Refurbished product - Grade A
Cardboard box damaged.
Amplifier Class D 2x100W 4 Ohm
The FXAUDIO FX1002A 2x100W on 4 Ohm is the perfect high power integrated amplifier in a small aluminum housing. Powerful thanks to the latest generation Texas TDA7498E chip, it brings a real solution of great simplicity of use with a stereo input, a power button and a front volume. It thus provides the ability to drive even the most difficult bookshelf or column speakers for a reduced budget.
The FX AUDIO FX1002A features audiophile level refinements and components including Epcos film capacitors. The double mono preamplifier part has three high quality interchangeable DIP 8 AOPs. The TL082CP DUAL JFET AOPs with fast and high bandwidth ensure transparency and dynamics.
1 | RCA input |
2 | Right speaker output |
3 | Left speaker output |
4 | Power supply input DC 24-36V |
The gain of the FX-Audio FX1002A can be adjusted via a DIP switch located in its housing. The diagram opposite shows the different possible settings: 35.6dB, 33.1dB, 29.6dB, 23.6dB.
The FX1002A has been fully tested by Qobuz. You can find detailed review by following this link.
SNR | 99dB |
Max power | 4 Ohm @ THD 10% @ 32V : 2x125W 4 Ohm @ THD 0.1% @ 32V : 2x100W 8 Ohm @ THD 10% @ 32V : 2x60W |
Power supply | DC 24-36V |
Frequency response | 20Hz - 20kHz (-0.2dB) |
Distortion | 0.10% |
Inputs | 2x RCA |
Outputs | Gold plated speaker terminals |
Weight | 1.2kg |
Dimensions | 165 x 95 x 30mm |
Accessoris | 1x power cable 1x AC/DC switching adaptor 32V DC 5.9A |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TDA7498E |
Power (W) | 125.0 |
Refurbished Grade | Grade A |
