André A.
Fais le job
Produit correspond à la description. Très simple d'utilisation, léger compact bref parfait pour lire ou ripper support....
Luca C.
Panos M.
Its more my personal taste
Customers reviews - There are 19586 reviews.
Lages Duran F.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS...
Smsl pl200 t
Excelente, muy feliz
Gracias
thomas d.
HIFIMAN MINI SHANGRI-LA Electrostatic Headphone Amplifier The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET transistors...
Ampli neutre.. transparent et musical
Couplé à un casque stax L700 et 007 magique
Seuls défauts le poids et la chaleur ...bon j'étais au courant ..
Pour reguler la t°... jai rajouter un ventilo a l'arrière 6×6 style imprimante 3D
Jan W.
WIIM ULTRA Streamer DAC ES9038Q2M Headphone Amplifier Bluetooth 5.3 WiFi 6E 32bit 384kHz The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library...
Amazing Streamer/DAC/Preamp
My Chain:
(1)Pro-Ject RPM 1 w/ AT VM95SH
(2) Wiim Ultra
(3) Audiophonics AP300-S250NC
(4) Canton B100
Got the Wiim Ultra in a bundle with the AP300 power amp and I am blown away by what you receive for your money!
The setup, room correction, and so on was done in minutes and it sounds very good out of the box. For phono I needed to push the trebles because the bass was too much, but for tidal the automatic room correction is very good.
It is nice to see the cover art and the phono pre is very nice to have and not too bad for what you pay here!
Can recommend the Wiim, especially with the ap300!
Chafi M.
Fosi audio box5
Super petit preampli phono j'ai une cellule MM ortofon 2m red, j'ai mis le réglage sr 48db, ourahh mon volume est enfin plus élevé la qualité sonore est au rendez-vous détaillé scène sonore bien pleine, bref gain également total sur la qualité sonore , preampli peut cher mais avec une grande qualité, pourquoi investir plus cher!!!!j'ai une patine Technics SL 1500C reliée à mon ampli intégré SPEC 777EX
je conseil ce petit preampli , il sonne vraiment bien grâce à ses composants de haute qualité notamment les petits condos nichicon!!!!
Andreas K.
IBASSO AMP14 Korg Nutube Amplifier Module for DX320 / DX300 DAP Black This iBasso AMP14 amplifier module is specifically designed to accompany the brand's DX320 and DX300 DAPs. Each module is hand tested and calibrated at the factory to provide...
Great improvement
Sound quality of DX320 improved significantly, actually without tube flavour, but in precision as well as in plasticity.
Frank F.
ISOACOUSTICS OREA GRAPHITE Vibrations Absorber Isolator Ø40x27mm (Unit) IsoAcoustics' Orea series of vibration absorbers eliminate unwanted vibrations and provide greater sound clarity and accuracy. The Orea is ideal for use with electronic devices...
Isoacoustics Oréa Graphite
A bien amélioré le rendu du boitier électronique ( alimentant le câble de modulation LEGATO FINEZZA ) léger et posé directement au sol.
Contre toute attente cela s'est avéré bien supérieur en plaçant 4 graphites directement sous les pieds du boitier électronique.
Merci à AUDIOPHONICS d'avoir choisi ISOACOUSTICS.
RENAUD C.
Un ampli OP de très haut niveau
Totalement silencieux, sans distorsion, entrée FET, slew rate exceptionnel, et la capacité de piloter un casque ou des câbles de liaison exigeants. Remplace l'excellent 5532 avec succès
Olivier G.
J'avais déjà un BL-Muse-03 dont j'étais très content.
Le BL-MUSE-01 PRO+ est très discret et fonctionne très bien.
Aucun problème de connexion.
Jean Pierre Ernst B.
Great product
The amp just arrived. Well packed. Well finished. Very good looking product.
Just out of the box the sound is truly astounding compared to my old ADAU1592 based small amp. No more issues with treble. Good solid bass. A lot more detail. Wider and deeper sound stage.
Thanks to Mr. Putzey for such a good design and thanks to Audiophonics for making it available at such a good price.
Great product for a small system with reasonable power needs.
Arvydas V.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 6.8µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Ok
Arvydas V.
