FURUTECH FT-SDS NCF (R) Power Plug Schuko Type F for Power Distributor Rhodium Plated
-17%
The Rhodium-plated Schuko Furutech FT-SDS-R NCF plug is a new version with a body using the brand's technological advances. Taking up the recognized qualities of the technical developments of Furutech "Piezo Effect" ceramics with damping properties, here is a very high level mains socket.
4.7 / 5
Reduced price!
Reference : 11376
Limited time offer:
94,90 €tax incl.
-17%
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 17-07-2025.
Furutech FT-SDS NCF (R)
Schuko Socket for Power Distributor Rhodium Plated
Furutech FT-SDS NCF (R) Prise Schuko pour Distributeur Secteur Plaqué Rhodium
As for the other Schuko plugs of the Japanese brand, this one receives the patented Alpha non-magnetic treatment which made the reputation of Furutech. The high contact quality of this high-end plug makes it an indispensable accessory for high-end hi-fi systems requiring the utmost attention to detail.
In addition, this plug is Rhodium-plated for high stability over time of the mechanical and electrical characteristics of this Furutech wall outlet.
NCF Technology
Incorporated in the new Furutech product series, NCF (Nano Crystal² Formula) consists of a special crystalline material with two "active" properties.
First of all, it generates negative ions that eliminate static electricity. It also converts thermal energy into far infrared (LIR) energy with wavelengths ranging from 50µm to 5mm.
Furutech then combines this remarkable material with nanoscale ceramic particles and Carbon powder for their "piezo effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electrical and mechanical damping material and is only available in Furutech products.
The depth of the grip is 52mm. This will not be suitable for all installations.
Technical specifications
Product typeSchuko socket for power distributor
Contacts materialPure Copper
Furutech α (Alpha) treatment
Contacts platingRhodium
Body materialNylon
Fiberglass
Front panel materialPolycarbonate
Base materialZinc / Steel 1mm
Max cable diameterØ2.8mm
Max cable section5.5mm² (10AWG)
Dimensions54.8 x 54.8 x 52mm
Cutout diameterØ55mm
Voltage / Current250VAC 16A
Mounting holes spacing40 x 40mm
Cutout for the passage of the bottom plate50 x 50mm
Max cable diameter (mm)2.8
Mounting typeTo screw
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
Rated current (A)16.0
3 reviews
la barrette neodio pw1, contient un filtre mécanique, qui je pense fonctionne sur un des deux principes qui animent la prise NCF, donc peut etre double emploi.
This review has been posted for FURUTECH FT-SDS NCF (R) Power Plug Schuko Type F for Power Distributor Rhodium Plated
bonjour
votre alimentation avec le cable sommer dédié est deja excellente. avez vous noté avec la prise NCF . si il y avait un peu plus d'air entre les instruments et si ils etaient mieux détourés (c'est assez subtil) et . si vous utilisez un caisson de basse (la prise etant sensée travailler sur la resonance du 50 herz) si celui ci est un peu plus mélodique?
Doit faire ses preuves...
J’ai acquis une barrette de secteur Neodio PW1 qui a apporté une amélioration sensible l’écoute. Je l’ai reliée à une prise murale FURUTECH FT-SDS NCF (R) Schuko plaquée rhodium, connectée et reliée directement à un disjoncteur dédié par un câble de secteur SOMMERCABLE NYM-ST-J Câble cuivre OFC 3x2.5mm². Je n’ai pas pu constater d’amélioration sensible par ce câblage. Peut-être est-ce aussi dû à mon ensemble d’appareil hifi de gamme moyenne (Naim Uniti 2, enceintes Melusine…) ???
The Rhodium-plated Schuko Furutech FT-SDS-R NCF plug is a new version with a body using the brand's technological advances. Taking up the...
