Claude G.
Super !!
Remy C.
Simple et efficace
Lacking
Customers reviews - There are 19518 reviews.
RENAUD C.
7025 pour restauration ampli Jolida JD202
Un tube de qualité, silencieux, visuellement très solide. Pas exactement le même gain que la 12AX7 d'origine, mais cela ne se ressent absolument pas dans mon ampli.
johan s.
GUSTARD P26 Discrete Class A Balanced preamplifier XLR RCA Silver Gustard P26 is an elaborate preamplifier / volume controller / strain selector (3 inputs). It will delight audiophiles looking for a fully balanced circuit.
Retransmission fidèle du signal reçu
Je l'ai depuis plusieurs mois. Avec un ampli de puissance Atoll. Le son est fluide et sensible à la moindre modification sur le système que ce soit l'ajout d'un dac, un changement de câble et surtout les AOP. C'est les sparkos que j'ai.
Bogdan B.
XDUOO TA-20 PLUS XLR Balanced Class A Headphone Amplifier with Tubes 1x5Z4P 2x12AU7 An upgrade of the TA-20, the TA20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube headphone amplifier now boasts...
An excellent amplifier in its price range
A very good amplifier that deserves every last penny spent, the sound is unexpectedly good and after replacing the 12AU7 tubes with PSVANE 12AU7-S S Series the sound became even better even though the new tubes didn't have time to burn in. And as a bonus it is also very beautiful. I've been listening to it for several days and I can't get enough of it. I recommend it 100%
Bogdan B.
Very good investment
I replaced the stock tubes on an XDUOO TA-20 Plus headphone amplifier and the sound became much better, it became smoother, the bass is richer and the separation is better.
Laurent D.
Bon produit si on est patient et pugnace
Le colis était bien emballé 2 vis n’étaient pas à la bonne taille et un module de carte SD supplémentaire qui n'a pas son utilité (que je vais renvoyer) Le montage est a la portée de n'importe qui c'est vraiment bien fait. J'avais un PI3 sous la main que je voulais utiliser avec ce Mini Dac. Après moult échange d'ailleurs très pros et concis avec le sav on a réussi à tout faire fonctionner sauf la télécommande qui faut avouer, n'apporte pas grand chose passé 3m de distance. Si d'aventure vous vous lancez dans montage, le résultat est vraiment bluffant le petit écran vous donne les image des Jaquettes et Spotyfy avec Volumio fonctionne parfaitement vraiment un très bon Dac Merci le SAV de m'avoir soutenu dans mon challenge. Un point que je trouve un peu léger c'est l’interrupteur style lampe de chevet sur le fil d'alimentation. Je ne mets que 3 étoiles a cause des sueurs froide et heure perdues a le faire chanter
Très bien mais
Utilisé en remplacement des NE5532 dans un Fosi BT20a Pro qui sonnait trop sec, clinique et terme.
Les Oracle 02 apportent de l'air et une image sonore plus large et profonde, ça respire et la musique n'est plus coincée dans les HP. La musique est plus vivante et reprend des couleurs.
Le haut medium aigu est très beau, sans dureté, avec de la matière tout en finesse, du détail, une très belle dynamique. Quelques sibilances sur les voix féminines.
Les registre grave médium est bien, mais pas à la hauteur du reste.
Si le haut grave est bien articulé et percutant si nécessaire, le médium est parfois confus dès qu'il y a beaucoup d'instruments, les voix d'homme et de femmes sont un peu trop lisses et manquent d'incarnation. Les infra-graves sont quasi absents.
Ceci en comparaison d'OP275 tout aussi transparent mais avec une énergie et une matière égale sur tout le spectre.
Bref un certain manque d'homogénéité à mon goût dans cette configuration, la hiérarchie serait sans doute différente dans un autre appareil. On est cependant à un tout autre niveau que les NE5532 d'origine qui équipent le Fosi BT20a Pro.
Guillaume B.
Bluffant!!