Good, but the tolerance could be smaller. One capacitor had 9.5mkF instead of 10
Arvydas V.
good capacitors
Elena M.
Mixed feelings plug
The sound is little bit closed for my taste, but overall good. My main criticism is very loose fit on MF-M5si amp. Cheap Norstone Arran plug fits much tighter, and its the same case even with freeby suplied stock cable. Was expecting much more from Oyaide
Claude T.
IAN CANADA TRANSFORMER I/V Passive I/V Stage Module The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply....
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus vraiment agréable dans ma configuration.
Bien brancher le monitor sur le GPIO du DAC et mettre le volume à 0db… sinon par défaut il est à -40db et donc pas de son.
Claude T.
IAN CANADA DUAL MONO MKII DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
Bonne config
L'ensemble
Claude T.
IAN CANADA MONITORPI PRO Control Center and Signal Analyzer with Display for Raspberry Pi Ian Canada's MonitorPi Pro is a powerful integrated control center and universal OLED display for all types of Raspberry Pi-based audio applications. To install the MonitorPi...
Bonne config
L'ensemble
Giuseppe C.
SOMMERCABLE MERIDIAN SP225 Speaker Cable OFC Copper FRNC 2x2.5mm² Ø8mm Meridian Sommercable SP255 is a two-conductor speaker cable. It is a cable developed to offer excellent mechanical strength and therefore ensure increased durability thanks to a...
Complicato
Duro e rigido come un tronco. È un cavo che richiede molto spazio e, nella maggior parte dei casi, in casa non abbiamo una stanza dedicata all’hi-fi. Diventa complicato, soprattutto se deve passare dietro a un mobile, dove serve un minimo di flessibilità. Come suona? Finché si tratta di rame puro (ovviamente), suonano tutti bene.
Kevin S.
PANGEA AC-14SE MKII Power Cable Triple Shielding Cardas Copper / OFC 3x2mm² 1m Based on a mix of sale strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
Utilisé pour éviter les interférences courant fort / courant faible au niveau du panneau arrière de mes élément hi-fi.
Attention comme souligné par un autre utilisateur, la phase et le neutre sont inversés et mon ampli ne sait pas fonctionner, une inversion au niveau de ma prise murale a été nécessaire.
Paulius S.
RJ45 Ethernet Connector Cat8 Shielded Ø8mm This Cat8 standard metal RJ45 connector lets you assemble your own Ethernet cables without the need for special tools. It accepts cable up to 8mm in diameter and has gold-plated...
Very Useful
Nothing to complain.
Paulius S.
SOMMERCABLE MERCATOR CAT8.1 Ethernet Cable OFC Copper 8x0.32mm² Ø8.2mm This Sommercable Mercator Cat 8.1 Ethernet cable has 8 conductors of 0.32mm² each (22AWG) with double tinned copper braid shielding. This cable, sold by the metre, will...
Very Good
I like this cable and price very much.
Thierry S.
Vraiment bien
Merci David, pour votre patience , et , disponibilité, je craignais que ce petit ampli ne fasse pas le poids, en kilo c est certain, face à mon Classé Audio, et bien, il est costaud le petit, le son est vraiment très bon, le conseil était fort avisé.
Terrific cable
I don't know how Neotech improved on the NEP 3001 hybrid, but this cable is astonishing at the first listening. As another user said, super levels of transparency and wider, deeper sound stage.
In 2 words- buy it!
Tomasz C.
TOPPING DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 Silver With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes, improving on its predecessor in...
Some people would call my change to this DAC/Amp a downgrade as I come from a Audio-gd D28.38 to this. However, this little DAC/Amp combo has so many more features, such as being able to use the device without a computer or other source connected to it.
For the headphones I normally use Denon D2000 and Focal Clear MG, this has plenty of power both single ended and balanced.
Sound-wise after listening to it for a few days, it sounds transparent to me, nothing seems out of place from other equipment I normally use. So all-in all I am very happy with it.
Connectivity-wise, it also has balanced out, which I use with a set of active speakers, which also works very well.
Being class D is also a huge plus as the Audio-gd device I had before could run a bit toasty even when not in use.
