers selon ses gouts et son utilisation (film, style de musique, expérience, enceintes, grandeur de la pièce, branchement) .
C'est mon deuxième achat ici, les avis semblent etre tous vrais, Je suis très content de mon achat dans cette boutique qui est connu dans la niche audio en Europe et qui présente un large choix de dernières technologies avec un rapport qualité/prix/service/sav imbattable et une livraison très rapide. Even lot of foreigners are buying in this excellent shop at very price.
You can buy here the latest or very rare components for your audio and enjoy music as never you did before!
Gabor T.
Gabor T.
Good item, original.
Gabor T.
ELNA SILMIC II RFS Aluminium Audio Capacitor 35V 100µF The Silmic II RFS (ROHS) series is a high-end series of capacitors from ELNA with superior acoustic qualities. The electrolytic separating paper used for this series contains...
Gabor T.
AUDIO-GD DA-8 DAC Module R2R 24Bit / 192kHz Mono (Pair) The DA-8 module from Audio-GD has a 24-bit DAC based on a resistor network. 2020 version with 3 I2S inputs and phase inversion selector.
Very good service. The product is excellent, fully working, good sounding.
Marc P.
DAYTON AUDIO DCS205-4 Classic Speaker Driver Subwoofer 150W 4 Ohm 89dB 30Hz - 200Hz Ø20cm Subwoofer speaker for repair / construction / prototyping. Diameter 20,3 cm. RMS 150W
Correspond à ma demande, produit arrivé rapidement et monté dans mon sub en remplacement d'un ancien et la différence est enorme !!
Bertrand S.
Très bien mais...
Très bonne qualité de fabrication. Je les ai choisies après de longues recherches sur internet et je pense que ce sont celles parmi les mieux conçues. Ces fiches bananes sont bien pensées avec leur système de serrage qui les solidarisent bien au bornier sans avoir à forcer pour les y entrer... Matériaux sérieux et robustes. Attention cependant à choisir un diamètre adapté à vos câbles. Les câbles QED XT tube par exemple sont très larges, j'ai réussi à les y entrer en les serrant très très fort mais pas évident du tout... Bon maintenant sur l'avis d'écoute... La première impression est plutôt satisfaisante : tout simplement l'impression d'une meilleure définition sonore et d'une meilleure spatialisation !... Mais après rodage, j'ai finalement décidé de ne pas les garder et de remettre les fils à nus (même si je n'aime pas l'impression que cela donne de "bidouille sur les borniers"). Car ils amenaient clairement une brillance sur les aigus. Réduisaient finalement le spectre sonore (l'impression de définition initiale était trompeuse) et les basses étaient devenues très lointaines... Grosse frustration au final... Ah la la l'audiophile cherche et ne trouve pas toujours. Il faut accepter ses échecs et allers-retours. Peut-être que c'est exactement ce dont vous avez besoin pour votre système, ou peut-être pas (PS mon système hifi : Ampli à tubes Line Magnetic LM211, lecteur réseau BLUOS, câble RCA ATLAS, câble enceintes QED XT400 et enceintes Audiovector QR1)
Nadjim K.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 2.2µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
Belle amélioration
Sur des enceintes vintage de 1978-1980 (Optonica CP-4500H) remplace un Nichicon plastique (jaune) en série sur la ligne d'un tweeter. Ce condensateur a permis une belle amélioration de la précision et du réalisme de la scène sonore, offre une meilleure cohérence d'ensemble et a grandement abaissé toute dureté dans les aigus tout en donnant plus de précision dans ce registre.
C'est moins spectaculaire que le recablage de la semaine précédente (gain en dynamique et définition) mais bien plus que le changement de tous les autres condensateurs par des SCR MKP fait encore avant.
Ces constatations sont partagées par plusieurs personnes.
Dans l'ensemble je suis très content de cet achat, mes enceintes sont transfigurées alors que pas mauvaises à la base.
Bonne journée.
Didier V.
un rapport qualité/prix imbattable
Ce petit préampli donne vraiment de très bons résultats. Il délivre un son très clair et détaillé bien plus agréable que mon préampli home-cinéma Marantz. J’ai eu juste un problème au début car la masse et la terre sont reliées dans le préampli et chez moi cela générait un ronflement désagréable (la connexion est faite au niveau des colonnettes qui supportent la carte électronique selon Audiophonics). En attendant de faire mieux, j’ai isolé la terre au niveau de la prise secteur et tout est rentré dans l’ordre (merci pour les conseils d’Audiophonics toujours très réactif).
Pour être parfait il faudrait à ce préampli une sortie casque intégrée ou une double sortie du préampli pour brancher un casque externe. Sinon au niveau des petits points d’amélioration, le bouton de sélection des entrées n’a pas de repère ce qui n’est pas très pratique pour voir l’entrée choisie et la quatrième position de ce sélecteur est dans le vide ce qui permet d’avoir un mute mais pour ma part j’aurais préféré une quatrième entrée. Pour finir dans le détail, la LED rouge en façade est très puissante, un peu trop à mon goût.
Pour la qualité de fabrication il n’y a pas grand-chose à dire : boitier métallique solide, carte électronique bien montée et sans reprises mais quelques traces de solvants ou autre produit (sans gravité). Mon seul reproche serait dans le raccordement de la carte aux prises RCA. Les soudures sont limites (soudures froides) et la masse est soudée directement sur le corps de la prise et non pas sur une cosse (quel dommage car en plus ils ont dû avoir un mal fou pour souder ces fils !).
En conclusion : un rapport qualité/prix imbattable.
Antonio V.
MUNDORF E-CAP ECAP70 (BG50) PLAIN Capacitor 70VDC 50VAC 1µF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Modification filtrage HP Klipsch RF83
Après l'achat de paires d'enceintes Klipsch RF83 je me suis rapidement rendu compte que le son sortant du pavillon était comme a gressif (haut medium) et étouffé, j'ai donc pris l’initiative de bypasser la partie du filtrage aiguës , et après plusieurs test avec des valeurs différentes 2,2/1,5/1uf c'est ce petit dernier qui m'apporte enfin les aiguës dont je rêvais, fini pour moi l'agressivité et l'étouffement du pavillon du à l'étrange manière dont Klipsch a voulu bridé celui. Merci audiophonics ;-)
