MEZE 105 SILVA Headphones
The Meze Audio 105 Silva is a high-performance open-back circum-aural headphone. Tuned with a perfect balance of musicality and refinement, the 105 Silva delivers clear, rich and engaging sound effortlessly. Transients are fast and articulate, bringing out complex details with natural ease. Highs extend gracefully, soft but revealing, while bass remains tight and well controlled, never overpowering but always present when needed.
Reference : 21016
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 17-11-2026.
Meze Audio 105 Silva Headphones Open-Back Dynamic Ø50mm 45 Ohm 112dB
Meze 105 Silva
Meze Audio 105 Silva: A timeless masterpiece
Rooted in the mid-century modern movement, the design of the 105 Silva follows the fundamental principles of clean form, functionality and durability, while seamlessly integrating natural and modern materials into its construction. Fusing vintage charm with contemporary aesthetics, the radial grille intertwines sublimely with walnut wood to form the ear cups, creating a feel that never really ages. The flexible steel headband and PVD-coated cast zinc alloy components form an extremely robust, yet highly flexible structure.
Meze 105 Silva
Meze Audio 105 Silva: A speaker designed for audiophiles
In order to achieve a sound suitable for audiophiles and music lovers alike, numerous 50mm drivers have been tested, with different materials and tuning methods. The result is designed to satisfy the widest possible range of musical genres.
W shaped diaphragm
Made from a carbon-fiber-reinforced cellulose composite, the diaphragm can reproduce high frequencies with incredible precision, clarity and definition. Not only more durable than conventional materials used in conventional dynamic loudspeakers, but also lighter, this composite reduces resonances that can lead to harmonic distortion.
Titanium-plated torus
The torus surrounding the membrane is made of a titanium-coated semi-crystalline polymer, designed to optimize rigidity, speed and tonal balance. The titanium coating, applied by physical vapor deposition (PVD), reinforces the structure of the diaphragm while keeping it light, guaranteeing rapid transient response and pleasantly textured bass.
The torus features grooves precisely positioned at an angle of 45.5°, effectively controlling resonances and enabling the driver to reproduce sound with precision and fluidity.
Stabilized loudspeaker
The copper-zinc alloy stabilizer, placed around the diaphragm, improves vibration absorption to further reduce distortion.
Meze Audio 105 Silva headset diaphragm
Meze Audio 105 Silva: A vibrant contrast
The Meze Audio 105 Silva offers a harmonious blend of clarity and richness. Thanks to a combination of perfected tuning methods and carefully selected materials, it distills the essence of what makes music so rich: virtuoso finesse combined with raw, unrestrained pleasure.
Meze Audio 105 Silva: Perfect comfort
Enjoy your music for hours thanks to Meze Audio's ergonomic manufacturing philosophy. The self-adjusting PU leather headband distributes weight to provide even pressure for all head shapes and sizes.
xxx
Meze Audio 105 Silva: Velvet pads
Velvet ear cushions surround the ears comfortably, providing optimum insulation to create a natural sound. As velvet is much softer and more breathable than leather, it prevents perspiration and overheating during long listening sessions.
Meze Audio 105 Silva: High-quality cable
The 105 Silva comes with a new 1.8m OFC copper cable with double twist, Kevlar sheath, soft PVC-coated left and right wires and an anthracite aluminum splitter. It's designed to be durable, flexible and tangle-free. Meanwhile, a customized Jack 3.5mm to USB-C adapter with integrated DAC/amplifier expands the possibilities for use with mobile devices, while maintaining high-resolution playback on the move.
Meze Audio 105 Silva: Where music comes to life
The 105 Silva draws you into a living, organic soundscape. Every detail, from its sophisticated design to its finely tuned acoustics, works harmoniously to create a coherent experience.
What's more, in keeping with Meze Audio's philosophy of offering long-lasting products, the 105 Silva can be disassembled and serviced again and again if necessary.
Exploded view of the Meze Audio 105 Silva
Product typeCasque audio
Headphone typeOpen-back
Circumaural
TechnologyDynamic
Speaker diameterØ50mm
Frequency response5Hz - 30kHz
Impedance42Ω
Sensitivity112dB/Vrms @ 1kHz
THD< 0.1% @ 1kHz
Headphone connectorsDouble Jack 3.5mm TS
Earcup shell materialWalnut wood
PC-ABS
Weight354g
Package1x Meze Audio 105 Silva
1x Jack 3.5mm 1.8m cable
1x Jack 3.5mm to USB-C (integrated DAC / AMP) adapter
ColorWalnut
Impedance (Ω)45
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)5
Highest frequency (Hz)30000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
Quel son!
Les médiums sont magnifiques.Les voix d'une présence extraordinaire. Le reste du registre graves et aiguës sonnent de toute beauté. Un casque exceptionnel, chaleureux, à découvrir.
This review has been posted for MEZE 105 SILVA Headphones Open-Back Dynamic Ø50mm 45 Ohm 112dB
The Meze Audio 105 Silva is a high-performance open-back circum-aural headphone. Tuned with a perfect balance of musicality and refinement, the 105...