Take this with a grain of salt as these are just initial impressions, but so far I am not disappointed.
arnaud m.
Exelent
La fonction de calibrage du caisson est très efficace et m’a enfin permis de coupler mes enceintes avec mon caisson.
Seul la fonction calibrage de la pièce m’a semblé pas très pertinente lors de mes essais en dénaturant la personnalité des enceintes.
Jean-Louis R.
CXG E60S Adjustable Soldering Iron with Stand 60W 500°C Ø7mm The adjustable soldering iron CXG E60S offers a power of 60W, allowing to reach a maximum temperature of 500°C. Its ceramic heating element ensures a constant temperature...
ne chauffe plus assez
Jean-Louis R.
VIBORG XF-202G Female XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Black (Unit) Viborg offers with its XF-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Wojciech S.
Best wires ever made
As long as you use the 1877PHONO GoldRush turntable cable (probably the best turntable cable there is - when I first connected it to my Technics SL-1200G, it seemed to me that Mephistopheles was behind the music and was helping to extract the magic from the sound) - CryoGold-Ag are the only ones you can use as a companion to GoldRush, because they are made in the same way and from the same materials. I have a dozen or so turntable cartridges and this is the third CryoGoldAg-Ag set I have bought (by the way, Audiophonics.fr offers the best price for them), because there is a complete synergy between the turntable, preamp and amplifier. These little wonders squeeze the maximum information out of the records. I can't give 6 stars out of 5, because there is not that much on the scale, and these cables are off the scale! 200% recommendation!
Jean-Louis R.
CANARE BCP-A77 BNC Connector Gold Plated Beryllium Copper Ø5.2mm The Canare BCP-A77 BNC connector offers a nice design quality, with a metal body and gold-plated beryllium copper contacts, ensuring very good conductivity. It ensures an easy...
Dommage qu’il n’y ait pas plusieurs embouts à sertir, pour si on veut changer de cable.
Dispo séparement?
Wojciech S.
The best headshell cables ever made
Wojciech S.
Great sound for the price
These tubes are not as prone to failure as the Chinese ones, they are made solidly and will serve for many years. They give a very saturated, soft sound, with beautiful mid tones, good bass and a sonorous top of the band. Worth recommending, they have a great value for money.
CARLIER B.
Idéla pour synthétiseur yamaha MM6
Je recherchais un encodeur rotatif pour mon synthétiseur yamaha MM6. J'ai contacté le service client Audiophonics qui m'a conseillé le BOURNS PEC16 Encodeur Rotatif Numérique 24 Positions Axe court. Emballage soigné et envoi rapide..
Merci Audiophonics pour votre sympathie et votre professionnalisme.
Jerry T.
Audiophonics DAC sabre board ESS9038
Please keep selling this item. It is very high quality! I will buy many more in the future!
Jean-François D.
FIIO K11 R2R DAC Headphone Amplifier 24bit 384kHz DSD256 Black The FiiO K11 R2R, the R2R version of its cousin the K11, is a small, versatile and high-performance DAC headphone amplifier. It is based on a resistor network and audiophile...
Impeccable !
Commande facile et expédition rapide. Le produit répond parfaitement à mes attentes et à sa réputation. Je branche mon casque Mezze 109 Pro dessus avec le câble symétrique de 4.4 mm. Le son est excellent, très doux. Les basses et sub-basses sont chaudes et dynamiques, les médiums et les aigüs sont bien détaillés. Satisfaction totale !
Vasilios K.
From the moment I connected it, the difference was clear: the sound became more musical, fuller, and flowed more naturally. Any harshness or edginess disappeared, and the presentation came to life with a new sense of energy and presence. Everything felt faster, more fluid, and emotionally engaging. It made me want to rediscover my vinyl collection all over again. Very pleased!
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 18V 1A 25VA This LHY Audio LPS25VA regulated linear power supply is ideal for any high-quality audiophile project. All the necessary technical refinements are incorporated in this power...
Ça Chauffe !
En charge avec un préamplificateurs phono Pro-Ject Tube Box DS3 B, l'alim. monte à 52°C avec 26 °C dans le local....Je pense placer des dissipateurs thermiques.
