Pierre H.
4N ou 6N
Didier C.
Etonnante petite boite !
Didier C.
Customers reviews - There are 19354 reviews.
Excellent bornier.
Excellente fiche banane
Emmanuel A.
Haut de gamme
Joris J.
Loose physically connected
Joris J.
Superb reclocker
Eugen M.
TSP facile
Eugen M.
Très surpris en bien
Joris J.
Exceptional value
Almost for free.
Philippe K.
ASTELL&KERN KANN MAX Digital Audio Player DAP HiFi 4x ES9038Q2M Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Gray The KANN series is a line of portable digital music players, particularly popular with audiophiles for their performance focused on high output and clear sound. The KANN MAX,...
Erik J.
naturel
Thierry V.
Surprenant!
Rimantas S.
Nice little DAC
Nothing to complain about.
Jean L.
Très bon RQP
Gregory F.
Impressionnant
bernard T.
Banana Plug Rhodium Plated OFC Copper Ø5mm (Set x4) This banana plug offers an excellent quality / price ratio. Made of OFC 4N copper with rhodium plating, it ensures a very good conductivity and durability. Its design also...
fiche bananes
Très belle fabrication, dommage que les vis soient un peu courtes car même avec un câble de 4mm2, elles peuvent tomber dans le corps du connecteur à la fin du serrage.
TAD ECC803S Tube Twin Triode (Unité) The TAD ECC803S tube is a double triode with a long plate, based on the Telefunken ECC803S design. It has a 1dB lower gain than the ECC83-Cz but offers a much more detailed and...
En rodage
Première impressions face aux tungsol qualité standard que je viens remplacer.
Plus de présence et de définition dans les basses fréquences.
Pas vraiment plus de details mais il n'ont que 3 ou 4 h d' exercice.
De prime abord, tien de fou face au tungsol.
On verra dans le temps...
Cela reste de bons tubes.
ARYLIC B50 Amplifier Two-Way Bluetooth 5.2 aptX HD HDMI ARC 2x50W 4Ω The Arylic B50 is an extremely versatile and practical Bluetooth 5.2 amplifier, endowed in addition to its wireless connectivity with a wide panel of connectors allowing it to...
Très très bon ampl avec l hdmi parfait pour un televiseur
Excellent ampl très étonnant pour sa gamme de prix. Il fonctionne à merveille pour épauler une TV avec l hdmi arc et l aptx hd s entend c est étonnamment bon quand les appareils connectés supportent le même code pour un système d'appoint ou du quotidien sans prise de tête tv et musique de qualité c'est parfait. En plus l appli est très bien faite franchement super pratique et Son qualitatif.
Didier G.
NEOTECH NEET-3008 Ethernet RJ45 Cable UP-OCC Copper 3m Neotech offers with its NEET-3008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four UP-OCC Copper conductors with a cross-section...
Didier G.
Patrice L.
Excellent choix
Cette nouveauté chez AudioPhonics est excellente .
Du connecteur cuivre doré dans des proportions minimalistes afin de ne pas perdre le signal dans des masses métalliques inutiles ( sauf pour l'égo de certains ... ) .
La coque est également en cuivre qui lui confère une bonne rigidité pour un poids assez léger.
L'accès à la soudure est déjà vue , hyper pratique, l'isolant tient bien la chaleur.
Je ne me perdrai pas dans la critique de la concurrence, mais à conception équivalente et à très exactement 4 x le prix, chacun se fera son opinion.
Cette fiche n'est pas blocable mais perso je ne m'en sers pas dans une régie/son , donc ....
Dans les ratios prix/matériaux/conception/fabrication, je ne chercherai pas plus loin.
Merci Audiophonics pour cette excellente initiative.
Bonnes soudures à tous
Alan S.
Très belle et bonne barrette secteur
je souhaitais refaire un peu mon setup home cinéma et il restait une partie à ne pas trop négliger l'alimentation de ce dernier (TV ampli HC platine Blueray, Console, PC multimedia, décodeur TV ) .
