Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
Customers reviews - There are 19516 reviews.
Paulius S.
ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very...
Review
Terrible designe, but sounds good.
Hugues P.
Monté avec un adaptateur Type D xlr, revient moins cher que celui vendu sur le site.
Hugues P.
Très bon produit.
Très bon pris
Du plus bel effet.
Hugues P.
Anodized Aluminium Push Button with Orange Light Circle 2NO2NC 250V 5A Ø19mm Black This bistable switch (two positions) 250V 5A in anodised aluminium incorporates a beautiful orange LED. It is ideal for all your DIY projects and assemblies, especially as an...
Las d'avoir toujours du bleu ou du blanc. Ce produit est parfait couleur douce et apaisante. J'ai changé tous mes interrupteurs.
L'ancien interrupteur orange était meilleur.
Eric Q.
EVERSOLO BTR-12 IR / Bluetooth Remote Control for DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 This IR / Bluetooth BTR-12 remote control developed by Eversolo is designed to be paired with all their DMP series devices, i.e. the DMP-A6, DMP-A6 Master Edition, DMP-A6 Gen 2,...
Me permet de piloter mon DMP-A6 de façon plus rapide qu'avec un téléphone ou avec l'écran. La portée est suffisante pour mes besoins, la télécommande n'est pas inutilement trop grande ou trop fournie en boutons.
Eric Q.
AUDIOPHONICS Trigger 5V 110V/230V Slave Power Supply Device This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have this feature natively.
Fonctionne parfaitement
Connecté avec une prise jack-usb, cet adaptateur allume et éteint un amplificateur et permet de ne pas laisser allumer inutilement un transformateur.
Roland B.
Plusieurs bémols, chaque pointe n'est pas vraiment identique en taille, moins de 10mm avec une échelle allant de moins 0.20 à 0.30 mm, pour une fabrication industrielle par machine à commande numérique!!!. Le deuxième point, inégalité du point de départ du filetage interne des pointes. Je les ai acheté pour mes deux Amplis et mon Pré-Ampli Hi-Fi.
Diego D.
ELECTRO HARMONIX 12AY7/6072A Tube Twin Triode (Unit) This Electro Harmonix 12AY7/6072A tube is a double triode with equipotential cathodes. It is mainly designed to amplify low frequency voltages in audio equipment.
UPGRADE DU CANAL GAin MARSHALL DSL 5 CR
Acheté pour remplacer la 12AX7 d'origine du préamp de canal ultra gain de mon marshall, afin de le rendre plus progressif : le résultat est notable, on retarde d'environ1.5 graduation la plage de réglage avant le durcissement typé "marshall" de la saturation. cela permet de trouver un réglage plus "crunchy" en début de course. (j'ai aussi testé une 12AT7 WA : effet moindre, pas suffisant)
Andris L.
WIIM REMOTE Bluetooth Remote Control for Wiim PRO / AMP The WiiM Remote, specially designed for the WiiM Pro and WiiM AMP, has a built-in microphone and an Alexa button for easy voice control of your network player or amplifier.
Nice
It feels good, the batteries last a very long time. There is no need to aim, because the remote control works on bluetooth. An ingenious product at a good price. I posted the pictures in disassembled form on the wiim site =D https://forum.wiimhome.com/threads/wiim-remote.495/post-7590
Christophe T.
Très simple à mettre en œuvre et d'excellente qualité.
Carte à relais ultra simple à mettre en œuvre. Je me suis fais un sélecteur pour 8 entrées et 4 sorties RCA stéréo, avec 3 cartes LITE 4CH. J'ai supprimé le pont de diodes et l'ai alimenté en 12VDC avec un petit bloc alim 230VAC/12 VDC, qui se branche directement dans une prise mural. Les relais sont de bonne qualité et on entend aucun brut de commutation dans le son. C'est très transparent, et vraiment abordable.
Jean T.
Rapide et efficace.
Comme à l'accoutumé : totale confiance. Je recommande.
Jean.
Laurent P.
HDMI 2.1 Optical Cable 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 3m This 3m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is compatible with CEC, 3D, HDR 10,...
