Refurbished product - Grade S
Product in perfect condition. Packaging box very slightly damaged.
Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black
iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS ES9038Pro chip, supporting high resolution audio streams, up to PCM 32bit 768kHz, DSD512 and MQA 16x, while ensuring an impressively clear and rich reproduction. The received and decoded audio signal is then routed to the integrated and interchangeable AMP1 MK3 amplifier module.
A true computer that fits in the palm of your hand, the DX240 is equipped with powerful and efficient components. It uses a Snapdragon 660 SoC, associated with a dual Mango OS and Open Android 9.0 operating system. The clock signals are managed by two independent NDK femtosecond oscillators and synchronized by an FPGA optimized by the brand.
In terms of connectivity, the DX240 is also well supplied. Its outputs are indeed multiple since the iBasso DAP provides a single-ended 3.5mm jack output, a balanced TRRS 2.5mm jack output and a 3.5mm jack line output. It also has a bi-directional Bluetooth 5.0 connectivity allowing to connect it to a source such as a smartphone as well as to a headset or Bluetooth earphones. Its WiFi 2.4GHZ/5GHz connectivity allows it to access files stored on your local network.
Embedding a large 4400mAh battery, the device charges easily and quickly via a USB-C port, for up to 11 hours of playback time.
Finally, its intuitive and modern design offers convenient access to all control buttons. Its large 5" Full HD screen provides perfect readability and an excellent user experience.
Product type | Digital audio player (DAP) |
Input | Micro SD slot (up to 2TB, Micro SD card not included) |
Outputs | 1x Balanced TRRS Jack 2.5mm 1x Single-ended Jack 3.5mm 1x Jack 3.5mm line output |
Connectivity | Bluetooth 5.0 bi-directionnal WiFi dual-band 2.4GHz/5GHz |
DAC Chip | ESS ES9038Pro |
Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 MQA 16x |
Screen | Full HD 1080p 5" |
SoC | Snapdragon 660 |
RAM | 4GB |
ROM (Storage) | 64GB |
Battery | 4400mAh |
Autonomy | 11h playback |
harging time | 2.5h |
Interchangeable amplifier | Supplied with AMP1 MK3 amplifier module |
Balanced Jack 2.5mm output characteristics | |
Max output level | 6.2Vrms |
Output power | 878mW @ 32Ω 128mW @ 300Ω |
Frequency response | 10Hz - 45kHz |
SNR | 125dB |
Dynamic range | 125dB |
THD+N | -114dB |
Output impedance | 0.57Ω |
Single-ended Jack 3.5mm characteristics | |
Max output level | 3.1Vrms |
Output power | 281mW @ 32Ω 32mW @ 300Ω |
SNR | 123dB |
Dynamic range | 123dB |
THD+N | -110dB |
Output impedance | 0.38Ω |
Color | Black |
Dimensions | 126 x 70.5 x 18.7mm |
Weight | 240g |
Package | 1x iBasso DX240 1x USB cable |
Input | Bluetooth |
Input | WiFi |
Input | Micro SD |
Output | Jack 2.5mm |
Output | Coaxial SPDIF |
Output | Bluetooth |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Color | Black |
Refurbished Grade | Grade S |