Geert J.
du haut de gamme à petit prix
J’ai acheté le JC2-FET pour relier mes sources à mon amplificateur de puissance. Mes sources n’ayant pas de réglage de volume, il me fallait un préampli. L’insertion d’un préamplificateur actif me permet aussi d’augmenter le rapport signal sur bruit de mon système.
La finition est à la fois spartiate et soignée. Le boîtier en aluminium brossé est solide. La face avant a une épaisseur de 8 mm. Même les boutons de réglage de volume et de sélection d’entrée sont en aluminium. Les bornes d’entrée et de sortie sont plaquées or. Le JC2-FET est conçu et produit en Chine.
Les concepteurs du JC2-FET se sont inspirés par le JC-2 que John Curl a réalisé pour Mark Levinson. Le JC2-FET a un montage en double mono et fonctionne en classe A. Chaque canal est pourvu d’une alimentation régulée (15 VA) : cela est très important pour les électroniques qui doivent gérer des signaux électriques très faibles. Les transistors utilisés sont de type JFET (Toshiba) qui ont la réputation d’être particulièrement musicaux. Il n’y a pas de condensateurs d'entrée et de sortie. Bizarrement, les concepteurs paraissent avoir ajouté un étage de sortie offrant un courant important. Cela n’est pas très ‘courant’ sur un préampli, la première fonction d’un préampli étant d’augmenter la tension (c’est l’ampli de puissance qui ajoute un courant). Le JC2-FET a un niveau de sortie de max. 9 volt, ce qui est un peu la norme pour les préamplificateurs ayant des sorties non-symétriques. Cela suffit largement pour piloter n’importe quel amplificateur de puissance.
Rappelons que la qualité des électroniques en amont de l’amplificateur de puissance est de prime importance. Le préamplificateur permet d’augmenter le ratio signal sur bruit du système puisqu’il n’amplifie que le signal de la source (musique, parole …) et non pas le bruit résiduel, contrairement à l’amplificateur de puissance qui amplifie la totalité du signal, donc aussi le bruit. Un préampli puissant (tension de sortie suffisante) permet donc de réduire le gain de l’amplificateur de puissance pour éviter que ce dernier amplifie trop le bruit. Chaque imperfection en amont de l’ampli de puissance sera littéralement ‘amplifiée’ par ce dernier. Voilà pourquoi la qualité des électroniques en amont de l’ampli de puissance est un facteur plus décisif que la qualité de l’ampli de puissance même (cf. théorème de Friis). Signalons aussi que la séparation du préamplificateur de l’amplificateur de puissance fait que les deux étages disposent d’une alimentation spécifique adaptée à leurs besoins et qu’ils sont moins sujets à des interférences mutuelles.
Contrairement aux autres avis, j’ai trouvé que le JC2-FET ne nécessite pas de rodage intensif : il dévoile assez vite son potentiel.
Voulant éviter les commentaires dithyrambiques, je vais me limiter à dire que l’insertion du JC2-FET dans mon système ne mène à aucune dégradation sonore. Bien au contraire : j’ai l’impression que le son est un peu plus grand. Les concepteurs du JC2-FET ont réussi le tour de force de créer un préamplificateur abordable qui offre une grande musicalité et une transparence totale. Je m’attendais à de légères dégradations (comme une transparence et une scène sonore réduites), mais heureusement ce n’est pas le cas. Il est clair que le JC2-FET joue dans la cour des grands: au tarif proposé, cela est un peu déconcertant …
Certains regretteront l’absence de sorties et d’entrées symétriques et de télécommande. Je signale aussi que le JC2-FET est livré sans câble d’alimentation.
Conclusion : du haut de gamme à un prix abordable.
Geert J.
3E AUDIO A5 Class D Stereo Amplifier PBTL 2xTPA3251 2x150W 4 ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5 amplifier is based on two TI TPA3251...
le petit qui joue dans la cour des grands
J’ai des enceintes à haut rendement et avec la plupart des amplis que j’ai déjà essayés, un souffle se manifeste, en particulier sur les moteurs à compression. J’ai acheté trois A5 pour réduire le souffle dans mon système, vu que le A5 a un bruit résiduel extrêmement bas. Avec les A5, sur les moteurs à compression, on entend toujours un léger souffle, mais cela est dû au bruit qu’il y a en amont des amplis : c’est mon processeur qui génère un souffle. Ce n’est donc pas la faute du A5 qui ne fait qu’amplifier ce qu’on lui donne, donc aussi le bruit. Quand je branche les A5 directement sur les moteurs à compression sans processeur, le souffle disparaît presque complètement.
