Refurbished product - Grade S
Cable drop of 90cm.
Coaxial Cable 75 Ohm Silver Shielded 90cm
Neotech's NEVD cable is carefully designed especially for the transmission of digital audio signals. The main characteristic of the digital audio signal is the transmission of very high frequencies. Therefore, the brand has particularly worked on minimizing the signal loss.
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
| Specifications | |
| Product type | Coaxial cable |
| Impedance | 75Ω |
| Conductor | Pure Silver |
| Quad Shielding | Polyethylene foam Cu-Mylar foil Microporous PTFE Braided SP-OFC |
| Quantity | 90cm |
| Diameter (mm) | 7.6 |
| Length (m) | 0.9 |
| Section (mm²) | N/A |
| Conductors material (Cable) | Silver |
| Refurbished Grade | Grade S |