J'ai opté pour cette barrette 8 prises afin de disposer d'assez de prise en tenant compte du placement d'un filtre IFI AUDIO AC iPurifier pour la partie vidéo. J'ai associé des câble secteur de chez PANGEA AC-14SE MKII et franchement ça match bien. Il faudrait que je permute afin de voir si tous les bénéfice sont là mais en tout cas pas de bruit parasite ou de neige à l'écran ni au niveau du système sonore. Ça respire la qualité. Alors est-ce un effet placebo ? En tout cas quand j'écoute une bonne source ( FLAC ) sur mon système je le fais avec un grand plaisir :D
Alan S.
Indispensable pour écoute nomade sur Smartphone
Ayant deux casques de qualité, je voulais pouvoir les utiliser sans souci sur n'importe quel smartphone. Après un moment de recherche, je me suis arrêté sur le Fiio KA3. Et franchement je ne le regrette pas le moins du monde.
Je peux maintenant profiter en mode "nomade" de mes casques ( Hifiman Sundara & Denon AH-D5200 ) sans le moindre souci de performances ( tant puissance que qualité ). ce DAC rikiki permet de les "driver" sans aucun problème. De plus ayant changer de smartphone, le Samsung A53 ne dispose plus de port 3.5mm jack. je me balade donc en permanence avec mon DAC. Ecoute de fichiers lossless ( FLAC ) et streaming via abonnement Qobuz et vrai régal.
J'ai fait écouter le combo à plusieurs collègues et franchement ils étaient stupéfaits de la qualité de rendu.
Je ne peux que recommander ce produit. ( livraison rapide et soignée comme toujours avec audiophonics)
PS : non, je ne suis pas sponsorisé ^^ mais quand un produit est bien il faut le dire. Quand il est mauvais aussi ^^
François R.
efficaces
beau produit protègeant bien le parquet!Il eut été plus confortable qu'elles soient livrées avec la rondelle de caoutchouc déjà installée car cela est fastidieux à mettre
Richard Ö.
This amplifier sounds fantastic !
Having heard many different highend amplifiers the last 20 years, Im very impressed by the sound quality from this amplifier. It is very clean, neutral and powerful, and the spatial qualities and resolution are stellar.
The sound from this amplifier is an upgrade from the otherwise very good sounding Fosi V3 and Aiyima a07.
M A.
IAN CANADA GPIO 40PIN Extension Kit for Raspberry Pi Ian Canada offers a GPIO extension kit for Raspberry Pi, allowing to make an off-set of this connector, especially useful for a box integration of some modules.
another beautiful product from ian canada.
exactly what I was looking for, this way it is easy to expand the gpio of a raspberry pi.
a minus point is that the product is quite pricey ..... something cheaper would have been nice, Other than that it's worth 5 stars.
M A.
LHY AUDIO Triple Linear Power Supply Module LT1963A 5V / +/-5V This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal....
Build quality is good and easy to adjust.
It would be even better if it could deliver higher amps.
all in all a perfect product.
M A.
good quality for a reasonable price.
build quality is good and looks nice.
M A.
nice quality and works fine
already bought several ian canada products and just like this one it really adds something and a very good quality.
use this in combination ian canada PurePi to 3.3 volt input FifiPi MA.
Pascal L.
Excellents résultats audio
Je recherchai une alimentation 5v cc pour remplacer l’alimentation d’origine à découpage d’un streamer audio. Convaincu de l’amelioration apportée par une alimentation linéaire régulée et filtrée sur des équipements audio analogiques, s’agissant exclusivement d’un streamer donc de circuits numériques j’étais pour le moins dubitatif…
Dans un premier temps j’ai remplacé provisoirement mon alimentation à découpage d’origine (5v 5w) par le chargeur d’origine de la marque à la pomme de l’IPad 6 ( 5v 10w) , dispositif également à découpage et là déjà, l’écoute a très nettement gagnée en définition, dynamisme, présence des basses et réalisme des médiums.
J’ai donc décidé d’acquérir sur les conseils avisés du service clients d’Audiophonics, cette alimentation 5V 25VA filtrée et régulée…
Une fois installée, là encore une étape a été franchie par rapport au chargeur de l’IPad 6, à savoir:
- Basses nettement plus profondes et mieux définies,
-Médiums et hauts médiums plus présents, plus détaillés et timbres plus justes
-Aiguës légèrement accrus et détaillés sans aucune agressivité
-Transparence, aération, dynamique, analyse , équilibre des registres, ouverture de la scène sonore nettement améliorées .
