FOSI AUDIO VOL20 Volume Control Knob
The Fosi Audio VOL20 is a volume control interface for controlling the volume of a multimedia source via Bluetooth or USB connection. As well as offering precise volume control, it incorporates practical features such as play/pause, previous/next and mute/unmute controls.
Reference : 20237
39,00 €tax incl.
32,50 € tax excl.
Fosi Audio VOL20 Bluetooth / USB Volume Control Knob
Photo of Fosi Audio VOL20
The Fosi Audio VOL20 is a volume control interface for controlling the volume of a multimedia source via Bluetooth or USB connection. As well as offering precise volume control, it incorporates practical features such as play/pause, previous/next and mute/unmute controls. With its customizable RGB LED, 10m Bluetooth range and up to 15 hours of battery life, the VOL20 is ideal for controlling your multimedia devices with ease. All integrated into a robust, modern aluminum chassis.
Fosi Audio VOL20: numerous functions
In addition to controlling the volume of your source, you'll have access to a host of additional functions:
  • One click: play/pause
  • Double-click: next track
  • Three clicks: previous track
  • 2 second long click: mute/unmute
Fosi Audio VOL20 features
Multiple operating system compatibility
Fosi Audio VOL20: multi-OS compatibility
The Fosi VOL20 is compatible with many OS in plug & play (without driver) for immediate use: Windows, macOS, iOS, Android, HarmonyOS.
Fosi Audio VOL20: customizable RGB LED
The RGB LED at the base of the VOL20 can be customized in a wide range of ways.
LED RGB
a high-performance battery
Fosi Audio VOL20: a high-performance battery
A 750mAh battery allows the VOL20 to run for up to 15h with its LED on, and up to 500h with the LED off.
Fosi VOL20 overview
Overview of Fosi Audio VOL20
1Multifunction button
2LED control knob
3Charge indicator
4USB DATA/charging port
5Ignition switch
Product typeBluetooth volume control
ConnectivityBluetooth / USB
Bluetooth range10m
OS compatibilityWindows, macOS, Android, IOS, HarmonyOS
Case materialCNC-machined zinc alloy
ChargeVia USB-C
Battery750mAh
Battery life15h with LED / 500h without LED
DimensionsØ55mm
Package1x Fosi Audio VOL20
1x USB-C/A to USB cable
OutputBluetooth
OutputUSB
ColorGray
FOSI AUDIO VOL20 Bluetooth / USB Volume Control Knob
The Fosi Audio VOL20 is a volume control interface for controlling the volume of a multimedia source via Bluetooth or USB connection. As well as...