Lourd, bien pensé, beau et fonctionne vraiment bien, je ne m'attendait pas à mieux, mais le résultat s'entend, une espèce de tranquillité générale dans tout le spectre sonore.
Je suis content!!
Guillaume B.
AECO ABI-0611S Speaker Terminals Tellurium Copper Silver Plated (Pair) These aeco ABI-0611S speaker terminals offer excellent design quality. They use low-mass contacts made of high-purity tellurium copper with silver 120µ plating, ensuring...
Jolie!
Très belle aspect (mieux que la photo ;) ), au touché ça sent la qualité, qui se vérifie a l'écoute.
Je vous le recommande.
Guillaume B.
SPARKOS LABS SS7812 Discrete Voltage Regulator +12V The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable...
Suite à l'upgrade des composants de la carte d'alim d'un préampli anglais avec un très bon résultat, la pose de ce régulateur apporte une touche de "fond noir" très appréciable sur les silences et du "calme" sur les très hautes fréquences.
J'aime bien mais le tarif moins.
Guillaume B.
Composite Foot Aluminium ABS Rubber 61x23mm Silver (Unit) This stand is ideal to stabilize a device while disconnecting it from an assembly to limit vibrations. It is made of ABS plastic and brushed anodized aluminum. The lower part of...
Bon pied
C'est un bon produit, rigide, bien fait ce qui donne une belle finition.
Marc S.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 3m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
Merci audiophonic
En remplacement d'un rc 400tm.
Gain immédiat ( scène élargie, plus de details, aigus medium basses équilibré).
Câble bien construit.
Un super produit.
Sebastien D.
EVERSOLO H2 Balanced DAC Portable Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 EVERSOLO offers with the H2 a balanced DAC and  portable headphone amplifier  combo wich is compact and powerful. With a USB-C input, it is an ideal companion for...
Bon petit son ce dac, brancher essentiellement pour la voiture avec usb player pro au smartphone belle écoute sur autoradio
Martin A.
Câble utilisé : Elecaudio HP25occ. Sur les photos, les connecteurs semblent bien plus petits qu'en réalité. Pour le soudage j'ai utilisé un brûleur à gaz cfh m20, avec le pistolet à souder je n'ai pas réussi, le liant est du Mundorf Supreme Silver 10%. Une fois que les bornes de l’amplificateur et des haut-parleurs sont bien serrées, elles le restent. Je ne m'attendais pas à acheter des connecteurs en cuivre à un tel prix et d'une telle qualité.
Jérôme B.
Super produit !
Juste sortir le dongle de son emballage, le connecter sur le port USB de la Freebox Révolution, paramétrer la box Alice dans la télécommande Harmony et synchroniser le tout !
Le tour est joué et même pas besoin de changer le Power Toggle !
Tout est nickel.
Anders R.
My second power amp!
Having connected the LPA S400ET in my bedroom stereo I am just as impressed as the HPA S400ET in the TV/cinema room. Both use Sparcos op amps. Maybe I should get a third one for my main rig powering my Magnepan 20.7 The present Bryston 4B is 19 years old now and warranty expires soon. Hmmmm...
David M.
Aluminium Foot Ø30x15mm M4 Black (Unit) This foot is ideal to stabilize a device while disconnecting it from an assembly to limit vibrations. It is made of CNC machined anodized Aluminium and a rubber ring prevents...
Excellent rapport qualité/prix Pied Aluminium Ø30x15mm M4 Noir
Parfait ! Excellent rapport qualité/prix. Pieds très esthétiques, discrets et anti-dérapant. Il y a mieux mais c'est plus cher. Largement au dessus des pieds d'origine de mon vieil ampli 'NAD'. Dommage qu'il n'y ai aucune vis avec.
David M.