Agréablement surpris
trés bon cable hdmi 2.1,passe en 4k 120hz la ou d'autre cables "certifier" n'étaient méme pas reconnue.
nicolas H.
TAD EL34-STR REDBASE Power Tube Pentode (Unit) The TAD EL34-STR Redbase is a pentode with a 25W heatsink plate and convection cooling. This tube is intended for power amplification in pentode, ultralinear or triode...
Excellent tube
j'avais un quad appairé et 1 tube a eu la bonne idée de me lacher. (apres 1.5 ans...) Au lieu de changer tout le quad, je suis parti sur l'idée de ne remplacer que le tube défectueux. Opération validée, valeurs du tube très proche du quad et à l'oreille c'est parfait !
A éviter
Apporte une "coloration" dans l'aigu qui peut être désagréable , en fait le terme exact serait plutôt distorsion , idem pour son pendant en shuko. Remplacée par des Furutech rhodium qui après rodage se sont révélées parfaites , pourtant vu ce qu'en disent certain le rhodium j'étais plutôt méfiant...Pour moins cher que les Fu rhodium , les Viborg plaquées Or-Ag sont beaucoup plus neutres
Christian D.
EVERSOLO H2 Balanced DAC Portable Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 EVERSOLO offers with the H2 a balanced DAC and  portable headphone amplifier  combo wich is compact and powerful. With a USB-C input, it is an ideal companion for...
excelent pour le prix
L audition symetrique du Dac est un plus par rapport aux autres appareils de ce prix
Christian D.
4.5
je suis trés sastifait de mon achat le lecteur steaming est exelent sur Qobuz .J ai essaye la sortie optique de mon excelent lecteur Meridian 508 sur le Dac de cet appareil il n y a pas photo le son est meilleur mieux défini et neutre.Par contre malgre que la traduction en Francais est prévu il n 'y a presque rien de traduit et l intégration de qobuz est moins poussé que sur Sonos C'est poirquoi je note 4.5 au lieu de 5
XANGSANE XS-Q23 Brushed Aluminium Damping Feet 40x20mm Black (Set x4) Xangsane's XS-Q23 brushed aluminum feet are dedicated to hi-fi and video equipment. Their Ø40mm diameter and 20mm height make them compact but no less effective....
Tres bon produit
Désolé pour mon precedent avis car erreur de produit
Ces pieds sont excellents
A recommander
Florian R.
Works beautifully
...the Amp is absolutely stunning. I use it for mastering in my home studio. Never had such transparent Stereo separation and controlled Bass before. I Use it with a pair of ATC SCM12 Pro. 250W are enough to play music very loudly with my ATC's
Thank you!
Sébastien T.
Que demander de plus ?
Placé derrière un petit DAC Geshelli à la place de l'adaptateur d'origine, l'iPowerX apporte immédiatement un grave plus percutant, une scène sonore plus profonde et quelque chose de plus "moelleux", de plus "posé" dans le médium… un régal à l'oreille. A noter qu'il fournit plus du double en puissance de l'adaptateur d'origine. Une optimisation essentielle pour redécouvrir son DAC !
JEAN-PHILIPPE F.
Très bien mais attention à l'alimentation
Coté son, c'est impec.
Par contre coté alimentation, j'ai été déçu : je pensais pouvoir l'alimenter avec le 5V de mon "préampli/Volume/sélecteur de sources" DIY, mais non... Le DAC ne supporte pas que le 0V de son alim soit relié à la masse analogique, et le fait entendre par un buzz à 200Hz et ses harmoniques. Insupportable. Il faut absolument l'alimenter avec une alimentation flottante... Depuis mon PC portable, ça va. Un adaptateur pour téléphone de qualité fait aussi l'affaire, mais le rapport signal/bruit est meilleur avec une alim linéaire. Cela fait des frais supplémentaires non prévus...
Xenofon T.
RCA 3 to 1 Input Selector Module This source selection module has three stereo RCA inputs and one stereo RCA output. It also comes with a solderable potentiometer for easy selection of an active input.
Input-Output
Excellent! I love it. Saves me much work.
Xenofon T.
Feet for Smal amps
Nice build, looks great.
