Rotary Digital Encoder 24 Steps Push Button D Shaft 15mm
This 24-position rotary encoder has a D shaft for attaching a button and a push button. In particular, it can be used as volume and source control.
Reference : 13022
1,60 €tax incl.
1,33 € tax excl.
Shipping date: 14-04-2026.
Rotary encoder
24 steps, push button, D shaft 15mm
This 24-position incremental rotary encoder has a D shaft to attach a knob. It can be used as a volume control or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push button and can therefore also be used as a source selector for example..
Type of productRotary digital encoder + push button
Number of steps24
Shaft typeD shaft
OutputIncremental
Shaft length15mm
Shaft diameter6mm
Total dimensions15 x 12.5 x 25mm
Type of connectionPins to solder
encodeur rotatif axe méplat 15mm
ShaftFlat
ChannelN/A
Resistance (Ohm)N/A
Tolerance (%)N/A
demande d'envoi des 2 en stock
Si le délai est trop long pour le réapprovisionnement merci de m'envoyer les 2 que vous avez en stock.
En fait j'en ai besoins que de 2. J’ai mis une quantité de 5 pour le minimum de commande.
Je vous offre donc les 3 autres.
Merci,
Christian Lemmer
This review has been posted for Rotary Digital Encoder 24 Steps Push Button D Shaft 15mm
