SATA Adapter for HDD on Raspberry Pi
While the Raspberry Pi is an extremely versatile SBC, it does not have a SATA connector for a hard drive. With the X830, this problem is solved, since the module comes directly under the Raspberry Pi and gives it a SATA connection. It is thus possible to offer a large storage capacity to your RPI, up to 10TB, while having a very good transfer speed thanks to the USB 3.1 to SATA 6Gb/s controller.
The X830 module powers the Raspberry Pi. Do not power the RPI directly via his Micro USB plug. To power the Raspberry Pi simply connect the power cable (2 wires, red and black) as shown below.
Product type | SATA Adapter for Raspberry Poi |
Hardware compatibility | Raspberry Pi 1 Model B+ |
Software compatibility | All OS for Raspberry Pi |
Hard Drive compatibility | SATA 3.5" HDD up to 10TB |
Connectors | 1x USB-A 3.0 1x XH 2.54mm 3 pins (Power output) 1x PH 2.0mm 4 pins (Power switch) |
Power supply | 14~40VDC 3A via Jack DC 5.5/2.5mm |
Dimensions | 155.8 x 118mm |
Package | 1x X830 Board 1x USB Jumper 1x Male / Male USB-A 3.0 Cable 1x Power supply connection cable 4x M2.5 x 12mm spacers 8x M2.5 x 6mm screws 8x Vis M3 x 8mm screws 4x M3 x 30mm spacers |