Excellent!! Embout séparateur / Splitter 1x11mm vers 4x4mm Noir
Novice, ma 1ere fabrication de câbles hifi en bi-amplification sur du diamètre 11 millimètres 'SPM440 Eléphant 4 x 4mm2' avec gaine ELECAUDIO GB-05 Gaine Tressée Extensible scotché au extimités. Astuce: prévoir dénudage du cuivre sur 8 cm qui sera perdu pour s'en servir d'aiguille lors du passage en 4mm2, puis poussez tout en tirant et résultat 'Parfait' ! Excellent résultat final !! Mon câble semble très 'pro'. Très content de mon achat .
David M.
Excellent! Gaine ELECAUDIO GB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm
Novice, ma 1ere fabrication de câbles hifi en bi-amplification sur du diamètre 11 millimètres 'SPM440 Eléphant 4 x 4mm2'. Très facile à glisser. Prévoir de la perte. Excellent résultat final! Mon câble semble très robuste et cela fait très 'pro'. Très content de mon achat .
Wayne M.
evo oil
very good service, always find the team to be very helpful, my first time trying the evo oil i will use again impressed thank you
Everaldo R.
XANGSANE SP-8540 Speaker Cable Silver-Plated OFC Copper 2x4mm² This Xangsane SP-8540 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
I'm very happy with this speaker cable.
I used it for my Focal Chora 816's and I have a feeling the highs are a bit more relaxed with these cables than my copper ones. But still a very clear and enjoyable sound with the xangsane sp8540 speaker cable.
Everaldo R.
Very nice plugs for the price, that fitted nicely in my Focal Chora 816's.
jean-christophe D.
AUDIOPHONICS HPA-S300NIL Power Amplifier Class D Stereo Nilai500DIY 2x300W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-S300NIL power amplifier is a high-performance stereo model, based on the new Hypex Nilai500DIY amplification...
impressionnant
je viens de recevoir mon nouvel ampli made in audiophonics.
il est encore en rodage mais je dois dire que c'est "du lourd".
c'est la nouvelle version en double mono total avec deux nilai 500 et deux alim independantes.
la puissance n'a quasiment pas de limite. la definition est totale sur tout le spectre, jusqu'aux tres basses frequences.
Raccorde a mon nouveau streamer matrix (avec roon et qobuz) et aux enceintes Klipsch RF7, c'est top niveau.
bon, les RF7 montrent leurs limites et il va falloir s'occuper de cela prochainement mais pour la partie electronique, je suis pare pour un moment.
Câble qui va loin pour le prix
Câble performant et équilibré, j'aime beaucoup, une belle découverte pour pas trés cher.
Hans Klaus R.
ATAUDIO Q8RF Female RCA Connector Ø7.5mm (The pair) These gold-plated RCA connectors are designed to provide good conductivity and resist oxidation. The conductors are made of high purity copper for a very good transmission of...
Good quality, Easy soldering
made from metal, solid feel, screw thread works smooth and locks firmly. All in all high quality appearance. Easy to solder, soldering points for + and - are on same level and avoids uneven cable lengh cutting to keep them nicely parallel.
Diameter for cable outlet (7.5mm) is only ideal for strong cable diameters - for usual audio lines too spacey (hence 4 out of 5 stars). Make sure you use large diameter audio cable for perfect fit.
Eduard V.
Doet zoals beloofd werkt perfect.
Goed product simpel te installeren (misschien zou het iets sneller mogen werken)
Tom K.
TOPPING D90 III SABRE Balanced DAC 2x ES9039SPro Bluetooth 5.1 32bit 768kHz DSD512 MQA Black Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced...
This is a quality product and the after sales service is very good
I received this DAC only two days after ordering it from the Netherlands.
The sound of this DAC is simply stellar, much better than anything I have heard before (I have heard and owned a lot of DACs inluding the D90se, Linn Akurate DS).
The bluetooth remote gave me troubles so I had to send it back. The after sales service of Audiophonics is very good and reassuring. Which is why I already ordered some other things on this site.
Also the Audiophonics website and tracking system is better than many other shops.
Makoto H.