En un mot c’est comme s’il ne restait plus que la musique et non plus du son…
Résultat tout à fait similaire à une montée significative en gamme des équipements voire à passer sur un ampli à tubes ou de classe A.
Écoute réalisée à partir d’un streamer moyenne gamme, d’un DAC et d’ un ampli hi-fi de qualité audiophile et d’enceintes 3 voies d’un constructeur Brestois …liaison streamer -DAC via fibre optique en verre véritable et liaison Dac-ampli par l’intermédiaire d’un câble RCA, d’une société Américaine , de qualité réputé pour son équilibre général .
En conclusion : une bonne alimentation permet également d’améliorer la restitution d’un appareil numérique ( je suppose qu’il en est certainement de même pour des équipements vidéo ?)
L’investissement nécessaire reste relativement modique par rapport aux gains obtenus
N’hésitez pas à questionner Audiophoniques car leurs réponses sont pertinentes et très rapides .
Dernier point, matériel reçu rapidement et très bien emballé
Produit bien conçu, bien construit et de qualité .
Je recommande ce produit ainsi que la société Audiophonics.
Bonne écoute à tous
Patrick F.
SUPER
Quelques soucis initiaux dus à un cable coaxial de mauvaise qualité qui hachait le signal. Parfait après correction
Quelle différence d'écoute ensuite, des basses propres et sèches, des aigus denses.
Quel changement comparé à l'audio d'une AppleTV
Vive le FLAC et l'i2S avec Qobuz
Alain S.
Comme cité précédemment ...
Petit appareil qui m'a permis de corriger facilement la qualité de sortie douteuse d'une TV 4K d'entrée de gamme.
Fonctionne à la perfection.
Jean Paul G.
Prise qui Apporte un plus dans tous les registres, neutre et transparent, ne changeant pas les caractéristiques de votre ampli, cd.. c’est étonnant en enlevant, et en remettant une prise lambda avec un câble normal …magnifie un câble plus haut de gamme..
coude.. plus petit? Serais mieux mais garder la même qualité sonore, recommandé
RQP? AAA+
Jean Paul G.
RQP excellent
Prise apportant un plus au niveau sonore large, bande passante, neutralité aucune couleur RQP imbattable
J’ai trouvé le côté pratique très bien, la même chose un petit peu plus plat pour certains endroits serait judicieux. À part cela, je recommande cette prise qui apporte une réalité augmentée dans la transparence à neutralité, ce que nous propose pas toutes les prises électriques. Je suis agréablement surpris, connaissant depuis de longues dates des problématiques rhodium, argent, or et toutes ces prises ESO de prix justifiés ? qui enfin de compte nous font oublier la simplicité de la musique.
Jean Paul G.
Le son est meilleur..
Le son avec cette prise en cuivre est très bon, neutre, équilibré, juste ce qu’il faut partout. Pas trop et genre je fait de l’holographie fatigante. Câble barrette secteur le résultat est la!! Tout est mieux dépourvu un tarif contenu.
Pratique . RQP…
Recommandé
Thierry V.
Excellents!
A nouveau sur conseils de Mr Aubert("re merci")...cable tout cuivre, qui fait enfin chanter mes tannoy mini...avec le modul Canare, je ne me pose plus de question..musique!
Dans ce système , chez moi et oour moi, mieux qu un Melodika sugar b. et surtout qu un inakustik s 1,8ke !
Thierry V.
Bluffant!
Sur conseil de Mr Aubert(merci!)...pour un 2eme systeme.
C est la 1ere fois que je mets des cables aussi peu chers...comparés à des charlins , des mad scientist des vovox...ben je préfère ceux là..incroyables par rapports a des cables 20x plus chers. Tres équilibrés , timbres fidèles, belle scène, dynamique, grave...on analyse plus, on écoute de la musique..quelle fluidité!
stephane s.
tung sol el 34 B
après tous les commentaires que j ai pu lire a propos de ces tubes je l ai installé sur un jolida 302B en remplacement des 6CA7eh mais quelle claque!!!! tout y est grave medium aigu franchement un régal pour les oreilles! je recommande a 200%
Patrick A.
