Refurbished product - Grade B
Slight scratches on the back.
The new DAP Shanling M5 Ultra is equipped with cutting-edge components and a new look, making it an original device. It features the AKM AK4499EX + AK4191EQ chip combo, as well as a USB XMOS XU316 interface, enabling it to support high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512. The M5 Ultra features the same I/V conversion stage as the brand's M9 Plus for perfect conversion quality.
On the amplification side, it features a TPA6120A2 chip for output power of up to 1070 mW at 32 Ohm. Many other features are available, such as bi-directional Bluetooth 5.2. In terms of connectivity, it works with WiFi 2.4/5G and supports DLNA and Airplay protocols, enabling it to connect to a NAS, for example. It also natively supports the TIDAL streaming service.
Regarding its appearance, Shanling has opted for sobriety, with a 4.7" IPS touchscreen and elegant angled curves on the edge. The connectivity interface goes straight to the essential, with a bi-directional USB-C port, a microSD slot up to 2TB and, of course, two headphone outputs: a 3.5mm jack and a balanced 4.4mm jack.
Shanling has equipped its M5 Ultra digital music player with a combo of AKM chips. An AK4499EX DAC chip and an AK4191EQ digital filter chip. Added to this is an XMOS XU316 USB interface. Together, they enable the M5 Ultra to support 32bit 768 kHz PCM and native DSD streams up to DSD512.
A Texas Instrument TPA6120A chip provides the headphone amplification. This high-fidelity chip with Class AB architecture delivers wide bandwidth, low noise and up to 128dB dynamic range, giving the M5 Ultra an output power of up to 1070mW at 32 ohm on its balanced output and 305mW at 32 ohm on its unbalanced output.
A bi-directional Bluetooth 5.2 chip enables the M5 Ultra to support high-resolution codecs: aptX, aptX HD and LDAC. The Shanling M5 Ultra is therefore able to receive and transmit high-resolution data wirelessly, in a reliable and stable way.
Thanks to its WiFi 2.4/5G connection, the Shanling M5 Ultra DAP offers a wide range of streaming services. It also supports TIDAL, DLNA, AirPlay and NAS protocols for connection to local servers.
An Ingenic X2000 processor provides a fast, easy interface and an advanced operating system. The 4.7" touchscreen offers optimal navigation space. Three buttons on the left side panel and a rotary knob complete the package for fast, fluid control of certain functions.
The M5 Ultra's case is simple and elegant, with slightly beveled side panels. The M5 Ultra's modern design sets it apart from other Shanling DAPs.
Inside the Shanling M5 Ultra is a 6000mAh battery, providing 10.5H unbalanced output and 8.5H balanced output.
Product type | DAP Digital Audio Player |
DAC chip | KM AK4499EX + AK4191EQ |
Headphone amplification chip | TPA6120A2 |
Processor | Ingenic X2000 |
Inputs | USB-C input (bi-directional) microSD slot (2TB) Bluetooth |
Outputs | 1x 3.5mm headphone output 1x 4.4mm balanced headphone output 1x USB-C (bi-directional) Bluetooth |
Supported sample rates | PCM 32bit 768kHz, native DSD up to DSD512 |
Supported Bluetooth Codecs | SBC, AAC, aptX, aptX HD, LDAC |
Connectivity | WiFi 2.4/5G Bluetooth 5.2 bi-directional |
Headphone output power | Jack 3.5mm : 305 mW @ 32 Ohm Jack 4.4mm : 1070mW @ 32 Ohm |
Output impedance | Jack 3.5mm : 4.7 Ohm Jack 4.4mm : 6.6 Ohm |
Screen | 4.7" IPS touchscreen |
SyncLink with Eddict Player App | |
Battery | 6000mAh |
Autonomy | 10.5H on unbalanced output 8.5H on balanced output |
Color | Silver |
Package | 1x Shanling M5 Ultra DAP |
Input | USB |
Input | Micro SD |
Input | Bluetooth |
Input | WiFi |
Output | Jack 3.5mm |
Output | Bluetooth |
Output | USB |
Output | Jack 4.4mm |
DAC / ADC Chip | AK4499EX |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
Refurbished Grade | Grade B |