Xenofon T.
Preamp case
Excellent! Good design. Good build. I love it.
Yann D.
Le meilleur DAC que j'ai eu à ce jour
Le son de ce DAC est longuement décrit sur le web, je vais juste compléter pour dire que je l'ai compatré à mes précédents DAC dont le X26Pro et le A26 notamment (je ne parle pas des topping qui m'ennuient) : le R26 est de loin le plus naturel et il n'a aucun problème à passer TOUS TYPES de musique. La théorie que pour la musique moderne il faut mieux le A26 est stupide. Je suis amateur de techno (qui cogne) et le R26 est jouissif (comme une table de mixage Mackie vs une numérique). Bref, j'adore ce DAC. Bonne muisque !
Vanja Š.
Easy to use. Excellent specifications.
Vanja Š.
like: Easy to use. Excellent specifications.
dislike: No secure pairing.
Aluminium Stands 39x18mm Black (Set x4) The sturdy aluminum feet reduce vibrations and limit the transmission of vibrations to other parts.  One spike can support up to 8kg. With a set of 4 you can support up to 32kg.
Excellents pieds
Matériel qui respire la qualité je conseille
Tres bien
A ce prix pourquoi ne pas protéger de la poussière ?
Cédric R.
Polyvalent
Bonne machine polyvalente.
Je n’ai pas aimé la signature sonore sûr mon système. Cela manquait de matière.
Associer à un système neutre à chaleureux je suis certain qu’il fera des miracles.
Cédric R.
C’est la première fois que j’achète un câble assemblé à ce prix. Il est excellent et largement au dessus du summercable épilogue qui a une légère tendance acidulée sur les hautes fréquences.
Cédric R.
Un câble de bonne qualité. Diamètre assez important mais assez souple.
Excellente base pour tout matériel de puissance, alim, ampli, intégré...
Exemplaire sur système professionnel
Conseils et rapidité exemplaire.
Bravo Audiophonics
Système monitoring pro NEUMANN
KH120a
HH750dsp
Carte son APOGEE quartet
J’ai acheté 8m pour refaire sur mesure mon installation qui était faite avec les câbles Vovox Sonorus.
J’ai pris du neutrik plaqué or.
Le travail des câbles se fait pas trop mal avec de bons outils. Je soude avec du 10% argent, et c’est pas simple ! Le plus difficile c’est les jacks 6,35 symétriques, c’est pénible au possible !
Le xlr à côté c’est du beurre.
À l’écoute la différence avec les Vovox est PHÉNOMÉNALE. C’est beaucoup plus ouvert. J’ai beaucoup plus de nuances dans les graves. N’oubliez pas que j’ai un sub (gros) qui redistribue aux écoutes de proximité. Ça file beaucoup plus haut et ça donne énormément de clarté aux médiums sans projection et le hautes fréquences sont détaillées sans duretés mais offrent une spatialité dont j’ai besoin pour mes balances.
Et tout cela c’est sans rodage !!!
Précision importante :
Je suis équipé d’un calibrage Neumann.
Microphone processeur dans le sub et software Neumann qui équilibre l’écoute en fonction de la pièce et de la position.
Je vais refaire la calibrage mais je réfléchis pour savoir si je le ferai avant rodage ( option pressentie) ou après…
Traitement acoustique de la pièce partiel ; juste pour corriger son défaut majeur.
Je mets un nouvel avis si gros changement.
Vraiment pour le prix c’est imbattable !!!
Je vais me faire des câbles pour mes microphones.
Jerome m.
nice
everything is fine, happy I am, except for the missing remote battery and alimentation cable.
bluetooth name (of my device at least) is QCC3008
remote is a leTV one ? black, small, clean,with a label wrote in corean I think, its fine by me :)
ALAIN B.
Bonne pince, coupe bien
ALAIN B.
Cable d'alimentation assez court
Très bien mais Cable d'alimentation assez court
Sobre et efficace
A ce pris, je n'ai pas trouvé mieux. J'ai un ampli en classe A et bien sur il chauffe. Particulièrement pendant les périodes de canicule.
