Très bien fini toujours un peu compliqué pour les soudures du au revêtement rhodium. Une solution largement supérieur sera d'utiliser des embases RCA Klei Perfect Harmony plaqué argent. C'est ce que j'ai fais avec un petit bricolage en DIY
Viborg's VC303R RCA connector has a pure copper core for excellent signal transmission. The connector is also plated with silver and rhodium to combine maximum conductivity with flawless oxidation protection. Finally, the body of the VC303R connector is made of a non-magnetic copper alloy to block any electromagnetic interference.
Product type | Female RCA connector |
Conductive material | Pure copper |
Contact plating | Rhodium / Silver |
Max cable diameter | Ø8.5mm |
Type of mounting | To solder |
Dimensions | 8.2 x 38 x 14mm |
Package | Sold per unit |
Max cable diameter (mm) | 8.5 |
Mounting type | To weld |
Connectic | Female |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Rhodium |
Contacts Plating (Connector) | Silver |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jizhuang S.
