Refurbished product - Grade S
Perfect condition.
DAP Compact Hifi Player DAC ES9218P Blue
Shanling offers with its M0 a digital player high fidelity extremely compact with original aesthetics. But the Shanling M0 is also a concentrate of technologies and features to offer you high definition sound, wherever you are!
The first thing that is obvious with this Shanling M0 is of course its particularly small size. Designed to follow you in all your movements, without cluttering you, the DAP measures only 40 x 13.5 x 45mm. On the weight side, the M0 weighs only 38g. So it will easily be forgotten so you can fully enjoy your music.
However, Shanling makes no concessions on ergonomics and integrates a beautiful 1.54" high definition touch screen from LG. This will allow you to simply access your music and act on all available settings. A screen placed behind a curved tempered glass window and components protected by a superb 100% Aluminium CNC machined case.
If Shanling takes great care in the aesthetics of its product, this desire to offer a product that is both beautiful and easy to learn is on the software side with the MTouch OS operating system. Thus, the interface of the walkman allows a fast and easy navigation, and an easy access to the numerous functionalities.
On the sound side, the M0 incorporates a DAC ESS ES9218P. This will allow a quality Digital / Analog conversion in full transparency. A converter associated with a powerful amplification section and an analog volume control. A combination that allows this small DAP to offer 118dB SNR, 0.004% distortion and support sample rates up to 32bit 384kHz, for accurate and detailed reproduction.
In addition, this walkman embeds a multi-layer PCB, allowing it on the one hand to take advantage of a smaller size of 38% compared to its big brother the Shanling M1, and on the other hand to have a cleaner electrical circuit and thus limit interference on the signal.
If the Shanling M0 of course has a Jack 3.5 connector to connect it in a classic way to your headset, it also offers connectivity Bluetooth for more comfortable use. Bluetooth connectivity with Sony LDAC and Qualcomm aptX technologies. This first technology, LDAC allows to enjoy Bluetooth Hi-Res Audio files, up to 24bit 96kHz 4.5Mbps, where traditional Bluetooth would allow only 16bit 44.1Hz compressed. The second technology, aptX, allows a transmission with less latency and more stable, in order to restore a clean signal.
But more than that, the M0 benefits from a bi-directional Bluetooth 4.1. Thus, if it can transmit to a speaker or a headset, it can also serve as a receiver, in order to benefit from its amplification and its DAC, from a third source.
In the same vein, this walkman also offers a bi-directional USB-C port. Like Bluetooth, it will therefore be able to receive or send audio data. Ideal for enjoying the audio performance of the device.
The DAP integrates a battery of 630mAh for an autonomy of 15h in reading, and days in standby. Perfect for enjoying your music without interruption during all your travels.
| Specifications | |
| DAC | ESS ES9218P |
| Output power | 80mW @ 32Ω |
| Recommended headphone impedance | 8 - 300Ω |
| Frequency response | 20Hz - 20kHz (-0.5dB) |
| Distortion | 0.004% (500mV) |
| SNR | 118dB |
| Output impedance | 0.16Ω |
| Channels resolution | 70dB |
| Dynamic range | > 105dB |
| Up to 32bit 384kHz / DSD128 | |
| Supported formats | |
| DSD | DSD64, DSD128 (.iso, .dsf, .dff) |
| DXD | Up to 32bit 384kHz |
| APE | Up to 24bit 192kHz / 16bit 384kHz |
| FLAC | Up to 24bit 192kHz |
| ALAC | Up to 24bit 192kHz |
| WAV | Up to 32bit 384kHz |
| AIFF/AIF | Up to 32bit 192kHz |
| DTS | - |
| Supported formats with lossess | MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, CUE |
| General | |
| Dimensions | 40 x 13.5 x 45mm |
| Screen | 1.54" 240 x 240px High Definition |
| Weight | 38g |
| Autonomy | 15h |
| Standby autonomy | 30 days |
| Charging time | 2h |
| Battery | 630mAh |
| Storage | Micro SD up to 512Go (not included) |
| Output | Jack 3.5mm |
| Color | Blue |
| Input | Micro SD |
| Input | Bluetooth |
| Output | Bluetooth |
| DAC / ADC Chip | ES9218P |
| Max sampling rate | DSD128 |
| Max sampling rate | 384kHz |
| Color | Blue |
| Refurbished Grade | Grade S |
