[GRADE A] FX-AUDIO FX1002A TDA7498E Class D Amplifier 2x100W 4 Ohm Black
Refurbished product - Grade A
The FXAUDIO FX1002A 2x100W on 4 Ohm is the perfect high power integrated amplifier in a small aluminum housing. Powerful thanks to the latest generation Texas TDA7498E chip, it brings a real solution of great simplicity of use with a stereo input, a power button and a front volume. It thus provides the ability to drive even the most difficult bookshelf or column speakers for a reduced budget.
Reference : 16043
Refurbished
85,00 €tax incl.
70,83 € tax excl.
Cardboard box damaged.
FX-Audio FX1002A
Amplifier Class D 2x100W 4 Ohm
FX-Audio FX1002A Amplificateur de bureau Class D 2x152W 4 Ohm
High Fidelity and power
An audiophile quality design
The FX AUDIO FX1002A features audiophile level refinements and components including Epcos film capacitors. The double mono preamplifier part has three high quality interchangeable DIP 8 AOPs. The TL082CP DUAL JFET AOPs with fast and high bandwidth ensure transparency and dynamics.
Rear facade: inputs and output
1RCA input
2Right speaker output
3Left speaker output
4Power supply input DC 24-36V
FX-Audio FX1002A
Setting the gain by DIP selector
The gain of the FX-Audio FX1002A can be adjusted via a DIP switch located in its housing. The diagram opposite shows the different possible settings: 35.6dB, 33.1dB, 29.6dB, 23.6dB.
Test bench by Qobuz
The FX1002A has been fully tested by Qobuz. You can find detailed review by following this link.
SNR99dB
Max power4 Ohm @ THD 10% @ 32V : 2x125W
4 Ohm @ THD 0.1% @ 32V : 2x100W
8 Ohm @ THD 10% @ 32V : 2x60W
Power supplyDC 24-36V
Frequency response20Hz - 20kHz (-0.2dB)
Distortion0.10%
Inputs2x RCA
OutputsGold plated speaker terminals
Weight1.2kg
Dimensions165 x 95 x 30mm
Accessoris1x power cable
1x AC/DC switching adaptor 32V DC 5.9A
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)125.0
Refurbished GradeGrade A
Refurbished product - Grade A The FXAUDIO FX1002A 2x100W on 4 Ohm is the perfect high power integrated amplifier in a small aluminum...