J’ai déjà eu plusieurs amplis classe D d’origine professionnelle (Crown XLS Drivecore, Crest Pro-LITE, QSC PLD …). J’ai toujours été charmé par le son audiophile de ces amplis, mais sur mes enceintes à haut rendement, ces amplis pro augmentent le bruit qu’il y a dans ma chaîne. Le A5 fait preuve lui aussi d’une grande musicalité, mais il n’ajoute pas de souffle au système. On est très loin du son maigre et froid de certains amplis de classe D venant du monde hifi. Les timbres ne sont pas dénaturés et le rendu sonore se caractérise par une grande clarté et par une belle fluidité. Cela n’étonne pas : certains composants sont de très bonne qualité (alimentation, condensateurs, puce …). Ajoutons à cela que le A5 offre une puissance respectable malgré sa taille réduite. En plus, le A5 est indépendant de la charge : cela est rendu possible par le ‘post filter feedback design’ (PFFB) et par les caractéristiques de la puce TI. Cela donne un son très équilibré. La scène sonore est précise, large et profonde.
Conclusion : petite taille, petit prix mais grand son.
István R.
AECO ABI-0611S Speaker Terminals Tellurium Copper Silver Plated (Pair) These aeco ABI-0611S speaker terminals offer excellent design quality. They use low-mass contacts made of high-purity tellurium copper with silver 120µ plating, ensuring...
AECO ABI-0611S vs ETI CRYO
I had the opportunity to compare the 0611S binding post with the ETI KRYO Silver Plated Tellurium Copper. (ETI KRYO Silver Plated is not certain to be cryo-treated either, because there is no information on the manufacturer's website https://eti-research.com/connector/kryo-binding-post/ ) Both have the same conductor (tellurium copper) and silver plating. The direct clamping of the spade and wire is the same and practical. It can be soldered on the inside and also fixed with a screw. There are two differences. The AECO fixes the wire with screw through a removable optional hard material ring. The other difference is that the AECO clamping cylinder is grooved for gripping the fork, which allows you to clamp the fork on heavy cables more firmly. I don't think the two sound different, I like the 0611S better and it is much more affordable price.
Julien L.
DAYTON AUDIO XO2W-2K 2-Way Speaker Crossover 2000Hz The Dayton Audio 2-way crossover series was designed using a second order Linkwitz-Riley alignment (12db/octave). Dayton Audio metallized polyester film capacitors are used in...
Qualité visuelle au rdv. Reste à tester à l'écoute.
Julien L.
AIYIMA B07 Amplifier 2.1 Bluetooth 5.2 Class D TPA3255 2x250W + 300W 4Ω Aiyima's B07 is a integrated amplifier with 3 channels, including one dedicated to the subwoofer and an auxiliary output. It is capable of delivering considerable output power...
Ampli
Petit mais costaud. Par contre chauffe rapidement.
Jacques B.
ETI LEGATO 20 AMP IEC C19 Connector Gold Plated Copper Ø20mm ETI Research's Legato 20 AMP power connector is a top-of-the-range IEC C19 that accepts power cables up to Ø20mm. Its contacts are made of gold-plated 1100 (IACS 102%)...
Excellente connectique !!
De l'ETI, encore et toujours, de grand qualité de fabrication et toujours une ouverture remarquable, un naturel avec beaucoup d'aération. Attention à bien attendre le "rôdage" de la prise pour en tirer le meilleur, notamment avec un grave en avant qui s'équilibre à l'issue !!! Evidemment, le prix est conséquent mais justifié. Bravo !!
Jean-François L.
Superbe choix
Le challenge n'était pas gagné d'avance : Alimenter mes Martin Logan Sequel II.
