AUDIO-TECHNICA AT-VM95SH Shibata Stereo Phono Cartridge
New
The Audio-Technica AT-VM95SH is one of the flagship cartridges in the VM95 series, offering exceptionally faithful sound reproduction thanks to its Shibata stylus. Designed for demanding audiophiles looking for the ultimate in precision and harmonic richness, this cartridge brilliantly replaces the AT440MLb and AT150MLX models, bringing a new dimension to your vinyl listening. If you're looking for a cell capable of revealing every nuance of your recordings, the VM95SH is your ideal ally.
Reference : 20880
219,00 €tax incl.
182,50 € tax excl.
Audio-Technica AT-VM95SH Shibata Stereo Phono Cartridge
Audio-Technica AT-VM95SH phono cartridge
Key features:
  • Aluminum cantilever
  • 3.5mV output voltage
  • Body compatible with all VM95 styluses
  • Frequency response: 20Hz to 25kHz
Audio-Technica AT-VM95SH: Revolutionary playback
At the heart of the AT-VM95SH's performance lies its naked Shibata stylus, a cutting profile renowned for its ability to follow the groove with extreme precision. This type of stylus offers increased contact with the groove wall, enabling maximum recovery of audio information, including the highest frequencies and subtlest details. Mounted on a sturdy aluminum cantilever, the Shibata stylus guarantees minimal distortion and an extended frequency response from 20Hz to 25kHz. With an output voltage of 3.5mV, the cartridge delivers a balanced signal, ready to be amplified with remarkable clarity. Channel separation of 23dB and a channel balance of 1.5dB testify to its ability to create a vast, incredibly defined soundstage.
Audio-Technica AT-VM95SH: Simplified installation and a gateway to audio excellence
Like all VM95 series cartridge, the AT-VM95SH incorporates threaded inserts in its body, greatly simplifying the installation process. There's no longer any need for tedious nuts; a simple screw connection is all that's needed to secure it to your headshell or tone arm. In addition to its ease of installation, the VM95SH offers remarkable scalability. Its body is fully compatible with all VM95 series replacement stylus. This means you can not only replace the worn-out Shibata stylus (reference AT-VMN95SH) to maintain its optimum performance, but also experiment with other stylus profiles (conical, elliptical, MicroLinear) if your listening preferences evolve. It's a lasting investment in audio quality.
Audio-Technica AT-VM95SH: A lasting audiophile experience
Designed for the most demanding listeners, the AT-VM95SH is ideal for revealing the full potential of your recordings, whether modern pressings or classics from your collection. To ensure optimum performance and longevity of your vinyl records, a recommended vertical pressing force of 1.8 to 2.2g (2.0g standard) is recommended. The estimated service life of a Shibata stylus is around 800 hours of use, making it a durable choice for extended listening sessions. The option of replacing only the stylus, and not the entire cartridge, underlines Audio-Technica's commitment to durability and economy.
Product typePhono cartridge
Frequency response20Hz - 25kHz
Channel separation23dB (1kHz)
Vertical track angle23°
Vertical tracking force1.8g to 2.2g (standard: 2g)
Stylus mountingNude square shank
Recommended load impedance47000Ω
Coil impedance3.3kΩ (1kHz)
DC resistance485Ω
Coil inductance550mH (1kHz)
Output voltage3.5mV (@ 1kHz, 5cm/sec)
Output channel balance1.5dB (1kHz)
Stylus typeShibata
CantileverAluminum pipe
Static compliance20 x 10-6cm / dyne
Dynamic compliance10 x 10-6cm / dyne (100Hz)
Mounting1/2" centres
Cartridge weight6.1g
Recommended load capacity100-200pF
Style size2.7 x 0.26mil
Cartridge typeVM Stereo dual magnet
Cable used for coilT.P. Copper
Dimensions (H x W x D)17.2 x 18.9 x 28.3mm
Supplied accessories2x Mounting screws 11mm
2x Mounting screws 8mm
2x Washers
Non-magnetic screwdriver
The Audio-Technica AT-VM95SH is one of the flagship cartridges in the VM95 series, offering exceptionally faithful sound reproduction thanks to its...
