PANGEA PREMIER XL BALANCED Balanced Interconnect Cable XLR-XLR 10m
This Pangea Premier XL Balanced XLR to XLR modulation cable is exceptionally well made. It is composed of Cardas Grade One copper strands with PE tube insulation and Al Mylar aluminium foil shielding, silver-plated braided copper and carbon-filled PE tube. The triple-layer shielding provides this cable with effective protection against RFI noise and EMI interference.
By buying this product you get 79 loyalty points
Reference : 21017
790,00 €tax incl.
658,33 € tax excl.
Pangea Premier XL Balanced Balanced Interconnect Cable XLR-XLR Copper Cardas 10m (Pair)
PANGEA PREMIER XL BALANCED : Front view
The topology of this cable is truly balanced, with three conductors plus a separate ground, rather than two conductors and a separate ground as found in falsely balanced cables. It provides a high level of transparency and detail, particularly in the high and low frequencies.
Pangea Premier XL: High-quality XLR 500 connectors
This Pangea Premier XL Balanced XLR modulation cable features high-quality XLR 500 connectors. Their contacts are gold-plated and incorporate effective polymer insulators and a high-quality locking mechanism. A black chrome plating also embellishes the connector body, which is resistant to chips and scratches.
PANGEA PREMIER XL BALANCED : View of connectors
Pangea Premier XL Balanced cable structure
PANGEA PREMIER XL BALANCED : cable composition diagram
1Conductor 1: Cardas grade 1 copper
2Conductor 1 & 2: Cardas grade 1 copper
3Transparent PE tube
4Insulation 2 & 3: PE tube
5Insulation 1: PE tube
6Shield: Al mylar aluminum
7Shield: silver-plated copper
8Shield: Conductive PE black
9Jacket: TPR black
10External sheath
Product typeXLR interconnect cable
Conductor materialCardas grade 1 copper
InsulationPE (polyethylene) AIR tube per conductor
BlindageAL Mylar aluminum foil
Silver-plated braided copper
Carbon-filled PE tube
Connector contacts materialCopper alloy
Connector contacts platingGold
Cable length10m
PackagePair
Length (m)10.0
ShieldingYes
Section (mm²)N/A
ConnectorXLR
Conductors material (Cable)Cardas Copper
PANGEA PREMIER XL BALANCED Balanced Interconnect Cable XLR-XLR Copper Cardas 10m (Pair)
This Pangea Premier XL Balanced XLR to XLR modulation cable is exceptionally well made. It is composed of Cardas Grade One copper strands with PE...