Après de nombreuses recherches sur les amplis adaptés, l'intelligence artificielle a attiré mon attention sur les amplis de classe D et notamment sur Hypex et Purifi.
Audiophonics m'a été d'excellent conseil dans le choix de celui-ci.
Je l'ai associé au préamplificateur MUSES72320 pour gérer facilement mes sources.
En plus, la livraison a été rapide et efficace.
Le résultat est exceptionnel quel que soit le volume d'écoute.
Merci à vous
Arnaud M.
RAMM AUDIO TA-14SP Speaker Cable OFHC Copper Shielded 4x 2.1mm² Ø10.5mm The Ramm Audio TA-14SP is a speaker cable offering quality design at an affordable price. It consists of four OFHC copper conductors with a cross section of 2.1mm² (14AWG),...
TOP
Aucun souci sur cette commande, ce câble, surgainé par mes soins (finition en thermo rétractable), a pris place entre un Electrocompaniet ECI6 et des Living Voice IBXR3 en bi-câblage. Il est un peu rigide mais se travaille très bien.
Je ne sais pas bien comment font ceux qui commentent le son d'un câble ou d'un élément en particulier, mais ce que je peux dire, c'est que chez moi, l'ensemble désigné plus haut fonctionne parfaitement à mon goût. Tout est en place, sans excès ni frustration, image, timbres tout est ok... CD, plateforme, vinyle, tout tourne, et ça fait même de la musique ! -;) Que demander d'autre ?
Frederic L.
gaine thermo rétractable...
Qualité parfaite.
Service parait. Merci à l'équipe technique.
Frederic L.
gaine Thermo rétractable...
Qualité impeccable mais je n'ai pas reçu la gaine 5 mm.
Celle que j'ai reçu était plus petite. Heureusement j'ai pu l'utiliser malgré cela.
Frederic L.
fiches bananes à souder...
C'est un produit exceptionnel que je recommande.
Ajoutez un bout de gaine thermorétractable et c'est parfait.
PATRICE R.
Superbe Amplificateur
C'est mon 4ème ampli en Class D .. Je ne reviendrai plus vers les tubes , la class A ou même AB.
Absolu transparence , maintien du grave et dynamique, ce sont les qualités déjà connues et au top avec la dernière version de PURIFI.
Je l'ai utilisé avec différentes enceintes a rendement différents. avec le réglage de gain de la carte Audiophonics il est toujours possible d'avoir une bonne progression du réglage de volume.
Actuellement je l'utilise avec le Dac Preamp JADE de Metrum Acoustic. La qualité de fabrication est excellente ainsi que la possibilité de changer l'AOP si besoin .. !
Si vous optez pour des montages séparés avec ampli de puissance. C'est le meilleur choix à ce prix et peut être dans l'absolu. Il faudra penser à lui associer un bon câble secteur il y en a de bons ici dans la gamme ELECAUDIO, c'est ce que j'utilise aussi.
avec liaison MOGAMI XLR
Enfin je ne partage pas l'avis précédent qui parle d'un haut médium en avant .. , en fait ces amplis sont tellement transparents qu'ils mettent en évidence les qualités et les défauts des équipements associés.
Notamment les colorations caractéristiques de certaines marques !
Dominique E.
JANTZEN AUDIO COMPACT MKT 001-8140 Axial MKT Capacitor 160V 22µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Tolérance erronée, valeurs non respectées
Si les condensateurs présentent bien, j’ai de sérieux doutes sur la tolérance quant à leurs valeurs. Il est indiqué 5%. Mais quand je mesure les 4 condensateurs de 22 µF à plus de 24µF et avec deux capacimètres différents, ça questionne. Un des condensateurs est même mesuré à 25,06µF, soit presque 14% de plus que la valeur indiquée. J'éviterai à l'avenir cette marque.
gilles A.
MUNDORF MRESIST ULTRA Resistor 30W 1.2 Ohm The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers...
Produit cher, mais de qualité audio, Associé à des condensateurs hdg genre jantzen alumen z sur la partie ' série ' des filtres enceintes, apporte transparence et musicalité, rapport a des associations condos/résistances moins hdg, le son semble s'améliorer au fil des heures d'écoute.