J'ai donc collé au double face thermique (transfert de chaleur optimisé) le capot métallique de mon ampli.
Rien que ça, le capot était + chaud qu'avant. C'est toujours autant de calories en moins pour le push de sortie.
Et si je couvrais le capot de radiateurs pour augmenter la surface émisse de chaleur. Dont acte.
Le look est sympa et très efficace. Suis ravi de ses radiateurs.
J'ai remplacé mes câbles haut de gamme et chers (dopés à l'argent pur) ... et oui, par le Sommercable Albedo sur platine vinyle et sur lecteur cd à tubes.
Superbe timbre, grande musicalité, neutralité, silence, je n'ai que des éloges à faire musicalement, petit prix aussi !
La tresse pour la masse et les 2 conducteurs soudés ensemble pour le point chaud.
Livraison ultra-rapide en moins de 2 jours, super site.
Pas cher et de bonne qualité.
Petit prix pour cette paire de fiches rca, bonne qualité générale.
Je les monte sur câble de modulation Sommercable Albedo, grande satisfaction auditive pour liaisons platines vinyles et pour lecteurs cd aussi.
Il est très important de savoir que l'isolant est téflon PTFE et ne fond pas à la soudure.
Livraison rapide en 2 jours, bravo !
Magique !
Sources : Octavio câble optique WireWorld Supernova
Mac Audirvana fichiers DSD et autres 24b
Spotify
DAC : Chord-Hugo2
Cables : Vovox Sonorus Direct
Amplificateur :Cayin 55 Tubes intégralement PSVANE EL34 replica Philips, et série S
Enceintes : Dali Menuet.
Sub REL
Je me réjouis chaque jour de l’homogénéité sonore de mon système.
Mais ces qualités peuvent être ruiné par un seul élément. J’avais une scène sonore très confuse avec des médiums projetés en avant. Certes, les timbres étaient magnifiques, mais cela devenait très désagréable et vraiment pas satisfaisant. j’ai vite soupçonné le câble qui relie l’amplificateur avec le haut-parleur, un câble pourtant réputé de chez Cardas. La comparaison avec la sortie casque sur l’ampli m’a aidé à comprendre d’où venait le problème.
Maintenant, la question était : quel câble prendre?
C’est vraiment une jungle ou le pire côtoie le meilleur indépendamment de toute notion de tarifs.
Sur les conseils d’Audiophonics, j’ai donc opté pour ce câble Mogami.
Donc, à mon tour de confirmer tout ce qui a pu être dit dans les autres commentaires. Au tout début, un gros grave bien ronflant pas déplaisant puis au bout d’une dizaine d’heures, le grave devient clair et bien assis,la scène sonore s’ouvre notamment en profondeur et les hautes fréquences , filent sans aucune agressivité, même sur des fichiers base définition.
Les timbres, les harmoniques de chaque instrument, les ambiances, les extinctions de notes sont présents sur tous les morceaux.
Les musiques sont maintenant tellement naturelles, je peux monter le son plus fort, sans que ça me casse la tête.
Les instruments ne se marchent plus sur les pieds, tout est à sa place dans l’espace c’est holographique.(Tout dépend du mixage, bien entendu.).
Finalement, en guise de conclusion, tout rentre dans l’ordre.
Je souligne l’excellence du conseil d’audiophonics, et l’efficacité de leur service de livraison.
Musicalement vôtre.
Emilio Y.
Good transparent and vivid amplifier
I bought the amplifier to replace my beloved Marantz PM-8005. Nowadays, I do not need most of the features that the integrated amplifier offers and I just wanted to have a simple amplifing block to link a Wiim Pro streamer (Tidal and Quobuz as sources), a Topping E30II DAC used as preamp and a pair of Dali Oberon 5. I had tried several cheap class D amplifiers in my secondary system and, although all of them performed well, I wanted to check whether Hypex Ncore modules made justice to their fame and measurements.
The amplifier arrived perfectly packed within a few days. 10/10 for Audiophonics! It is well built, robust and the connectors are also of really good quality. As expected, it is smaller and much lighter than my Marantz PM-8005 so it is a good alternative when espace is limited.