Superb power amplifier
Firstly thank you for your quick delivery! I ordered the amplifier on Friday night and received it onTuesday noon in Japan! I’ve never experienced a delivery so quick from abroad. Also the power cable was perfect for use in Japan. Thanks again to the people who made this happen.
Secondly the amplifier’s black aluminum body looks nice with RCA connectors at the back as gold accents. So are the speaker cable connectors.
And the sound. It is clear and covers from the delicate sounds such as Miles Davis’s first phrase of The Sketches of Spain and to the wildest bass in Sonny Rollins’s Night at the Village Vanguard with quite ease.
Actually it can reproduce any music, including classical, I throw at it comfortably and without any difficulty. It seems it can drive my speaker to its limit.
The amplifier is superb!
Didier C.
TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio...
Préampli HC ToneWinnet AT-300
Super. En service depuis deux semaines, l'image est sublime et le son également. Je ne l'utilise qu'en HC et 3.1. Même si l'interface peut paraitre dépassée, tout y est et de toute façon, une fois réglé on y revient dessus que très rarement. Rapport qualité prix imbattable.
Qualité du service et emballage toujours au top.
Merci Audiophonics
Cable neutre et transparent mais pas ennuyant à l'écoute , se bonifie avec le rodage et acquiert un très bon équilibre . On entends tous les détails sans agressivité ; timbres respectés . Le rqp est excellent . je serai curieux de le comparer au NFS 6 son grand frère vu la qualité de cette entrée de gamme ?
ERIC C.
Bien pratiques !!!
Utilisé entre ampli un Marantz SR8015 qui possède 2 sorties trigger et 2 amplis Nuprime STA9 n'en ayant pas, ces petits boitiers qui sont équipés de prises 12v font le boulot et alimentent mes nuprimes à la mise sous tension ou arrêt du Marantz, il a fallut créer 2 petites rallonges car les boitiers branchés sur les nuprimes sont en position verticale avec la prise 12v dirigée vers le bas et vue la faible hauteur des nuprimes cela posait problème d’où la petite rallonge entre ampli et boitier.
RENAUD C.
Câble de modulation fin et souple. Très bon rapport qualité/prix
RENAUD C.
Une 12AT7 recommandée
Un bon tube, équilibré, bien construit, très satisfaisant pour restaurer mon petit ampli Jolida JD 202.
RENAUD C.
Professionnel et fiable. Grande qualité pour un prix raisonnable.
RENAUD C.
Professionnel et fiable. Grande qualité pour un prix très raisonnable.
Excellent rqp
Il est préférable de lui connecter des prises sans argent car il propose beaucoup de détails, une belle séparation des instruments et une stéréo superbe.
Idéal pour les dac et ampli classe d.
Bon cable
Utilisé avec un dac préampli, il est a sa place.
Spzcialisation, scène sonore large et bien défini. Détail mais reste plus chaud que je l' aurai pensé, d' après les commentaires. Je recommande
montage impossible
Cette prise est un test de zénitude, si vous ne sortez pas de juron vous réussissez le test.
Quand on réussi avec beaucoup d'effort à connecter ses câbles , la galère n'est pas terminée, il faut maintenant fermer le couvercle.
Pas de bol ça ne ferme pas car les vis des borniers tapent dans le capot , sauf si vous avez mis du fil de 0.5mm :)
Je n'ai pas réussi le test :)
Lancelot B.
Très bon amplificateur
Il remplit parfaitement le job, tout en délivrant une grosse puissance, pour un prix avantageux. Superbe !
Marcel O.
insanely high quality built product, top notch
An absolut fantastic DAC. I love the reproduction of voices, very natural and holografic. One can easily trust the positive reviews on youtube without a doubt. Finally my Pioneer TAD S-3ex front speaker play the music at their best. I am very pleased to highly recommend this product based on my experience.
Dimitri R.
M'a permis de ressortir mon vieux Pi3 pour le transformer en Spotify Connect via Moode Audio (Audiophonics 9023 directement dans la liste des i2s).