EIZZ EZ-205M Male 3 Poles XLR Connector PTFE Platinum Plated Ø9mm Red (Unit) This Eizz EZ-205M 3-pin male XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation...
Outillage
Pas d'indication sur l'outillage nécessaire pour serrer/desserrer les vis. Dommage ...
Sébastien J.
100% satisfait
Un grand merci à l'équipe audiophonics pour l'excellente gestion de ma commande. Service réactif, professionnel et efficace. Concernant le produit, je suis ravi de la qualité de ce lecteur. Très belle finition. Un très beau produit et un super son dans une taille hyper compacte. Exactement ce que je recherchais pour continuer de profiter de ma collection de cd. Je l'ai associé à un ampli nad C700 tout aussi compact et musical. Un combo rêvé pour profiter de la musique dans tous les formats. Je recommande à 100%
Romain S.
Meilleur rapport prix-basse
Agréablement surpris par la qualité de restitution de ce vibreur basique après égalisation.
Pour comparaison j'ai pu avoir un clark sysnthesis tst329 et un vibreur semblable (d'un aura interactor) et ce produit se rapproche du premier pour moi.
Plage d'utilisation 20-90Hz, pas besoin de pousser l'ampli la définition et très bonne.
Egalisation nécessaire, perso sur PC mais sinon avec votre ampli ou minidsp.
Pierre s.
indispensable
Peu de temps après la publication de mon avis "problème chauffe", il se trouve qu'un composant de l'alimentation a lâché. Ce sont des choses qui arrivent, Le produit, sous garantie, a été pris en charge par Audiophonics et réparé en moins de temps qu'on peut l'écrire.
Je reviens donc sur cette alimentation, déjà pour à nouveau remercier le SAV et qu'ayant remis, le temps de la réparation, les alimentations à découpage d'origine, je me rends mieux compte du gouffre existant en matière de restitution pour le streaming audio.
Pour ma part, box et NAS branchés dessus.
Francis K.
J'avais des problèmes de coupure de son et de décalage avec ma télé en Optique. Ce "Reclocker" a résolu le problème au premier branchement. Je l'alimente directement en USB avec ma télé, comme cela pas besoin d'un autre chargeur sur la multiprise.
Peut-être même que le son est meilleur...
Rien à dire fait le job, parfait !
Antonio C.
a real beast
Hypex NCX500 doesn't need any presentation about its quality....
this amplifier is really well built more than what's visible from site images. Bindings are really well done.
The only note is about OPA: perhaps a couple of OPA1612 would like to be a fantastic upgrade.
Super suggested buy!!!
NICOLA G.
Connections are often underestimated by audiophiles. Dirty rca inputs and poor quality binding posts degrade the audio signal more than one might believe. I replaced the crappy brass-made binding posts on my speakers (cornscala type d) with these Eizz and the difference was stunning. Better imaging, more extension and presence, no traces of harshness, more silence between notes. One of the best buys in my music and hifi lover carrer! Excellent product and excellent service by Audiophonics!
Yves B.
ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit...
Facile à installer, utilisé avec BubbleUpnp je peux écouter Qobuz et les radios numérique de Radio France avec mon vieil ampli des années 70.
YB
Bernard T.
Branché à la place d'un ampli Marantz de 100w sur des enceintes de proximité je suis bluffé par la qualité de cet ampli.
Sur des enceintes à base de tweeter aurum quantus et grave fountek c'est de mon point vue au top.
Envoi très rapide, emballage correcte bravo Audiophonics
Pascal S.
fixées sous des JMR Lunna à la place des vis à pointes, le son devient précis, les basses sont bien définies et profondes. Une homogénéité sur tout le spectre avec un son ouvert. j'ai laissé les pastilles blanches en faisant un trou au centre à l'emporte pièce pour passer les vis de 6 mm. Je suis content du résultat sonore pour un prix correct.
Bernard T.
Super bon cable
Très bonne qualité de fabrication , bon produit
Livré rapidement, bravo à l'équipe Audiophonics