It has enough power to drive the Oberon 5 without problems and I have still quite a lot of margin using the volume control of the DAC to play to absurdly loud levels (definitely not healthy listening volumes). Regarding the sound (knowing is subjective and considering that I am by no means an audiofool), I have to admit that it is taking me a while to get used to it when compared to that of the PM-8005. I percieve a better detail, instrument separation and dynamics than in the Marantz, as well as better and cleaner bass control. However, I am missing certain soundstage and musicality or mellowness (some may call it distortion), which makes the PM-8005 a real pleasute to listen to in my system. I have the feelings that the Marantz is more forgiving with the quality of the source while, with the Ncore-based amp, poorly mastered records are almost inaudible.
All in all, really good option for reduce espaces or simple setups in which the conectivity of an standard integrated amplifier is not needed. Totally transparent, dynamic and with amazing bass resolution.
Michel l.
audiophonics et immanquablement le meilleur site audio toujours a l’écoute dont je remercie l'ensemble des personnes qui m'ont conseillé pour ce petit ampli dayton HTA100 agréable a regarder et à écouter pas encore rodé l’ensemble me convient suffisamment pour apprécier mes vinyles sur platine dp300f cellule Ortofon 2M Red MM plus câble enceinte van den hul cs122 enceinte bibliothèque highland 4301 et sub focal cub3 parfait pour mon bureau
J'en suis trèscontent.
Facile à mettre en oeuvre. Bon contact. Fait bien le job.
Je garde ces prises qui deviennent mon modèle par défaut.
Boyan C.
Really the precision, control and power is out of this world. The only problem I have is that the 12V trigger in/outs accept only mono 3.5 jacks, if you try to use stereo jack it creates ground loop problems. This was not a problem with the nc502mp aps that I have.
Jorge P.
Excelentes
Ao longo de muitos anos tenho usado e testado varias marcas de conectores, mas estas Viborg são as melhores, excente qualidade de construção, uma assinatura sónica neutra, com vozes e instrumentos mais reais e naturais, o espectro sonoro é comleto e sem esforço
... escelentes
Jorge P.
Excelentes
... escelentes
Jorge P.
Excelentes
... escelentes
Jorge P.
Excelentes
... escelentes.
Jean-Pierre D.
AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment,...
Bon résultat sur les gros amplificateurs Home Cinéma
A un prix contenu, ce câble offre une alimentation de qualité à mon amplificateur Denon 8500 HA qui a une consommation électrique élevée (900 Watts). A l'écoute, bonne amélioration du son, c'est neutre et apporte un son puissant à l'installation, cela me semble fidèle notamment en utilisation musicale, pas de coloration. Autrement, malgré sa grosse section, le câble peut se plier aisément donc permettre un branchement quand on a peu d'espace ce qui est mon cas. Cela respire la qualité de fabrication notamment au niveau des prises. Audiophonics me l'a conseillé pour alimenter les grosses centrales électriques en classe AB du type de mon Denon.
Jean-Louis L.
Paire d'enceintes de conception Danoise mais fabriquées en Chine, ce qui les met à ce prix-là, pas de secret.
Puissance admissible : 90 W RMS (150 W en crête . . . )
Impédance : 4 à 8 ohms
Sensibilité (2,83 v/1m) : 89 dB
Bande passante (± 3 dB) : 50 à 22 000 Hz
mais toutes ces performances semblent un peu gonflées...
Pour une pièce jusqu'à 20 m2, elles semblent assurées avec entrain & une belle Musicalité.
Évidemment, pour le prix de 2 très bons condensateurs audiophiles, vous n'en aurait que pour votre argent, voire même bien plus.
Je les ai attelées à un petit Ampli Classe D et tout cela sonne très bien, derrière un lecteur CD ou en Streaming via Qobuz.
Pour une écoute sympa dans une pièce secondaire, ou comme moi, si on part en villégiature obligatoirement avec de la Musique, superbe choix assez compact.
Sami K.
Good quality/price ratio
Sounds, looks and feels good. Better shielding due to additional conductive plastic layer combined with the copper shield. Tricone XXL has very good build quality and materials with a reasonable price.