Le son est nickel connecté à mon ampli.
Testé sur Picore Player et Volumio, reconnu en selectionnant i2s-DAC. Moode est celui qui réponds a mon besoin avec ce matériel !
Envoi rapide de la part d'Audiophonics, rien à dire comme d'hab !
jean-pierre R.
Phono Preamplifier Board Low Noise OPA JRC5532 This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF...
Idéal pour rénover une vielle platine
Acheté pour "électronifier" ma vielle platine Thorens et choisi pour l'intégration de sa propre alimentation, ce module a pu être logé sous le chassis et a donné entière satisfaction. J'en ai profité pour ajouter une embase secteur IEC et des embases RCA, le tout disponible sur le site audiophonics. Un petit bémol : la position des entrées / sorties RCA qui ne facilite pas la soudure des câbles de modulation.
Merci encore audiophonics pour la rapidité des réponses à mes demandes de précisions.
Hasni Z.
Top qualité.
Bonne épaisseur et résistance une fois réduit.
Bon sèche-cheveux indispensable (merci madame :)
Hasni Z.
VIABLUE Braided Sleeve Blue 13-26mm The diameter of these ducts can be adjusted by 13-26mm. It is possible to overlay 2 layers of braided sleeve, so your cable is even better protected.
Bon rendu final
Pour un câble de 1,90 m, j’ai commandé 2 mètres mais c’était trop juste… solution : j’ai dû réduire la taille du câble à 1,80m + gaine thermo et là c’est nickel !
Hasni Z.
[GRADE S] ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm 1.9m Refurbished product - Grade S 1.9m long pre-cut cable
Excellente qualité de fabrication.
Tout juste monté sans difficulté et un tuto existe sur ce site.
En rodage avec le câble qui va bien sur un Heed Lagrange S.
Hasni Z.
Tout juste montée sans difficulté et un tuto existe sur ce site.
Hasni Z.
Efficace et simple montage
Hasni Z.
Bonne qualité / finition
Produit bien mieux fini que sur les photos de présentation !
Ça respire la solidité.
Edmond P.
Pour mon Raspberry Pi zero 2W je voulais un DAC usb qui ne soit pas énorme et c'est parfait.
J'ai juste ajouter un petit adaptateur micro usb male/usb-c femelle pour faire le job.
Seul petit bémol la puissance de sortie audio est un petit peu faible mais je peux compenser largement avec mon ampli.
La qualité audio est aussi bonne que celle de mon DAC Sabre SA9023.
Rajiv J.
Good preamp for the Gustard R26 DAC
I was looking for a preamp for my Gustard R26 dac, and was torn between the H26 and P26.
I chose the P26 preamp based on some (really helpful) advice from the Gustard support. The choice was driven by the following aspects:
1) I did not need the headphone amp, just a pure preamplifier.
2) I have swapped the LME49860 op amps on the P26 with Sparkos Labs SS2590. The Sparkos pair cost me 250 Euros, which took the P26 to a whole new sound level, that is hard to describe. The LME49720 op amps on the H26 are also on swappable DIP8 switches. However it has capacitors mounted very close to the Op-amps, and the Sparkos OpAmps are big and need space (LxB is 1.1 x 1.1 inch, or 2.8 x 2.8 cm). Gustard was kind enough to send me close up measurements that helped me conclude that the op amp swap would be tricky, or just not possible.
3) The P26 allows you to adjust gain between 0 to +6dB both in the input and output stage, which helps to harmonise and match with components on both ends. The H26 only has +6dB gain option at the output side.
4) Gustard support responded to my question of how both would compare in pre-amp mode with the following reply, I quote: "The P26 is a good choice for a preamp only. The P26 and H26 preamplifiers have different styles, the H26 is tuned a little softer while the P26 is a little clearer & transparent."
All in all, a good choice, as I said..
Ole B.
Keeps everything promised
