Ce lecteur réseau fonctionne très bien avec la solution piCorePlayer et un serveur LMS. Une question cependant, comment faire pour que la DEL du bouton poussoir de mise en route ne clignote pas de façon permanente?
Sabre ES9023 DAC and Raspberry Pi 3
The Raspdac LTE Raspberry Pi 3 comes back in a brand new version equipped with an I-SABRE V3 ES9023 converter.
Switch to high definition dematerialized with RaspDAC LTE. Aluminium and Plexiglas housing, 24bit / 192kHz TCXO, Raspberry 3!
It is an affordable solution for dematerialized reading, assembled and tested in our workshops in France.
Complete and ready-to-use network drive electronically, you only need to install for the software solution of your choice (piCorePlayer, Max2Play...).
This DAC I-SABRE V3 ES9023 is equipped with a TCXO 50MHz Ultra Low Jitter Precision Clock. The analogue stage has no active components and only a capacitor on its path. The result is an authentic listening without the usual caricature colours.
This RaspDAC includes advanced power management (ATX type) for the self-extinguishing of the software solution used. These functions are managed by a PIC and allow different extinguishing modes according to the needs (software or hardware).
Raspberry Pi
Version 3 Modèle B
Audiophonics DAC
I-Sabre V3 ES9023 TCXO
Design
Exclusive
Specially designed to allow you to have the efficiency of your Raspberry Pi in a high quality audio environment, it turns out to be as elegant and discreet so you can easily integrate it into your system.
The Raspberry Pi 3 and DAC I-SABRE V3 torque, integrated in an Aluminium and Plexiglas housing designed in our workshops, will prove to be particularly resistant and durable.
| Connectors | |
| Raspberry Pi Outputs | 4x USB-A 1x Ethernet RJ45 1x Micro SD 1x HDMI |
| DAC ES9023 Outputs | 1x Stereo RCA |
| Specifications | |
| SNR | 110dB |
| Output level | 2V RMS |
| TCXO Clock Ultra Low Jitter | 50MHz |
| Audio formats supported | LPCM 2Ch |
| General | |
| Dimensions | 102 x 169 x 50mm |
| Color | Black |
| Case | 100% Aluminium |
| Weight | 620g |
| Power supply | Jack DC 5.5/2.1mm |
| Accessories | 1x power adapter 7V 3A supplied |
| Input | USB |
| Input | RJ45 |
| Input | Micro SD |
| Output | USB |
| Output | I2S LVDS via HDMI |
| Output | RCA |
| DAC / ADC Chip | ES9023 |
| Max sampling rate | 384kHz |
| Color | Black |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Yves Y.
