KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair)
The RCA KLEI Harmony Perfect RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience. For example, the contacts of these sockets are made of copper with silver plating, ensuring an optimum conductivity of 106% IACS.
3.3 / 5
Reference : 14545
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2026.
KLEI HARMONY perfect
KLEI Harmony Classic Embases RCA Cuivre Plaqué Argent (La paire)
The RCA KLEI Harmony Perfect RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience. For example, the contacts of these sockets are made of copper with silver plating, ensuring an optimum conductivity of 101% IACS. The design of these connectors uses many architectural micro-details to focus on signal integrity by eliminating the causes of possible interference, such as eddy current or capacitive reactance.
For the body of the subbases, an ultra heat resistant polymer was used, cancelling the disturbances that can be induced by a metal structure. The mass of the connectors is also reduced and calculated by KLEI in order to limit the skin effect as well as EMF and RF interference.
Thus, these mounts will fit perfectly into your high-end DIY setups and contribute to the signal transmission quality of your audio system.
Product typeRCA plugs
Contacts materialCopper
Contacts platingSilver
IACS Conductivity index> 106%
Screw threadM10
Cutout diameterØ10mm
Max panel thickness7mm (without color ring)
5mm (with color ring)
Connection typeTo solder
QuantitySold by pair (1 plug with red ring, 1 plug with white ring)
Mounting typeTo weld
Max panel thickness (mm)7.0
3 reviews
Embase RCA KLEI HARMONY PERFECT
Connecteur très bien construit avec un minimum de composants métalliques. Très compact et résistant.
Malheureusement non fonctionnel car la lamelle de contact du signal (contact interne) est trop lâche et n'assure pas sa fonction de transmission du signal électrique. Résultat canal muet ou bourdonnement intense.
Ce problème a été constaté sur les 2 paires commandées, la version CLASSIC et la version PERFECT.
A déconseiller.
This review has been posted for KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair)
superbe musicalité
monté sur l entrée de mon ampli et sur mon dac en sortie analogique. quel ouverture et quel clarté redoublée.. tous est a sa place avec un plus partout.. malgré le contact qui est qu' un pin de 2mm sur 1 mm touchant la pin de la prise rca point chaud.. le resultat est vraiment bluffant.. j ai monté des wbt argent pur en sortie de mon lecteur cd x ray..de 18 ans d Age et en entrée numérique de mon dac. audio gd.. quel claque.. déjà que sais excellent sans.. la sais superbe. .j ai même essayer une interface ifi digital ..et la je sens littéralement les personne les timbale les violons.. ils sont devant moi ..dans mon salon.. comme quoi un upgrade resonné et bien fait. améliore vraiment.. se qui est déjà bon.. sa deviens excellent.. pas pour tous bricoleur du dimanche. .mais avec un peut d adresse et de bon conseils. ont peut atteindre une sorte d excellence.. prochainement je craquerais pour une interface de chez audio gd. avec alimentation régénérative..
embrasse RCA klei
déjà elle sont belle de bonne qualités ,attention lorsque vous souder le cable sur le connecteur la soudure doit être rapide , alors passons au meilleur je lui dis choisi du cable NEOTECH OCC de 1,3 mm .le sont est nettement plus vivant plus aérer ses bluffant ,pour encore mieux y mettre du FIL DE CABLE PUR ARGENT et ensuite sous gaine thermo et aussi de confectionner un cable RCA aussi avec du fil de cable argent comme cela le signal est optimum pas de bouchon
The RCA KLEI Harmony Perfect RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the...
